Digital Music Systems
iFi ZEN Stream Offers Plug and Play Operation & Spotify and Tidal Connect
The iFi ZEN Stream is a rather comprehensive and flexible solution for hi-res streaming with support for Tidal and Spotify Connect.
iFi ZEN Stream
If you thought the Dongle DAC wars were getting competitive, iFi just made the digital music streaming category a lot more interesting. The iFi ZEN Signature lineup is currently on my desk under review and the one thing missing was a hi-res streamer that worked with both Tidal Connect and Spotify Connect. Enter the new iFI ZEN Stream.
The iFi ZEN Stream connects to a router via Wi-Fi or Ethernet cable, and outputs to an external DAC (or an amp with digital inputs) via USB or S/PDIF. It utilizes an open-source architecture making it flexible and future-proof…mostly.
iFi ZEN Stream with ZEN DAC Front Lifestyle
iFi ZEN Stream (top), iFi ZEN DAC V2 (bottom)
The iFi ZEN Stream is a rather comprehensive and flexible solution in one rather small box. Its open-source architecture ensures the user is not tied to a specific platform or app, offering a wealth of options and the ability to add more via programmable firmware.
Its Linux-based operating system offers flexibility, with the streaming community encouraged to work with iFi to create additional features to add down the line via OTA (Over The Air) updates.
The ZEN Stream’s hi-res audio includes support for PCM up to 32-bit/384kHz and DSD up to 11.2MHz (DSD256) over Wi-Fi, as well as over Ethernet cable.
iFi ZEN Stream with ZEN DAC Rear
iFi ZEN Stream (top), iFi ZEN DAC V2 (bottom) rear view
Digital inputs include a USB-A input, giving the option of playing music from HDD and solid-state storage devices, and a USB-C programming port to upload software/firmware updates (an alternative to OTA updates via Wi-Fi).
2 digital outputs – asynchronous USB and coaxial S/PDIF – provide connection to an external DAC or amp with digital inputs. Both these outputs are regulated by iFi’s femto-precision GMT (Global Master Timing) clock circuitry to eradicate jitter from the digital signal.
The USB ports – both input and output – support USB 3.0 and use iFi’s ANC II active noise cancellation to remove distortion from the audio signal.
The iFi ZEN Stream also includes the following features:
  • Integrated Tidal Connect and Spotify Connect: Users of these online music services can stream directly from the Tidal and Spotify apps
  • DLNA certification: Any DLNA-compatible streaming app – including iFi’s forthcoming Stream-iFi app – can be used to control the ZEN Stream and access audio content from online services and DLNA-certified network storage devices.
  • AirPlay and Chromecast: Integrated Airplay and Chromecast ensures easy streaming from Apple and Android devices. AirPlay is included at launch; Chromecast will be added as a free firmware update later this year.
  • Roon compatibility: At launch, the ZEN Stream is compatible with Roon Bridge software, making in suitable for a Roon environment, and full Roon Ready certification is in the pipeline – a tempting proposition given the ZEN Stream’s affordable price point. With the ZEN Stream, you can add Roon compatibility to any DAC on the planet.
  • NAA operation: The ZEN Stream can operate as an NAA (Network Audio Adapter) in conjunction with Sygnalist HQPlayer software – favoured by many serious music streaming enthusiasts. This means it can direct packets of audio data received over Wi-Fi or Ethernet cable straight to the connected DAC without applying any processing whatsoever.
The iFi ZEN Stream is a logical addition to any iFi ZEN or ZEN Signature desktop system and we can’t wait to review this very affordable network streamer that looks to offer almost anything one could need.
For more information: TBA
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
A Wireless and Bluetooth network player that does both TIDAL Connect and Spotify Connect? The $99 Wiim Mini has us very intrigued.
