A/V Furniture & Accessories
IsoAcoustics’ Aperta Sub XL Isolator Will Firm Up Your Bottom End: High-End Munich 2023
If you think isolating your subwoofer from the rest of your room doesn’t make a lot of sense — think again. The IsoAcoustics Aperta Sub XL Isolator might be the answer you are looking for when it comes to maximizing your subwoofers impact.
IsoAcoustics Aperta Sub XL isolator under subwoofer
Big Bottoms. Big Bottoms. Big Bottoms drive me out of my mind. Don’t let your subwoofer get left behind.
Vibration is the enemy; both in the recording studio and in your home when it comes to sound quality. Put your hand on your loudspeaker while listening to music and you’ll immediately feel how the energy produced by the drivers causes the cabinet to resonate. That level of resonance affects how your loudspeaker sounds. External vibration from your room, equipment stand, or loudspeaker stands impacts how your loudspeakers sound as well.
We have written rather extensively about IsoAcoustics’ range of isolation stands and platforms and many of us them in our own systems; I currently use one set of Aperta stands on the desktop with bookshelf loudspeakers and three of their isolation platforms underneath 2 turntables and my Cambridge Audio Edge A Integrated Amplifier.
The Aperta Sub XL brings the patented IsoAcoustics isolation technology to larger subwoofers of up to 160 lbs / 72.5 kg. Taming the power of such mighty speakers is no easy feat, but IsoAcoustics managed to build on the design of the Aperta Sub for smaller subwoofers to perfectly support heavier models. By carefully managing the distribution of low frequencies, the Aperta Sub XL retains the subwoofer’s power while mitigating unwanted side effects, leading to a clearer, more defined sound.
IsoAcoustics Aperta Sub (smaller version)
Managing Powerful Bass
Like its smaller sibling, the IsoAcoustics Aperta Sub XL decouples the subwoofer from the supporting surface. Its specially designed internal isolators absorb the energy that would otherwise be transferred to the structure underneath and cause disturbances of the sound image.
It also keeps that energy from reflecting and being conducted back into the subwoofer, where it could cause smearing. The result is a remarkable improvement in terms of clarity and definition – sonic properties that are particularly hard to come by in the low frequency spectrum.
Design & Functionality
The design of the IsoAcoustics Aperta Sub XL is as clever as it is subtle. It discreetly supports and decouples the subwoofer without drawing much attention. Since most subwoofers come with feet in all four corners, the Aperta Sub XL uses the space between the feet to make contact, an important design decision considering the isolators are directional to maintain the speaker’s energy on-axis.
It comes with optional carpet disks that anchor the sub into carpeted surfaces if required. The Aperta Sub XL measures at 14.5” wide by 16” deep by 1.5” high (368 mm x 406 mm x 37 mm).
IsoAcoustics Aperta Sub XL isolator under subwoofer crop
HIGH END 2023
IsoAcoustics will show the Aperta Sub XL at hifi trade show HIGH END from the 18th through 21st May 2023 at the MOC in Munich, Germany. Attendees can find IsoAcoustics at Atrium 4.2 F210 and listen to the company’s products in action.
The presentations will feature A/B demonstrations with GAIA isolators on Focal Scala Utopia Evo speakers, showcasing the considerable sound difference between GAIA isolators and the speakers’ factory spikes.
Price & Availability
  • The IsoAcoustics Aperta Sub XL (supporting up to 160 lbs) will be available in June 2023 for $189.99 USD.
Related reading: See more coverage of HIGH END Munich 2023
3 Comments
3 Comments
  1. LONNY JENNINGS
    May 17, 2023 at 2:23 am
    I assume there’s double blind testing to back up all the claims of these magic devices? How about you spend the money instead and buy a competent subwoofer whose cabinet doesn’t vibrate?
    Speaking of magic, they’re directional? How, pray tell, does that work? I’ve been in this game for fifty years. I’ve seen it all; bricks on transformers, Tice (Radio Shack) clock on the same AC feed, isolators on speaker cables, burning in wires, and it never ceases to amaze me how this kind of BS gets people to part with their money.
    As always, I don’t know where the lunacy resides more, the purveyors of this crap or the idiots who buy it.
    Show me the testing proof and/or the physics.
    • Ian White
      May 17, 2023 at 11:07 am
      Lonny,
      I will say this about their products (I own 5 of them). The speaker stands make a very large difference in terms of the isolation from the rest of the room, but they also thin out the sound somewhat on some loudspeakers. I’ve tried the Aperta stands on 5 bookshelf speakers (under $1,000) and whilst the overall clarity improves, the bass loses some of its impact and it almost felt like I had changed the amplifier.
      I’ve never been a proponent of 90% of the accessories pushed by brands (you left out the Armor All and green markers) and agree that there is a lot of BS being spewed.
      Best,
      Ian White
  2. Ian Jackson
    May 17, 2023 at 9:17 am
    I use four washing machine pucks under my SVS PB1000. Does the job for almost no outlay.
Audio Technica ATH-R30x Open Back Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Our favorite products for audiophiles and studio professionals from NAMM 2025, including headphones, speakers, and some surprises.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Thinking of replacing your existing loudspeakers? The IsoAcoustics GAIA III Speaker Isolation Feet might force you to change your mind and save money as...
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
