InFocus Corp. announced the addition of the IN5120 series of projectors, featuring the IN5122 (XGA, 1024 x 768) and IN5124 (WXGA, 1280 x 800) models. Offering life-like colors and a deep grayscale depth due to inorganic LCDs, the IN5120 series provides organizations of all sizes high-performance projection and impressive connectivity and collaboration features at a remarkably low price.
Simplified Installation and Maintenance
The IN5120 series provides affordable LCD capability that is easy to install and maintain in a wide range of conference rooms, training rooms and classrooms. The IN5122 and IN5124 can be easily installed on a wall or ceiling. Their low profile design makes them easy to use on tables or media carts so they can be easily moved for flexibility and cost effectiveness. Horizontal and vertical lens shift along with corner correction allow the IN5120 series to project crisp, square images in nearly any room.
With 4,000 lumens, the new IN5120 series creates bright, high impact images up to 110 diagonal inches (2.79 m) even in well lit rooms. Plus, two IN5120 projectors can be stacked on top of each other for nearly twice the lumens. A single-lamp design and easily accessible lamp door make the IN5110 easy and economical to maintain. The latest inorganic LCD technology and up to 5,000 hour lamp life, offer years of worry-free operation.
Flexibility to Personalize and Collaborate
The IN5120 series makes it possible to collaborate with colleagues and classmates around the world. Remote workers don't need to be confined by four walls to present in a meeting. Simply connect the projector to your established network and anyone on that network can present. The IN5120 series also allows users to simply plug in a USB thumb drive to present without a computer. Plus, custom start-up screens allow companies to reinforce brands internally and create targeted messaging in specific rooms throughout any facility.
The IN5120 series makes integration with most professional room and media control systems flawless, and allows users to personalize the projector for specific business or educational needs. Assignable audio and 5 BNC inputs provide installation flexibility. Plus, the series' RS232 port allows connection to Creston, AMX, SPcontrols or any other room control system, and an RJ45 port allows users to interface with any network control systems.
“Projection technology doesn't have to be complicated or expensive,” said Benjamin Joy, product line director at InFocus. “We offer this projector series for organizations that want the flexibility and quality of a high-end projector without the large price tag.”
Availability
Both projectors are available now for:
