Integra DRC-R1.1 Flagship THX Ultra A/V Preamp Adds 4K HDBaseT
Integra DRC-R1.1 11.2-channel THX Ultra Dolby Atmos DTS:X A/V Preamplifier with 4K HDBaseT
11.2-channel Home Theater Preamp/Processor Adds 4K HDBaseT Support
Integra today announced two flagship home theater components to their reference-grade Research Series that will be available March 2018. The new models include the DRC-R1.1 11.2-Channel THX Ultra A/V Preamplifier and the DRX-R1.1 11.2-Channel THX Select A/V Receiver that is almost the same but includes amplifiers. Both are the first products in their respective categories to incorporate 4K HDBaseT circuitry which allows for the transmission of 4K/60fps/ 4:4:4/UHD/HDR-10/Dolby Vision content up to 100 meters away over Cat 5/6/7 wiring. Each new “dot 1” model succeeds the DRC-R1 and DRX-R1 (without the “dot 1”) that are nearly identical without 4K HDBaseT support.
Additionally, both units support Dolby Atmos and DTS:X formats up to 7.2.4 channels; multi-zone processing; wireless technologies such as Chromecast built-in with Google Assistant voice control and DTS Play-Fi multi-room hi-fi music streaming; and hand-selected components. Each model also includes 8 HDMI in (1 Front*1), main out, and sub / Zone 2 out with support for HDCP 2.2, 4 K / 60 Hz, Dolby Vision, HDR 10, HLG (Hybrid Log-Gamma), WCG (Wide Color Gamut), extended (sYCC601, Adobe RGB, Adobe YYC601), and BT.2020 video pass-through.
Integra DRC-R1.1 A/V Preamplifier Processor Front View
Integra DRC-R1.1 A/V Preamplifier Processor Controller Back View
With the THX Certified Ultra DRC-R1.1, no detail is overlooked. From the copper screws used to lock modular circuitry blocks to a double-skinned insulated frame, additional internal bracing to enhance the products anti-resonant characteristics, to the floating circuit boards, multiple 32-bit DSPs and DACs, the DRC-R1.1 processor was built for theater-reference sound. It includes state-of-the-art front-end technologies such as the 4K HDBaseT support, and object-based audio processing through 7.2.4 channels, and features gold-plated 11.2-channel balanced XLR audio pre-outs. The unit has 32-bit SHARC DSPs (x3), independent differential audio DACs for Stereo Front L / R (384 kHz / 32-bit AK4490) and Surround (768 kHz / 32-bit AK4458), and separate DACs for Zone 2 for HDMI IN 1-5, SPDIF (PCM), NET, and USB sources, and Zone 3 for NET and USB Sources. Bi-directional IP and RS-232 port for advanced home automation control systems are onboard, as are two IR inputs / one output, and three programmable 12V trigger outputs with adjustable delay.
Integra DRX-R1.1 A/V Preamplifier Inside Top View
Price and Availability
The Integra DRC-R1.1 11.2-Channel Network A/V Preamplifier/Processor Controller will be available for $2,500 US ($3,500 CAN) March 2018.
Integra RC-913R Remote Control
Advanced Features
  • THX Certified Ultra for Theater Reference Sound
  • Enhanced HDBaseT LAN Connection Supporting HDCP 2.2-compliant 4 K / 60 Hz / 4:4:4 Video Transmission and POC (Power Over Cable) in Combination with Optional HDB-RX1 HDBaseT Receiver, IR and RS-232C Control
  • Supports Dolby Atmos and DTS:X Formats Up to 7.2.4 Channels
  • HDMI 8 In (1 Front*1), Main Out, and Sub / Zone 2 Out with HDCP 2.2, 4 K / 60 Hz, Dolby Vision, HDR 10, HLG (Hybrid Log-Gamma), WCG (Wide Color Gamut), Extended Colorimetry (sYCC601, Adobe RGB, Adobe YYC601), and BT.2020 Video Pass-through
  • AccuEQ Auto Speaker Calibration Technology with Standing Wave Elimination and User-Definited Customizable Filters
  • AccuReflex Phase Alignment Technology for Dolby Atmos-enabled Speakers
  • Chromecast bulit-in Wireless Audio Platform and Google Assistant Voice Control Support
  • DTS Play-Fi Multi-room Hi-Fi Music Streaming Capability
  • AirPlay Audio Streaming from iTunes and iPad, iPhone, and iPod touch
  • Spotify Connect, TIDAL, TuneIn, Pandora, and Deezer Services*2
  • FlareConnect*3 Multi-room Network and Analog Wireless Audio Distribution to Compatible Components and Speakers
  • Integra Control Pro App for iOS and Android Devices*4 Enables Easy Initial Setup, Multi-room Management, and System Control
  • Plays Hi-Res Audio Files Including DSD Direct 11.2 MHz Stereo, 192 / 24 PCM, Dolby TrueHD*5, FLAC, WAV, ALAC, AIFF, MP3, and AAC via Network and USB Input
  • 192 kHz Audio Scaling and Upsampling Mode for Wider Dynamic Range and Enhanced Detail Resolution
  • Direct Mode for Audio Reproduction Close to Original Source Quality
*1 Front HDMI Input does not support 4K/60p, Dolby Vision, HDR10, BT.2020, or HDCP 2.2.
*2 Availability of services may vary with region. Please confirm before purchase. Subscription may also be required.
*3 Requires firmware update.
*4 For iOS and Android devices. Please check App Store or Google Play for device and OS requirements.
*5 Dolby TrueHD playback via USB input only.
Other Features
  • Dual-skin Insulated Chassis with Exclusive Cross-bracing System
  • Additional Anchor Points for Outer Chassis
  • Custom-made Magnetic-flux Low-Hum EI Power Transformer, Fully Enclosed and Shielded for Minimal Leakage
  • Floating Isolated Digital Processing Boards with Separate Shielded Power Supply
  • Hand-selected Audio-tuned Parts with Conductive Copper Chassis Screws
  • Extra-large Anti-Standing-Wave Insulator Feet Improve Sound Localization and Tone Response
  • Class-leading Processing System Featuring 32-bit SHARC DSPs (x3), Independent Differential Audio DACs for Stereo Front L / R (384 kHz / 32-bit AK4490), Surround (768 kHz / 32-bit AK4458), and Separate DACs for Zone 2 / Zone 3 (192 kHz / 24-bit AK4388)
  • VLSC (Vector Linear Shaping Circuitry) High-frequency Noise Filtering (All Channels)
  • PLL (Phase Locked Loop) Jitter-cleaning Circuitry for S/PDIF Audio
  • A/V Sync Control (-100 ms to +500 ms in 1 ms Steps at 48 kHz)
  • Crossover Adjustment for Each Channel (40 / 45 / 50 / 55 / 60 / 70 / 80 / 90 / 100 / 110 / 120 / 130 / 150 / 180 / 200 Hz)
  • Audiophile Grade Anti-Resonant Aluminum Front Panel
  • 40 FM / AM and Internet Radio Random Presets with Station Naming
  • Sleep Timer, HDMI Passthrough, and Network Standby
  • 5 Digital Audio Inputs (3 Optical and 2 Gold-plated Coaxial, Assignable)
  • 7 Gold-plated Analog Audio Inputs (RCA)
  • Gold-plated Phono Input (MM) for Turntable Connection
  • 2 Gold-plated Composite Video Inputs
  • 2 Gold-plated Component Video Inputs and 1 Gold-plated Output
  • USB Input (5 V / 1 A) for Audio Playback
  • Gold-plated 11.2-Channel Balanced XLR Audio Pre Outs
  • Gold-plated 11.2-Multichannel Pre Outs
Custom Integration Features
  • Zone 2 HDMI Output for HDMI Inputs 1–5 with Matrix Switching, Zone 2 OSD Including Volume Bar Overlay, Network Service Selection, and More
  • Bi-directional IP and RS-232 Port for Advanced Home Automation Control Systems
  • 2 IR Inputs and 1 Output
  • 3 Programmable 12V Trigger Outputs with Adjustable Delay (A: 100 mA, B: 25 mA, C: 25 mA)
  • Zone 2 and Zone 3 Pre- / Line Outputs, Front L / R Bi-amping Capability
  • Zone 2 DAC for HDMI IN 1-5, SPDIF (PCM), NET, and USB Sources
  • Zone 3 DAC for NET and USB Sources
  • One-touch Whole House Mode for Easy Distribution of Any Audio Source to All Three Zones
  • Dealer Settings Memory Store and Recall
  • Remote Play Zone Function Enables Zone Selection for Audio Playback via Chromecast built-in, AirPlay, Spotify Connect, and DMR (Digital Media Render) Smartphone
  • Front Panel Lock / Unlock and IR Lock / Unlock Capability
  • Reset Function, Firmware Updates, and Temperature Based Fan Control via 3rd Party Control Systems
  • Firmware Updates via ISCP for Dealers and Installers
  • Independent Bass / Treble / Balance Controls for All Zones
  • Optional Rack-Mount Kit Available (IRK-180-4C)
1 Comment
1 Comment
  1. Richard
    October 19, 2022 at 7:24 am
    Am about to buy one want to know the don’t and cons
HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
The Case for Audio/Video Receivers (AVRs) While soundbars have evolved over the years and can provide a convenient solution to better TV sound, nothing beats a...
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
A curated Baker’s Dozen of the best new and reissue albums of 2025, with expert insight and links to full reviews.
Most soundbars promise Dolby Atmos and deliver disappointment. These are the rare models that actually sound convincing and are worth recommending in 2025.
Our Best of 2022 Soundbar picks feature some great options from Sony, Polk, Sonos, Samsung, and Vizio for every budget.
The best soundbars are now competitive with component based surround systems. Here are our current favorites.
Yes’ Fly From Here: Return Trip lands with cleaner Dolby Atmos and 5.1 mixes, offering more definition and space than fans expected from this...
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
