Dongle DACs
iFi’s GO link Max Dongle DAC Doubles Down on Power and Connectivity
With more power and balanced connectivity, the iFI GO link Max dongle dac is a great upgrade over the previous GO link and only costs $70.
iFi GO link Max Dongle DAC connected to laptop and IEM
iFi Audio, a maker of popular reasonably-priced compact and portable audio devices, such as portable DACs, has announced the GO link Max dongle DAC. Building on the foundation of the previously released GO link, the Max provides improvements in output power, a balanced Dual DAC setup with a 4.4mm balanced headphone output, minimized distortion, and a wider dynamic range.
The GO link Max has a compact design similar to that of its predecessor, the Go link. With its silver-plated copper cable and noise-rejecting helix design, listeners can enjoy clear, uninterrupted sound at home or on the go.
iFi Audio GO link Max with Earbuds and Laptop
With up to 241mW of output power — nearly five times more than a MacBook Pro (calculated at 32 ohms RMS using MacBook Pro’s stated headphone output voltage, Go line Max can drive demanding headphones without strain.
For added audio quality support, the GO link Max incorporates balanced circuitry with a Dual ES9219 DAC setup, physically and audibly separating the left and right channels at greater than 118 dB separation.
A 4.4mm balanced headphone output helps listeners to hear ultra-clear, precise balanced sound. Balanced audio minimizes unwanted noise or interference that can disrupt the signal resulting in distortion-free listening with better musicality.
iFi Audio GO link Max Connection Diagram
In addition to a 4.4mm true balanced headphone connection, the iFI GO link Max also includes “S-Balanced” connectivity. This is an iFi Audio technology that allows a single-ended 3.5mm headphone jack to deliver the benefits of a balanced audio connection. “S-Balanced” supports reduced distortion and improved channel separation even when using standard single-ended headphones.
The “S” stands for “Single-Ended Compatible.” This allows the 3.5mm jack to be used with both balanced and unbalanced headphones.
iFi Audio GO link Max Connections Close-Up
THD Compensation minimizes harmonic distortion while fine-tuned Dynamic Range Enhancement (DRE) extends the range between the loudest and quietest moments, making music listening more realistic.
The inclusion of ‘Quad DAC+’ and Jitter Elimination enable the GO link Max to deliver ultra-low distortion and clarity. This system reduces digital noise to ensure ultra-clear sound with exceptional detail. Every note, instrument, and vocal is rendered with pinpoint accuracy, allowing listeners to experience their music with enhanced clarity and precision, free from the subtle distortions that can otherwise impact sound quality.
Unlike some of the competition, the GO link Max uses a hardware-based volume control. This means you can turn the volume up or down without losing any of the details in music.
Comparison
iFi Audio GO link Max vs Go link
GO link MaxGO link
Price$79$59
Product TypePortable DAC and Headphone AmpPortable DAC and Headphone Amp
InputUSB-CUSB-C
Headphone Output3.5mm (Single-Ended/S-Balanced)
4.4mm (Balanced)
Microphone Pass-ThroughNot SupportedNot Supported
Hi-Res Audio SupportPCM 384kHz
DSD256 (11.3MHz)
PCM 384kHz
DSD256 (11.3MHz)
MQA RenderingNot IndicatedYes
DAC2 x ESS Sabre ES92191 x Bit-Perfect DSD & DXD DAC by ESS (exact model not provided)
Output Power (RMS)Single-Ended/S-Balanced: 100mW @ 32Ω; 2V @ 300Ω
Balanced: 241mW @ 32Ω; 4V @ 300Ω
Single Ended/S-Balanced: ≥1.5V/70mW @ 32Ω, ≥2V/14mW @ 300Ω
Output ImpedanceSingle-Ended/S-Balanced: 0.35Ω
Balanced: 0.7Ω
Single Ended/S-Balanced: <0.4Ω
SNR (Signal-to-Noise Ratio)Single-Ended/S-Balanced: 125dBA
Balanced: 130dBA
Single-Ended/Balanced: ≥125dBA (2.05V)
THD+NSingle-Ended/S-Balanced: ≤0.0015% @ 32Ω 1.27V
Balanced: ≤0.0016% @ 32Ω 2.4V
Single Ended/S-Balanced: ≤0.004% (1.27V @ 32Ω)
THD CompensationYes
Dynamic RangeSingle-Ended/S-Balanced: >125 dBA
Balanced > 130 dBA
Dynamic Range EnhancementYes
Frequency ResponseNo Provided10-80kHz (-0.5dB)
Power ConsumptionNo Signal ~0.6W
Max Signal ~3.2W
No Signal ~0.2W
Max Signal ~1W
Cable Length2.8″ (60mm)2.8″ (60mm)
Dimensions150 x 15 x 10mm
5.9 x 0.59 x 0.39-inches
135 x 12.6 x 7.6mm
5.3 x 0.5 x 0.3-inches
Net Weight14.5g (0.51 oz)11g (0.4 oz)
Box ContentsiFi Audio GO Link Max
USB-A Male to USB-C Female Adapter
Quick Start Card
Instruction Card
iFi Audio GO Link
USB-A to USB-C adapter
Lightning to USB-C adapter
Quick Start Card
User Manual
iFi Audio GO link Max What's In The Box
Bottom Line
With so many portable dongle DACs on the market, it can be confusing for music listeners to select the best one to meet their needs and the fact that iFi has a large selection within its brand doesn’t make things easier.
However, whether you prefer balanced or unbalanced headphone connectivity, the iFi GO link Max might be just the ticket. For $79 you get a sophisticated dongle DAC that can easily travel with you.
Although we haven’t reviewed the GO link Max yet, we have reviewed its predecessor, the iFi GO link and were quite impressed. So we’d expect the Max to be even better.
Pro Tip: In addition to earbuds or headphones, the 3.5mm output can be used to connect the GO link Max to a preamp, integrated amp, or powered speakers.
iFi Audio GO link Max Size Example
Where to buy?
Get the regular iFi GO link for $59 at Amazon.
For more information: ifi-audio.com/products/go-link-max/
Related Reading
3 Comments
3 Comments
  1. Asa
    November 21, 2024 at 5:42 pm
    Just curious – in a few photos above are 64 Audio earbuds. I didn’t see any reviews of them on the site – is it something you’ll look at in the future? They seem to be geared more towards audio engineers/musicians. Thanks.
    • Ian White
      November 21, 2024 at 6:53 pm
      Asa,
      I will ask Will to see if he can get a pair to review in January.
      Ian
      • Asa
        November 21, 2024 at 6:58 pm
        Thanks!
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Is FiiO’s lineup of Dongle DACs starting to cannibalize itself? The addition of aptX HD and LDAC support makes this more of a bargain.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Questyle, DDHiFi and Hidizs earn top honors in our Best Dongle DACs of 2022 Buying Guide.
With the Dongle DAC market shaking itself out in 2024, the $129 Questyle 15c leapfrogged the competition.
