Integra DTR-40.5 and DTR-50.5 A/V Receivers
Integra DTR-50.5 A/V Receiver
Integra today announced two new THX Select2 Plus certified home theater receivers, models DTR-40.5 and DTR-50.5, which offer 4K Ultra HD video support, along with built-in Wi-Fi and Bluetooth. The Integra DTR-50.5 has a more powerful seven-channel 135-watts per channel power amplifier, compared to the DTR-40.5’s 7×110 wpc. The DTR-50.5 also has additional digital audio inputs, a differential DAC for the front channels, a programmable remote control, and the company’s exclusive Digital Processing Crossover Network. DPCN improves the performance potential of bi-amped stereo speakers by eliminating the crossover overlap between the high and low frequency signals to prevent high and low frequency sounds from bleeding into the wrong drivers.
With so many different wireless music source options available today, these receivers are designed to interface via Wi-Fi and Bluetooth to stream music from phones, tablets, and computers. With Integra’s Remote Apps for iOS and Android, users can push music to the AVR from phones and tablets. They can also playback high definition music files in FLAC, DSD, ALAC, HD 24/96 and HD 24/192 formats from HD music download services.
These networking features also provide access to the widest selection of audio streaming content such as that from Spotify, Pandora, Rhapsody, SiriusXM Internet Radio, Tune In and many others. The DTR-40.5 and DTR-50.5 also have a phono input and provide extensive support for legacy digital and analog sources.
On the video side, both receivers provide full support for the new 4K Ultra HD video displays, using either the 4K pass-through feature or upscaling for conventional HD video sources via a Marvel QDEO processor.
Other connection options include eight total HDMI inputs (7 rear-panel) with two outputs for connection to streaming services via Apple TV, Roku, Blu-ray players and other sources, a USB port, and an Ethernet connection. The Integra DTR-40.5 and DTR-50.5 include an array of modern and very useful video features, including InstaPrevue, which allows users to monitor multiple program sources with this HDMI variant of picture-in-picture. There is also Mobile High-definition Link (MHL), which uses the front-panel HDMI port to deliver HD video and up to 7.1 channels of audio from compatible Android smart devices and other products.
Integra DTR-40.5 A/V Receiver - back
DTR-40.5
Integra DTR-50.5 A/V Receiver - back
DTR-50.5
Sound quality is a key factor in Integra’s design process. The new Phase Matching Bass circuitry optimizes low frequencies while preserving mid-range clarity. It counters phase shifting — which can affect sound quality — by synchronizing the timing of different frequencies. The result is deep, well-defined bass that won’t overwhelm vocals or strings.
The amplifier sections employ the company’s three-stage inverted Darlington circuitry and Wide Range Amplifier Technology (WRAT) — a low negative-feedback topology for low distortion and high dynamic range.
In addition to the 7.1 channel Dolby True HD and DTS-HD Master Audio processing that is part of the HDMI spec, the DTR-40.5 and DTR-50.5 use Dolby Pro Logic IIz and Audyssey DSX to provide alternate surround option for front height and wide channels. Audyssey MultEQ is included for automated room setup using an included microphone. Audyssey Dynamic EQ and Dynamic Volume provide further sound enhancements.
Custom installers will appreciate the inclusion of Powered Zone 2 and Zone 2/3 preouts, two IR inputs and one output for remote control integration, and three 12-volt triggers. A bi-directional RS-232 port and Ethernet jack are available for connection to some home automation systems.
Price and Availability
The Integra DTR-40.5 and DTR-50.5 will be available in July 2013 with suggested retail prices of $1,300 and $1,700 respectively.
Integra DTR-40.5 A/V Receiver - front
DTR-40.5
Integra DTR-50.5 A/V Receiver - front
DTR-50.5
Specifications
DTR-40.5 DTR-50.5
Amplifier Section
Power Output (8 Ω, 20 Hz-20 kHz, FTC)
110W /Channel (8 Ω)Dynamic Power
250W /Channel (3 Ω)
220W /Channel (4 Ω)
130W /Channel (8 Ω)THD (Total Harmonic Distortion)
0.08% (Power Rated)Damping Factor
60 (Front, 1 kHz, 8Ω)
Input Sensitivity and Impedance
200 mV/47 kΩ(LINE)
2.5 mV/47 kΩ(Phono MM)
Rated RCA Output Level and Impedance
200 mV/470 Ω(Pre Out)
Maximum RCA Output Level and Impedance
4.6 V/470 Ω(Pre Out)
Frequency Response
5 Hz–100 kHz/ +1 dB-3 dB
(Direct Mode)
Tone Control
±10dB, 50 Hz(BASS)
±10dB, 20 kHz(TREB)
Signal to Noise Ratio
106 dB (LINE, IHF-A)
80 dB (PHONO MM, IHF-A)
Speaker Impedance
4 Ω–16 Ω
Power Consumption
6.9 A
No-Sound Power Consumption
80 W
Stand-by Power Consumption
0.1 W
Dimensions (W X H X D)
17 1/8″ x 6 7/8″ x 12 7/8″
435 × 174 × 326.5 mm
Weight
25.1 lbs. (11.4 kg)
Carton Dimensions (W X H X D)
22 7/16″ x 11 3/4″ x 18 7/16″
570 x 298 x 469 mm
Weight
32.0 lbs. (14.5 kg)
Amplifier Section
130W /Channel (8 Ω)Dynamic Power
300W /Channel (3 Ω)
250W /Channel (4 Ω)
150W /Channel (8 Ω)THD (Total Harmonic Distortion)
0.08%(Power Rated)Damping Factor
200 mV/47 kΩ(LINE)
Frequency Response
(Direct Mode)
Tone Control
±10dB, 50 Hz(BASS)
±10dB, 20 kHz(TREB)
Speaker Impedance
4 Ω–16 Ω
Power Consumption
8.1 A
85 W
0.1 W
17 1/8″ x 7 13/16″ x 15 5/6″
435 × 198.5 × 388.5 mm
Weight
33.1 lbs. (15.5 kg)
22 7/16″ x 13 1/16″ x 20″
570 x 331 x 508 mm
Weight
40.8 lbs. (18.5 kg)
Integra RC-869M Remote for DTR-40.5
Integra RC-841M for DTR-50.5
RC-841M Remote for DTR-50.5
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
After a five year hiatus, Sony is back with new A/V receivers optimized for home theater and immersive surround sound.
JBL raises the bar for affordable stereo and home theater performance with stylish lines of A/V receivers and matching loudspeakers.
Denon and Marantz enable HDMI 2.1 in their top-of-the-line A/V receiver and preamplifier/processor for 2021.
