Hard Drives
INOi HD363N 3.5 Aluminum Network Hard Drive Enclosure with Bult-in FTP and SAMBA Servers
Attention small businesses and workgroups! You’re about to enter the next dimension in file sharing where you’re fully quipped to play with the big boys! Introducing INOi’s HD363N Network Hard Drive Enclosure – a combination FTP and Samba server that offers a range of file sharing options usually associated with much larger businesses. You can use this powerful yet inexpensive network drive enclosure to share files among PCs to achieve remote data backup. You can use the INOi HD363N for wireless file sharing when used with a wireless network bridge.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
