When it comes to building an audio or home theater setup, everyone loves to obsess over the sexy stuff—content sources, processors, amps, speakers. You know, the gear that gets all the glory shots on YouTube and makes your wallet cry. But here’s the thing: if you want it all to work (and keep working), you’d better budget for the boring stuff too—cables, power management, racks, maybe even some decent lighting if you don’t want to feel like you’re watching The Batman in a cave — which would actually make some sense, but I digress.
And then there’s vibration control. The most misunderstood and over-marketed accessory in audiophilia. Some companies will try to convince you their $800 magic stones will “unlock” your system’s third eye. Spoiler: they won’t. But IsoAcoustics? They’ve actually earned their rep. Pros use them. Audiophiles trust them. And unlike a lot of tweak-market snake oil, their stuff actually makes a measurable and audible difference. Shocking, we know.
IsoAcoustics
IsoAcoustics has built a strong reputation in the OEM, pro, and hi-fi worlds for its effective vibration control solutions. Known for its high-performance isolation feet, the company is expanding its popular GAIA Series in 2025 with two new models: the GAIA Neo and GAIA-TITAN Neo.
The new GAIA Neo and GAIA-TITAN Neo models build on IsoAcoustics’ proven design with upgraded materials and engineering meant to handle everything from compact floorstanders to behemoth reference loudspeakers. Like their predecessors, they isolate speakers from vibrations that travel through the floor and back up into the cabinet—interference that can smear detail, tighten bass, and generally make your expensive gear sound like it’s wearing cheap shoes.
GAIA Neo Series
IsoAcoustics introduced the GAIA series in 2016, offering threaded isolation feet that reduced vibration and resonance for better audio performance. A decade later, the GAIA-TITAN line was added, and at High End Munich 2025, IsoAcoustics will preview the GAIA Neo and GAIA-TITAN Neo. These new models follow the same tiered structure as before, with three sizes each, designed to support a range of speakers and components based on size and weight capacity.
Weight Capacity
(Per Set of 4)Dimensions
(W x H)GAIA III NEO 32 kg (70 lbs) 2.2 x 1.8 IN (56 x 45 mm) GAIA II Neo 55 kg (120 lbs) 2.6 x 2 in (65 x 50 mm) GAIA I Neo 100 kg (220 lbs) 3 x 2 in (77 x 52 mm) GAIA-TITAN Theis Neo 145 kg (320 lbs) 3.4 W x 2.2 in (86 x 56 mm) GAIA-TITAN Rhea Neo 190 kg (420 lbs) 3.7 W x 2.4 in (94 x 60 mm) GAIA-TITAN Cronos Neo 281 kg (620 lbs) 4.2 x 2.5 in (106 x 64 mm)
Pro Tip: The weight guidelines provided by IsoAcoustics should be carefully followed to ensure the best performance.
Key Features
Enhanced Isolation: Neo builds on IsoAcoustics technology. This provides greater isolation and sonic clarity.
Seamless Height Adjustment: The Neo design incorporates a lower rotating ring that allows easy height adjustment. By rotating the ring, the isolator can be raised or lowered without affecting its on-axis alignment.
Refined Aesthetic & Simplified Installation: The new models eliminate the need for lock nuts, making installation a breeze. The isolator housing now sits flush against the bottom of the speaker, with an integrated O-ring that compresses for a secure fit and ensures proper alignment.
Floor Sliders: The included Floor Sliders make positioning large speakers a breeze. Just slide the speakers into place, then tilt one side at a time to remove the Sliders. These Floor Sliders will be available to ensure a smooth and easy installation.
Thread Sizes: Each GAIA Neo model includes the three most common thread sizes to fit a wide range of speakers and components. These sizes accommodate the majority of applications. Alternate thread sizes are also available.
Finishes: The Gaia with Neo line comes in two finishes: Black and Dark Chrome.
From Dave Morrison, Founder of IsoAcoustics: “GAIA Neo makes it easier than ever for audiophiles and hi-fi enthusiasts to unlock the full potential of their systems,…GAIA is the standard in isolation performance for the audio market, and we’ve worked very hard to make this outstanding product line even better. Neo is the culmination of this exploration.”
IsoAcoustics Online Product Selector
IsoAcoustics’ Online Product Selector simplifies finding the perfect isolation solution for your setup. By following a few prompts, this intuitive tool recommends the right isolator based on your speaker or equipment type and specifies the required thread size. Ahead of the GAIA Neo launch, the Online Product Selector will be updated, ensuring customers can easily choose the right model and adapter with confidence.
IsoAcoustics: The Hidden OEM Secret Behind Some of the World’s Best Speakers
IsoAcoustics designs and manufactures acoustic isolation products for speakers from some of the most respected high-end loudspeaker brands, including Sonus faber, Marten, PSB Speakers, Perlisten, Gershman Acoustics, and more. This means when you purchase selected models from these brands, IsoAcoustics is part of the package.
The new GAIA Neo solution is already gaining traction with these prestigious brands and drawing even more manufacturers into the fold. At HIGH END Munich 2025, two world-class speaker brands will unveil new flagship models, each built on the advanced OEM integration of IsoAcoustics’ GAIA Neo and GAIA-TITAN Neo isolators.
The Bottom Line
So, while everyone’s fawning over the latest speaker or amp, don’t forget the unsung hero: acoustic isolation. After all, even the best gear is just a bunch of vibrating metal and plastic without the right foundation. If you’re heading to High End Munich 2025 from May 15th through 18th, you’ll have the chance to see (and hear) how IsoAcoustics’ products make your system actually perform—because, let’s face it, your speakers deserve better than sitting on your coffee table like they’re just another piece of furniture.
Price & Availability
The IsoAcoustics GAIA Neo and GAIA-Titan Neo Series will be available Q3 of 2025. Pricing is TBD. Both products will make their worldwide debut at HIGH END Munich, May 15-18, 2025, at MOC in Munich, Germany.
IsoAcoustics will be exhibiting in Room A 4.2 F210. Visitors will have the opportunity to experience the IsoAcoustics difference onsite through A/B testing of the new GAIA Neo versus factory spikes.
For more information, visit: isoacoustics.com.
Related Reading
