Integra DTR-30.1 and DTR-20.1 AV Receivers
Integra has introduced two mid-priced audio-video receivers designed to provide state-of-the-art home theater performance plus sophisticated integration with home automation systems. The new Integra DTR-30.1 and DTR-20.1 are, respectively, 7.2- and 5.2-channel, two-zone AV receivers designed for modern high-definition audio and video systems. In addition, the DTR-30.1 is the first Integra A/V receiver that incorporates the new Dolby ProLogic IIz which lets installers offer their clients engaging sonic ambience in three dimensions, not just two.
Both receivers use the latest HDMI 1.3a connection technologies with full support for 1080p video, Deep Color, x.v. Color, and high definition sound via Dolby TrueHD and DTS-HD Master Audio. The Integra DTR-30.1 has six HDMI inputs, including a front-panel input, while the DTR-20.1 has four HDMI inputs. The DTR-30.1 also features Faroudja DCDi Edgea¢ based upscaling of all video sources to 1080i via the HDMI output. These receivers each deliver 90 Watts per channel of amplification into 8 Ohms, and include processing for every major digital audio format in use today, as well as a full suite of audio technologies from Audyssey.
“These new Integra receivers represent a great value for systems integrators and end users,” said Keith Haas, Integra’s Director of Sales. “They offer great sound and video performance at a reasonable price, and they offer outstanding second zone capabilities and home automation integration. Plus, as the first Dolby PLIIz-enabled products designed for custom installation, they give dealers a big step forward in the capabilities they offer their clients.”
Each of the receivers feature Audyssey 2EQ automatic calibration system, which corrects each channel’s output in both frequency and time domains based on measurements at three unique listening positions. Additional features include Audyssey Dynamic Volume technology, which optimizes the dynamic range of listening material at any listening level, and Audyssey Dynamic EQ, which corrects problems associated with reduced sound quality at low listening levels.
The Integra DTR-30.1 and DTR-20.1 each include a wide range of features specifically tailored to the needs of custom installers, including bi-directional RS-232 and Ethernet ports for third party control systems, three programmable 12-volt triggers, dual IR inputs, and three unique assignable IR code sets. They have extensive multizone / multisource features, including Zone 2 fixed and variable line outputs with independent Bass/Treble and balance controls. The DTR-30.1 also features the company’s Powered Zone2 capability, which allows two of the unit’s seven main amplifiers to be used for Zone 2 amplification while still enjoying 5.1-channel surround sound in the main zone. Additionally, these amplifier channels can be reconfigured for bi-amplification of the front left and right audio channels when used with compatible high-end speakers.
These Integra receivers are the first to use the company’s new proprietary rear-panel universal port, which simplifies the connection of forthcoming add-on modules, such as an HD Radio Tuner and iPod Dock. Each receiver also uses the company’s discrete-component Wide Range Amplifier Technology (WRAT), and features dual line-level subwoofer outputs.
For the majority of dealers, who also install these receivers in the customer’s home, the DTR-30.1 and DTR-20.1 includes the ability to independently store custom settings, reducing setup and support times. An optional rack mount kit is available for applications where rack mounting is desirable.
The Integra DTR-30.1 and DTR-20.1 surround receivers are currently available at suggested retail prices of $800 and $600 each, respectively.
Integra designs and manufactures premium Home Theater receivers, processors, amplifiers, and DVD players that are specifically designed to meet the needs of custom audio/video systems installers. Systems integration and convergence technology protocols include RS-232, IR and on-board Ethernet for network connectivity and TCP/IP control. Integra has access to vast technical resources, and bears a proud heritage of 60 years of audio engineering excellence.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $899, the Integra DTM-7.4 offers custom installers a convenient way to connect a powerful stereo receiver into a smart home system.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
2023 A/V Receiver firmware update enables Klipsch Optimized Mode along with improvements for both custom installers and gamers.
At $3,200, Integra's flagship home theater receiver offers 11 x 150-watts of power, Dirac Live, and 8K pass-thru along with extra features for custom...
Integra today announced the DTM 40.7 Network Stereo Receiver featuring low-impedance and high-current performance, along with advanced custom installation features, plus wireless connectivity. The...
Integra announced the new mid-range DHC-60.5 THX Ultra2 Plus Certified A/V Preamplifier/Processor with support for HDBaseT technology, that allows HD audio/video signals to be...
