iFi’s iDSD Valkyrie Wants to Be Your Guide to Musical Valhalla
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
iFi iDSD Valkyrie Portable DAC Amplifier
Schiit Audio might own the floor when it comes to its usage of Norse mythology in the naming of its products, but they’ve never offered anything like the iFi iDSD Valkyrie DAC/Headphone Amplifier. And probably never will. It’s a rather large ask of this portable to deliver on its namesake; the Valkyrie had the honor of guiding dead souls to Odin’s Valhalla, where if they were lucky, the deceased warriors became einherjar and prepared for the forthcoming Ragnarok. Schiit’s Ragnarok 2 Integrated Amplifier also includes a DAC and balanced headphone amplifier but that’s where Thor and Loki go their separate ways.
iFi iDSD Valkyrie Portable DAC Amplifier Front
Quad-DAC Architecture and aptX Lossless and LDAC
The iDSD Valkyrie is built around four Burr-Brown DACs in a hybrid multi-bit configuration, drawing from iFi’s long-standing experience with the multi-bit Philips TDA1541A. This design captures the impact of the iconic multi-bit chipset, but with superior low-level linearity for state-of-the-art detail retrieval.
For those looking to stream from a DAP or use wireless headphones like the Focal Bathys or DALI IO-12, iFi has equipped Valkyrie with the latest flagship Qualcomm chipset to deliver CD-quality audio via aptX Lossless, and hi-res playback via LDAC.
iFi iDSD Valkyrie Portable DAC Amplifier Rear
Portable Power
One of the knocks against portable DAC/headphone amplifiers is that they don’t offer enough power to drive the most difficult dynamic and planar magnetic headphones without compromising on battery life and overall performance. The iFi iDSD Valkyrie delivers approximately 44% more power than iFi’s flagship, the iDSD Diablo 2 when driving current-hungry 16 Ohm headphones, and up to 5,700mW peak output power – or 2,258mW RMS
xMEMS Support
The iDSD Valkyrie supports IEMs (In-Ear Monitors) using xMEMS, an innovative speaker technology pushing the boundaries of headphone performance. xMEMS speaker technology implements both actuation and diaphragm in silicon producing the world’s fastest and most precise speakers for IEMs. With these next-generation speakers, there’s virtually no phase shift and they are close to 150 times faster than regular mechanical drivers.
Colossal Capacity, Silent Stability
To power all its advanced features, the Valkyrie requires a serious battery configuration. Under the chassis are four 5,000mAh lithium-ion batteries, totalling 20,000mAh. Not only do the batteries provide sound free from electrical interference and noise, but they do so with enough life to last up to 18 hours of playback on a single charge. Fast charging via USB-C means the Valkyrie takes just 2.5 hours to recharge.
iFi iDSD Valkyrie DAC/Headphone Amplifier Front Right
Features:
  • K2HD Technology
  • DSD 1024 Remastering: High-performance FPGA professionally remasters audio to DSD512 or DSD1024.
  • Quad DAC Architecture: Four interleaved Burr-Brown DACs with superior low-level linearity.
  • 5,700mW Peak Output: Delivers formidable power for driving the most demanding headphones.
  • Lossless Bluetooth and xMEMS Support: Delivers CD-quality Bluetooth via aptX Lossless and next-gen driver compatibility for ultra-fast, precise sound.
  • 20,000mAh Battery: 18 hours of continuous playtime, with fast charging via USB-C in just 2.5 hours.
iFi iDSD Valkyrie DAC/Headphone Amplifier Top
Specifications
iFi Model iDSD Valkyrie
Product TypeDAC/Headphone Amp
Price$1,699
Hi-Res Audio SupportPCM 768kHz, DSD512
Bluetooth FormatsaptX Lossless, aptx Adaptive, LDAC, LDHC.HWA, AAC, SBC
Digital Inputs1 x USB-C,
1 x S/PDIF (optical, coaxial),
Bluetooth ver 5.4
Analog Inputs1 x Balanced 4.4 mm,
1 x 3.5mm
Headphone Outputs1 x Balanced 4.4 mm,
1 x S-Balanced 3.5mm
Line Outputs1 x Balanced 4.4 mm,
2 x 3.5mm,
1 x RCA
Power/Charging1 x USB-C
Headphone Output Impedance< 0.3 ohms via 4.4mm,
< 0.2 ohms via 3.5mm
Output Power (4.4mm – RMS)>19.6V/640mW (@600 ohms)
>12.0V/2.250mW (@64 ohms)
Output Power (3.5mm – RMS)>9.8V/160mW (@600 ohms)
>8.5V/2.258mW (@64 ohms)
xMEMS>28Vpp (4.4mm output)
Line Output Impedance205 ohms via 4.4 mm,
105 ohms via 3.5 mm RCA
SNR (Signal-to-Noise Ratio)116dB (A-Weighted)
DNR (Digital Noise Redution)116dB (A-Weighted)
THD+N (Total Harmonic Distortion Plus Noise)0.002% (20-20kHz)
Power ConsumptionNitro 13W,
Turbo 6.5W,
Normal 3.5W,
xMEMs 6.1W
BatteryLithium-Polymer 20,00mAh
ChargingVia USB-C – QC3.0 #20V, QC2.0@5-12V
Charging Time2.5 hours @ 20V,
4 hours @12V,
5 hours @ 9V,
8 hours @ 5V
Dimensions172 x 160 x 30 mm
(6.77 x 6.3 x 1.2 inches)
Net Weight882 grams (1.94 lbs)
iFi iDSD Valkyrie Portable DAC Headphone Amplifier Bottom
The Bottom Line
With support for LDAC, aptX Lossless, and the ability to drive IEMs that use xMEMS drivers, the iFi iDSD Valkyrie is definitely ahead of the curve right now and we’re very impressed by the output and reported battery playtime. Those are impressive numbers on paper.
Will consumers spend $1,699 on a portable DAC/headphone amplifier is the real question and will they be open to carrying around a 2 pound component?
We shall find out in rather short order. Review forthcoming.
iFi iDSD Valkyrie Portable DAC Headphone Amplifier Lifestyle
Price & Availability
The iFi iDSD Valkyrie is available now for $1,699 at Audio46, and internationally with pricing at £1,699 or €1,699.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Podcasts
In celebration of Shure's 100th Anniversary, company historian Michael Pettersen reveals how music, entertainment and culture have been shaped by Shure.
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
With a 120 Hz OLED panel, perfect blacks and an affordable price, LG's B4 may be the value pick for price-conscious TV buyers right...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
Podcasts
Nick Brown, SVS VP of Marketing reveals some surprising ways to get better sound from your hi-fi and home theater system, and gear you...
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
