iFi ZEN One Signature DAC Offers Bluetooth Connectivity
The iFi ZEN One Signature DAC strips out the volume control and headphone amplifier for a dedicated hi-res DAC with Bluetooth support.
iFi has been exceptionally busy over the past 2 years updating its existing product lineup and introducing a myriad of portable options for your iPhone or Android smartphone. The iFi ZEN Series has been a huge hit so far; although my experience with the ZEN CAN Signature 6xx has been one of the few disappointments so far in many years with their products.
The iFi ZEN One Signature DAC looks to be a no-compromise desktop DAC with support for hi-res streaming and support for every Bluetooth codec with the exception of Bluetooth aptX Lossless which was announced in Q4 2021.
iFi ZEN One Signature DAC Angle
Described as a ‘universal DAC’ owing to its all-encompassing input options, the ZEN One Signature takes the DAC stage from the ZEN DAC V2, adds S/PDIF inputs (optical and coaxial) alongside the USB port, stirs in Bluetooth technology from the ZEN Blue V2 ($189 at Crutchfield) and seasons the pot with signature-grade circuit enhancements to create a desktop DAC solution for $349 USD.
The result is a pure DAC (no built-in headphone amp or volume control) that serves as a home audio hub for all your digital devices, from smartphones and tablets to PCs and Macs, disc players and audio servers to TVs and games consoles.
The ZEN One Signature’s singular purpose is to take the digital audio signal from any device, via cable or Bluetooth, and convert it to analogue to feed an external amp and speakers (or headphones).
iFi ZEN One Signature DAC front closeup
The ZEN One Signature’s ‘digital engine’ is based around a Burr-Brown DAC chipset that iFi uses extensively. One such critical component is the XMOS chip that processes the audio data received via the USB and S/PDIF digital inputs.
The ZEN One Signature uses a low-latency, 16-core XMOS microcontroller delivering enhanced processing power; iFi’s in-house digital development team has programmed the XMOS firmware to optimise sound quality and ensure a perfect partnership with the Burr-Brown DAC.
Extensive jitter-eradication technologies are also applied to the digital stage, including the latest generation of iFi’s GMT (Global Master Timing) femto-precision clock and intelligent memory buffer.
The ZEN One Signature’s hi-res audio credentials encompass 32-bit/384kHz PCM over USB (192kHz over S/PDIF), all levels of DSD to DSD256, and single- and double-speed DXD. Thanks to the Burr-Brown DAC chip’s four-channel True Native design, PCM and DSD take separate pathways – this enables DSD, as well as PCM, to remain ‘bit-perfect’ in its native form right through to analogue conversion.
iFi ZEN One Signature DAC Front
MQA – the hi-res streaming format – is also supported, with full decoding of MQA files up to 384kHz. This means that the complete ‘three unfold’ decoding process is performed internally, as opposed to just the final unfold in the manner of an MQA ‘renderer’ – ideal for subscribers to Tidal’s ‘HiFi Plus’ tier, where Tidal Masters (MQA) content can be found.
Bluetooth done better
While Bluetooth’s wireless convenience and wide device compatibility is well recognised, many people don’t realise how good Bluetooth audio can sound because they’ve only experienced it at base-level quality via rudimentary SoC (System on Chip) implementations. iFi has gone to great lengths to ensure its Bluetooth technology is state-of-the-art, earning it a class-leading reputation.
Making full use of Qualcomm’s latest four-core QCC5100 Bluetooth processing chip, every current high-definition Bluetooth audio format is supported, including aptX Adaptive and aptX HD, LDAC and HWA/LHDC.
Other codecs covered include regular aptX and aptX Low Latency, AAC and SBC (the ‘plain vanilla’ Bluetooth codec). This means that every possible source device is handled at the highest audio resolution its Bluetooth specification allows.
The ZEN One Signature is Bluetooth v5.1-compliant, ensuring the best possible range, stability and performance. Up to eight paired Bluetooth source devices can be stored in memory, making it easy to switch from one device to another.
Connectivity Options?
iFi ZEN One Signature DAC Back
Around the back resides an asynchronous USB Type B port, alongside two S/PDIF inputs – optical and coaxial, the latter doubling as a digital output. RCA analog outputs are joined by a balanced 4.4mm output, enabling fully balanced connectivity with a suitably equipped amplifier. iFi makes a balanced 4.4mm to stereo XLR cable, ideal for connecting the ZEN One Signature to an amp with XLR inputs.
For more information: ifi-audio.com
Where to buy: $349 at Audio46 | Amazon
2 Comments
2 Comments
  1. OldRoadToad
    January 16, 2022 at 3:18 pm
    The inclusion of “The FARCE”, i.e., MQA means that I and many others will never give in to Emperor Bob’s “Snark side of The FARCE”.
    Too bad as it looks to be otherwise excellent. I am not going to pay Uncle Blob because he cornvinced a company to include his BS. Even if I NEVER use it to unfold Uncle Bob’s dirty laundry I will have paid him to have it there, via licensing.
    To Hades with that, LOL!
    ORT
    • Ian White
      January 16, 2022 at 4:54 pm
      MQA is not my thing. I rarely use it when listening to TIDAL.
      I doubt that 99% of the population have ever heard of it or would understand what is does.
      Ian White
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
