iFi GO Blu Delivers Big Sound Quality in Tiny Package
The iFi GO Blu DAC/Headphone Amplifier offers a myriad of features and a huge reserve of power. For only $199. That’s a helluva deal.
iFi Go Blu Portable DAC Headphone Amplifier
iFi Audio has proven rather consistently over the years that it can do almost anything. The British manufacturer of portable and desktop DACs/Headphone Amplifiers never ceases to amaze us with its ingenuity and forward-thinking products. They also offer some of the best accessories for headphones and DAPs and we can’t think of another brand that offers such a comprehensive selection of affordable products. Tickle us blue in regard to the brand new iFi GO Blu DAC/Headphone Amplifier just announced.
iFi GO Blu
Key Features:
  • Advanced Bluetooth module with QCC5100 handles every HD format
  • Supported codecs include: aptX, aptX HD, aptX LL, aptX Adaptive, LDAC, HWA/LHDC, AAC, SBC
  • Hi-res DAC stage with ultra-low jitter and customized digital filter
  • Amp stage with twin-mono signal paths and Direct Drive technology ensures ultra-low distortion
  • Precision rotary volume control with auto-gain – adjusts output to match your headphones
  • Delivers up to 5.6V of power – drives even tough headphone loads with ease
  • Two headphone outputs: 4.4mm Pentaconn fully balanced and 3.5mm S-Balanced
  • S-Balanced output cuts distortion by 50% with single-ended headphone connections
  • XBass and XSpace – tailor sound to suit your headphones and personal sonic taste
  • Built-in mic for hands-free calls when paired with your smartphone
  • Can also be used as a Bluetooth receiver in a speaker-based audio system (via the 3.5mm output) or as a USB DAC/headphone amp (via the USB-C charging port)
  • Battery life – approximately eight hours (varies according to volume level and the power demands of the connected headphones/earphones)
The Details
iFi’s acclaimed DAC/headphone amps have formed a cornerstone of the company’s product range since its formation in 2012, delivering brilliant sound from smartphones, tablets, PCs, Macs and more. Some of these devices include rechargeable batteries and are sized to make them conveniently portable.
None, however, are as eminently pocketable as the GO blu – iFi’s most diminutive DAC/headphone amp yet. But, while it may be delightfully small (55x34x13mm, similar in size to a matchbox or Zippo lighter) and weigh just 26g (less than an AA battery), this pocket rocket delivers a performance that is remarkably mighty.
iFi Go Blu Portable DAC Headphone Amplifier in hand
To maximize mobile convenience, the GO blu pairs wirelessly with the user’s source device via Bluetooth. No more messing around with restrictive USB cables and dongles, worrying about whether you’ve got the right OTG cable for your Android device, or Lightning to USB Camera Adapter for your Apple iOS device. Just pair… and GO.
Clever right?
But while the GO blu majors on convenience, there’s not a hint of compromise when it comes to sound quality. Most pocket-size Bluetooth DAC/headphone amps incorporate all-in-one ‘system on a chip’ solutions to deliver input processing, digital-to-analogue signal conversion and amplification.
These are simple to implement, compact and cost-effective, but they cannot compare with expertly designed, individually optimized circuit stages when it comes to sound quality.
Uniquely for a device of this type and size, the GO blu’s clever design packs in separate Bluetooth, DAC and amp stages, each engineered in distinct blocks to deliver the ideal combination of cutting-edge specification and superb sound.
Bluetooth and DAC stages
The way iFi implements Bluetooth is anything but ‘run of the mill’ and despite its diminutive size the GO blu is no exception. Making full use of Qualcomm’s latest four-core QCC5100 Bluetooth processing chip, every current high-definition Bluetooth audio format is supported, including aptX Adaptive and aptX HD, LDAC and HWA/LHDC.
Other codecs covered include regular aptX and aptX Low Latency, AAC and SBC (the ‘plain vanilla’ Bluetooth codec).
This means that every possible source device is handled at the highest audio resolution its Bluetooth specification allows – no other pocket-size DAC/amp delivers such comprehensive codec support, or such high-quality sound over Bluetooth.
The GO blu is Bluetooth v5.1-compliant, ensuring the best possible range, stability and performance, and its ‘Bluetooth engine’ can be updated over the air.
The Bluetooth stage feeds the DAC stage, with a Cirrus Logic 32-bit DAC chip at its heart. This is coupled with a customized digital filter to minimize pre-echoes and ringing artifacts, and a precision clock system to ensure ultra-low jitter, thus reducing errors and distortion in the digital audio signal.
Amplifier stage
The analogue circuitry in many of iFi’s recently launched audio devices has focused on balanced design, traditionally a high-end concept; remarkably, the GO blu is no exception, despite its diminutive size.
iFi Go Blu Portable DAC Headphone Amplifier Circuit Board
The amp circuitry benefits from symmetrical twin-mono signal paths and utilises iFi’s Direct Drive design concept – direct-coupled to ensure a clean signal path without distortion-inducing output coupling capacitors.
In true iFi fashion, the GO blu incorporates circuit components of a quality not commonly found in a device of this kind, including TDK C0G multilayer ceramic capacitors and inductors from Taiyo Yuden and Murata.
The net result is ultra-low distortion across the entire signal bandwidth, delivering sound that is purer, clearer and more naturally expressive.
The amp stage delivers up to 5.6V – considerably more power than other similarly sized devices – handling even relatively tough headphone loads with ease. To ensure signal strength suits the sensitivity of the connected headphones or earphones, auto-gain adjusts output up or down by 6dB.
Further sonic tailoring is provided by two user-selectable features familiar to users of other portable headphone amps from iFi. The first is XBass, a sophisticated form of ‘bass boost’ that enhances low frequencies without muddying the midrange, particularly useful with earphones and open-back headphones that may lack deep bass.
The second is XSpace, a setting designed to compensate for the ‘in-head localisation’ effect that can occur when using headphones to listen to music that was mixed using a pair of speakers, effectively widening the headphone soundstage to deliver a more spacious and speaker-like experience.
Both these optional settings operate entirely in the analogue domain rather than messing with the digital signal via DSP (Digital Signal Processing) and may be switched in or out of the signal path.
iFi Go Blu Portable DAC Headphone Amplifier Connections
A pair of headphone outputs are provided – a 3.5mm socket for headphones with a single-ended cable/connector, and a gold-plated 4.4mm Pentaconn output enabling headphones equipped with balanced connectivity to take full advantage of the GO blu’s balanced amp design.
In addition, the 3.5mm output benefits from iFi’s S-Balanced circuitry, cutting crosstalk and related distortion in half when used with regular, single-ended headphone connections.
We can see this being exceptional with a lot of headphones including the Meze Audio 99 Classics and HiFiMan HE400se.
How much for all of this digital processing and power? $199 USD.
For more information: iFi Audio GO Blu
4 Comments
4 Comments
  1. MadMex
    September 17, 2021 at 10:11 pm
    Stuck working from home, aka under house arrest, since Coronavirus started, and disliking popular wireless bluetooth IEMs you must force down your ear canal, I’ve tried a couple, so uncomfortable, and loving wired earbuds so I can hear my surroundings, such as someone breaking into the house, I ordered this teeny tiny ifi GO Blu because carrying around my heavy iPhone XS in my loose shorts, or pajamas, all day actually pulls down my shorts as I walkabout exposing my rear end to unsuspecting housemates. And for this reason alone I give this product 5-stars. The iPhone now stays put and the ifi GO Blue rides along with me. No more falling pajama shorts.
  2. MadMex
    January 5, 2022 at 11:39 am
    Follow Up: After just 4-months my ifi Go Blu is major malfunctioning and no longer usable. It now blows out my ears with an extremely loud screeching sound with both 3.5 and 4.4mm. I’m currently dealing with support, and I hope all goes well. I am an early adopter and sometimes things go this way.
    • Ian White
      January 5, 2022 at 11:41 am
      After 4 months?
      It’s weird that you mention this because I’ve been having issues with my V2 of the Zen CAN which is having volume problems with some headphones.
      Ian White
  3. MadMex
    February 11, 2022 at 5:33 am
    Follow Up: Unable to update the firmware on my own following iFi helpdesk instructions, I’m not tech savvy enough, I suppose, I sent it in at their request after they offered to update the firmware for me. The 2-week turnaround was fantastic and this Go Blu is now a banger. It sounds better than before. It sounds directly plugged directly into my Mac, but it’s not, it’s over Bluetooth. Amazing. All my effort and $10 postage and handling to send in has paid off. Bravo iFi.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Gaming is driving the headphone market and Sennheiser's new HD 550 might be a fantastic option below $300 for audiophiles and gamers.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
