Integra Announces New Flagship DRX-8.4 AVR
At $3,200, Integra’s flagship home theater receiver offers 11 x 150-watts of power, Dirac Live, and 8K pass-thru along with extra features for custom installers.
Integra DRX-8.4 A/V Receiver 2023
2023 Integra DRX-8.4 A/V Receiver
Integra has announced its new flagship AVR for 2023, the DRX-8.4
Designed for the custom install (CI) market the DRX 8.4 incorporates a comprehensive feature set including a newly engineered chassis and audio signal path for optimum noise reduction and signal clarity, with support from 32-bit ESS ES9026PRO Hyperstream® audiophile DACs
To better support the custom installation market, the DRX-8.4 is compatible with Control4, Crestron, Save, URC, Elan, and RTI custom installation control systems.  The 8.4 also has a Quad-core network processor for optimum IP responsiveness and stability.
Integra DRX-8.4 A/V Receiver Front
With its 11 channels of amplification and two independent subwoofer outputs, the DRX-8.4 supports 7.2.4 channel speaker setups. The 8.4 also includes two additional wired zone outputs. This allows for Zone 2 and Zone 3 two-channel stereo setups.
The DRX-8.4 also has Dirac Live room correction built-in (License included). This allows users to fine-tune speakers connected to the DRX 8.4 to more accurately match the acoustic environment of the room they are placed in, providing a more well-rounded music listening experience with better accuracy, more prominent sweet spot, more precise voice intelligibility, and deeper, but less boomy bass.
Room Correction Setup can be done via the Dirac PC/MAC app and optional USB mic (Advanced), or via the free Integra Mobile App (iOS, Android) and included wired mic (Basic).
Tip: Dirac Live Bass Control ready (single or multi) as an optional user upgrade
If you have any trouble with the DRX-8.4, an onboard diagnostics tool kit with video test patterns, EDID/HDCP adjustments, and a virtual remote is included that can be used via a web app.
Integra Partners
Additional Features
Here is more detail on some of the additional features and specifications of the DRX-8.4.
Amplication: 11 Channel Amplifier (A/B class)  that delivers 150 Watts per channel (8 ohms, 20 Hz–20 kHz, 0.08%  THD, 2-ch driven, FTC).
Audio Support: The Integra DRX- 8.4 has you covered for home theater sound with support for almost all surround sound formats including Dolby Atmos/Dolby Atmos Music, DTS:X, and Auro 3D (with firmware update) as mentioned above, as well as IMAX Enhanced and additional surround sound processing capability.
Hi-Res Audio: Support for 24-bit/192kHz audio playback. Digital audio format support includes MP3, WMA, WAV, MPEG-4/AAC, FLAC, and ALAC
Wireless Music Streaming: Amazon HD, Spotify Connect, Tidal, Deezer, Padora, Tune-In, and Roon Ready.
Multi-room Audio: Works with Sonos Certified.
HDMI 2.1 Support: Includes HDMI-eARC and Gaming Support (4K/120Hz, 8K/60Hz) with up to 40Gbps transfer rate, VRR (Variable Refresh Rate), ALLM (Auto Low Latency Mode), and Quick Frame Transport (QFT).
HDR: Pass-through of all HDR formats, including Dolby Vision is provided.
Remote Control: A wireless handheld remote is provided.
Voice Control: Alexa Built-in, Google Assistant, Apple Siri, and Josh AI (this option needs to be installed professionally)
Smartphone App Control: iOS, Android
Additional Control: 12-volt trigger (2), wired remote sensor (in/out), RS232C, IP Control
Integra DRX-8.4 A/V Receiver Rear
Connectivity
  • Wireless: Bluetooth (Aptx HD), AirPlay 2, Chromecast Built-in Wi-Fi (Wired Ethernet is also included if needed).
  • Wired Inputs: HDMI  (6 rear/1 front), Analog (5 plus 1 x XLR), Phono (MM-1), Digital Optical (3), Digital Coaxial (2), USB (1 1 Rear)
  • Wired Outputs: HDMI (3), Multichannel Pre-out (11), Subwoofer (4 – two independent/2 parallel), XLR pre-out options for L/C/R, SW1/SW2.
  • Speaker Connections: 15 Pairs of speaker terminals (one pair for each amplified channel).
Integra DRX-8.4 A/V Receiver Top Open
Dimensions and Weight
  • Dimensions (WHD): 17 1/8 x 7 13/16 x 18 1/2 inches (435 x 198 x 470 mm.
  • Weight: 49.6 lbs (22.5 kg)
Pricing and Availability
The Integra DRX-8.4 is available for $3,200 at WorldWideStereo.com as of Spring 2023 and through authorized Integra integration dealers.
8 Comments
8 Comments
  1. LG
    March 1, 2023 at 7:22 pm
    Are you serious $3200 for a flagship receiver like that there’s absolutely nothing in it you shouldn’t call that a flagship you should have called that a mid-range you need to go learn from the other manufacturers that makes high-end receivers and have incredible parts inside them this is nothing but a piece of junk
    • Boolero
      March 2, 2023 at 1:25 pm
      Well, it is still THEIR new flagship avr designed for the custom installer market.
      • Stephen Livingstone
        April 28, 2023 at 5:05 am
        Are u guys joking. $3200 for this is amazing. Think about it. Denon 4800h over priced, marantz cinema 40 $3500 overpriced. Nad overpriced less outputs less control. Arcam $4200 still not dirac full control overpriced. Onkyo/integra is the only brand right now trying to bring prices down for normal people. Only other brand I would recommend is anthem.
    • Robert Soeder J
      March 6, 2023 at 10:32 am
      This is over priced and is ugly no one should by it just because of its price I wouldn’t even payv1200 for it what a scam….
        April 28, 2023 at 5:06 am
        Your not a target customer. Try to find a $1200 part that beats this.
      • Mark Lloyd
        May 14, 2023 at 6:56 am
        I agree whole heartedly with Stephen Livingstone . Please show me what better at this price point you mention of $1200 . I could be very wealthy with this knowledge you have but refuse to share . There are things on the 8.4 I don’t like but it’s made at a price point like so many things . So far the only thing you have shown us is a lack of knowledge of these products and the extreme genius of the people bringing this one to market
    • Mark Lloyd
      May 14, 2023 at 6:44 am
      I find it amazing. It opens doors to so many people to enjoy various formats of entertainment at home with very good stated power . Time will tell though . I hope it does well . Competition is needed in this market . As for your opinion LG I have know idea who you are and respect opposing opinions no matter how ridiculously uninformed they may be.
  2. chad jones
    August 16, 2023 at 1:44 pm
    A receiver with XLR preouts should justify the price, because not every one does that.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
