iFi GO pod Converts Wired IEMs Into Wireless Earbuds: AXPONA 2023
The iFI GO Pod appears to be a rather viable methodology for turning your favorite pair of wired IEMs into wireless earbuds. What makes it unique? Read on.
iFi Go Pod
Does anyone take a day off at iFi Audio? Nobody takes one here either so I guess we are in good company. The British manufacturer has flooded the market with a wide range of portable DACs/headphone amplifiers, desktop amplifiers, and Dongle DACs over the past 12 months and this might be one of their most interesting releases yet. The iFi GO pod appears to be a rather viable methodology for turning your favorite pair of wired IEMs into wireless earbuds.
How Does the iFi GO Pod Work?
Using a pair of GO pods is simple. First, detach the cable from your favorite IEMs and connect the earpieces to the left and right pods. Then, pair the pods with your source device (a smartphone, for example) and hook the ergonomically designed ear loops behind your ears to ensure a comfortable fit… the result is an unrivalled TWS (True Wireless Stereo) headphone sound.
iFi Go Pod with 64 audio U4s Around the Ear
To launch the GO pod, iFi is partnering with some of the world’s finest manufacturers of high-performance IEMs to make curated ‘GO Pod + IEM’ packages.
Spanning both new and established models from 64 Audio, Craft Ears, Meze Audio, Symphonium and Westone, these special collaborations have produced six world-class pairs of TWS in-ear headphones.
Related product: Shure True Wireless Secure Fit Adapter Gen 2
Hi-fi separates for your ears
True wireless earbuds – even the more expensive ones – rely on SoC (system on a chip) solutions to integrate the requisite tech into a tiny space. From a high-performance audio point of view, this is not ideal; amalgamating critical stages such as Bluetooth decoding, digital-to-analogue conversion and amplification saves space and reduces cost, but compromises sound quality.
The iFi GO pod is distinctly different. Each of these critical stages is designed separately and optimised individually to ensure excellent sound quality – like an audio system made from individual hi-fi components. In addition, much like top-level hi-fi speakers, high-quality corded IEMs are engineered for sonic excellence, combining multiple high-tech drive units to transmit sound directly into your ear canal.
Connect a pair of these IEMs to the GO pods and it’s no wonder that the resulting sound is so much better than regular true wireless earbuds.
iFi Go Pod Right
Bluetooth
iFi has gone to great lengths to ensure its Bluetooth technology is state-of-the-art throughout its product range, earning it a class-leading reputation. The GO pod continues this uncompromising approach, including certification for Qualcomm’s Snapdragon Sound platform and Bluetooth 5.2 for optimum range, speed and reliability.
Bluetooth processing is handled by Qualcomm’s top-tier QCC5144 module, with its 32-bit, quad-core architecture and low power draw delivering excellent wireless audio performance whilst minimising drain on the GO pod’s battery.
As always with iFi’s Bluetooth audio devices, the GO pod is compatible with an impressive array of high-quality Bluetooth formats. LDAC and LHDC (HWA) are both supported to their maximum32-bit/96kHz specifications, with LDAC’s highest 990kbps bitrate available to users of Android devices that support Snapdragon Sound (660kbps with other LDAC-enabled devices).
Qualcomm’s 24-bit aptX HD and aptX Adaptive formats are also covered, offering sample rates of up to 48kHz and 96kHz respectively, with the additional benefit of QHS (Qualcomm High Speed) providing an extra 300kbps of bandwidth.
Other supported codecs include aptX Low Latency, regular aptX, AAC and SBC. This means that every possible source device is handled at the highest audio resolution its Bluetooth specification allows. Another Qualcomm technology enabled in the GO pod is TrueWireless Mirroring.
Although appearing as a single device when paired, both the left and right pods can receive Bluetooth signals – but only the one with the strongest connection acts as the receiver while the other mirrors the connected pod.
If the listener moves position and the connection to the mirroring pod becomes stronger, they swap over so the mirroring pod becomes the receiver without interrupting the audio signal. Similarly, if the receiving pod is removed from the listener’s ear, the other pod becomes the receiver, ensuring a seamless true wireless stereo experience.
iFi Go Pod IEM Combos
The DAC
In addition to Bluetooth processing, Qualcomm’s QCC5144 chipset can be configured to perform digital-to-analogue conversion and headphone amplification too – but this is not the iFi way.
Though more complicated and costly to design, the sonic benefits of separate, individually optimised DAC and amp stages are far more valuable to iFi than the savings made by one-chip-does-all solutions. To that end, the GO pod incorporates two Cirrus Logic MasterHIFI chips – one in the left pod, the other in the right.
This 32-bit hi-res DAC chip is dedicated to single-channel digital-to-analogue signal conversion in the GO pod’s circuit design, combining with a jitter-eradicating precision clock to deliver ultra-low distortion and high dynamic range – one of the key reasons why the GO pod unlocks better sound quality than true wireless earbuds.
Another factor is the hardware-based analogue volume control. The GO pod doesn’t rely on the software-based volume controls in connected digital devices, which can have a deleterious effect on audio resolution. Instead, adjusting the volume on the connected device controls the volume level in the DAC, rather than in the phone, tablet or computer.
To minimise pre-echoes and ringing artifacts, the DAC is designed with proprietary digital-interpolation filters that support multiple digital filter responses. This enables the GO pod to offer five filter settings, user-selectable to suit personal taste, musical style and format type – no true wireless earbuds offer such a facility.
iFi Go Pod + Symphonium Meteor
The Amplifier
Delivering a balanced output signal to each connected earpiece – another first for the TWS in-ear headphone scene – the GO pod’s amp stage has been carefully deigned to ensure ultra-low distortion and a silent background with high-sensitivity IEMs.
With a power output of 120mW into 32 ohms, and an output voltage of 4V into high-impedance 300-ohm loads, each GO pod supplies plenty of gas to drive any connected IEM with consummate ease, without rapidly draining the internal battery.
To ensure its output perfectly matches the connected IEM, each pod auto-detects the IEM’s impedance and adjusts power accordingly. There are four settings – 16 ohms, 32 ohms, 64 ohms and 300 ohms – with the setting most appropriate to the connected IEM selected automatically.
iFi Go Pod + Meze Advar
Wearability
None of this technology would be worthwhile if it couldn’t work with a wide range of wired IEMs and earbuds with detachable cables.
The GO pod’s detachable ear loop contains the IEM connector, and these are interchangeable – iFi has made ear loops for MMCX, 2pin, Pentaconn, T2 and A2DC connectors. Weighing just 12grams, each pod is designed to be lightweight and comfortable, yet robust and durable.
The ear loops are mouldable to fit around your ears and the pods are water- and sweat-resistant (IPX5 rated), so no problem wearing them down the gym or getting caught out in the rain.
A built-in microphone utilises Qualcomm’s cVc noise suppression technology for excellent voice clarity, whether you’re making a hands-free phone call, chatting on a video call, speaking to the connected device’s voice assistant or even playing a game online.
The aluminium panel on the front of each pod works as a touch control; simply tap to play or pause audio, skip forward or back, answer or reject a phone call, or engage the connected device’s voice assistant.
Charging?
The GO pod comes with a smartly designed charging case, with softly lined internal compartments and sufficient room to accommodate connected IEMs as well as the pods themselves.
Meze Advar with iFi Go Pod in Charging Case Open
A 1500mAH rechargeable battery is built into the charging case; a pair of GO pods will play for up to seven hours on a single charge, while the case provides multiple recharges to enable up to 35 hours of playing time. The case supports both Qi wireless charging and USB-C fast charging.
Compatibility?
Rather than just launch the GO pod and leave users to choose the IEMs they think would work best, iFi has collaborated with some of the world’s finest IEM manufacturers to find perfect ‘GO Pod + IEM’ partners.
As a result of this research, the first 1,000 GO pods produced will come packaged with a pair of IEMs from a carefully curated selection. All six ‘GO pod + IEM’ packages offer savings over individual pricing of the GO pod and IEMs when purchased separately – are listed below:
iFi Go Pod IEM Package Pricing
Price & Availability
The GO pod launches on April 14, 2023 at AXPONA (Audio Expo North America). The first 1,000 ‘GO pod + IEM’ packages are now available at ifi-audio.com.
60 days later – or when these packages have all sold through, whichever is sooner – the GO pod will be made available as a standalone product for £/$399 to combine with any pair of IEMs.
Each pair will come with two ear loops catering for MMCX and 2pin IEM connections; additional ear loops for Pentaconn, T2 and A2DC connections will be available at £/$29 each.
Related reading: Shure SE846 Sound Isolating Earphones with Gen 2 TWS Adapter
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our picks for the best desktop and portable DAC/Amps for audiophiles of 2025 include Burson Audio, JDS Labs, FiiO, iFi Audio and Rotel.
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
In-depth review of the Bowers & Wilkins true wireless noise cancelling earbuds covers everything you need to know.
Our favorite Dongle DACs in 2025 for audiophiles include models from Questyle, Audioengine, iFi and Campfire Audio.
With the Dongle DAC market shaking itself out in 2024, the $129 Questyle 15c leapfrogged the competition.
SOUNDPEATS Air5 Pro+ adds xMEMS drivers, AI Adaptive ANC, LDAC, and aptX Lossless, delivering a true 2-way design and hi-res performance at a budget-friendly...
