Digital Music Systems
iFi’s NEO Stream Is Streaming Platform Agnostic
The $1,299 iFi NEO Stream is a Roon Ready network streamer with open source architecture and no limitations of streaming platforms.
iFi Audio NEO Stream front angle
iFi Audio is celebrating a major milestone in 2022 and ten years into its rather unique journey, it is offering something liberating to music listeners who desire the ability to stream how they wish without being tied to any specific streaming platform or OS. The iFi NEO Stream utilizes an open-source architecture to make that a reality but how it actually accomplishes that requires greater explanation.
One claim that we think needs to be mentioned is from their own press release.
Music listeners are able to access their music through their choice of control app or music platform, and always experience exceptional sound quality, without the exorbitant price tags of other high-end streamers.”
We are big proponents of the open source architecture concept and would agree with iFi that streamers like the Naim Uniti Atom, Andover Songbird, Cambridge CXN V2, Bluesound NODE, and others do use their own operating OS and do promote specific streaming platforms.
But here’s the thing — for the most part they work rather well.
Some of us already use Spotify Connect and TIDAL Connect instead of going through the respective apps built into the streamers.
App development is a very expensive and time consuming endeavor; during our visit to the Focal Powered by Naim location in Houston, we met with members of the Naim team and the company has invested a lot of money into the platform that drives their current (and future) generation of streamers and network amplifiers.
Let’s learn more about what makes the IFi NEO Stream a very different type of streamer.
iFi’s new NEO Stream is built from the ground up to deliver versatility and sonic performance. It combines the latest version of iFi’s network streaming engine with a new DAC stage; connect the NEO Stream to a pair of powered loudspeakers or your existing amplifier and you are ready to go for $1,299.00 USD.
iFi believes the NEO Stream is distinctly different from other music streamers on the market because it is not tied down to any specific streaming platform and is built around their proprietary technology.
NEO by name – and by nature
The NEO Stream is the second device to join the NEO Series – iFi’s mid-level mains-powered range for home use, sitting between the ZEN Series and Pro Series.
The name ‘NEO’ was chosen because the first device in the series, the NEO iDSD, featured an all-new design and several features new to its product category. The NEO iDSD – a DAC/headphone amp with USB, S/PDIF and Bluetooth connectivity – remains current, but while it may be tempting to assume the NEO Stream is a NEO iDSD with a streaming module added and the headphone amp removed, this assumption would not be accurate.
The NEO Stream’s desktop-size chassis and aluminium casework clearly resembles the NEO iDSD. But while its circuitry builds on existing iFi designs, its internal architecture and attributes are unlike anything else on the market.
What’s up DAC?
The iFi NEO Stream’s digital audio circuitry is based around a 32-bit Cirrus Logic DAC chipset with advanced multi-bit modulation. This is coupled with a customised digital filter to minimise pre-echoes and ringing artefacts, and iFi’s GMT (Global Master Timing) precision clock system to ensure ultra-low jitter, thus reducing errors and distortion in the digital audio signal.
The DAC is fed by a powerful 16-core XMOS microcontroller, which processes the audio data received at the USB input. iFi’s in-house digital development team has programmed the XMOS firmware to optimise sound quality and ensure a perfect partnership with the Cirrus Logic DAC.
Hi-res PCM is supported to 32-bit/384kHz, alongside DSD64, 128 and 256, and single- and double-speed DXD. The DAC’s architecture maintains DSD data in true native form, unlike other DACs that convert DSD to PCM.
Open-source architecture – audio streaming unleashed
Many audio streaming devices lock users into a specific platform. That is not necessarily a problem, assuming the facilities on offer are in line with the user’s requirements and they are happy with the interface.
But, if they want to select their preferred streaming platforms and apps without restriction, with the ability to adapt and evolve as requirements change, a device with an open-source architecture offers clear advantages.
iFi has developed its own streaming engine, purpose built to deliver flexibility and performance. Its open-source nature, built on a powerful quad-core ARM Cortex processor and Linux-based operating system, enables it to evolve over time, whilst ensuring users are not locked into a specific platform. You choose the way you want stream, select your favorite app or streaming platform and let loose the streaming dogs of war.
From the device drivers, to the kernel (the heart of the operating system), to the shell (which interfaces with the kernel), to the applications and the user interface, everything is fully optimised for seamless operation and excellent sonic performance.
The firmware at the heart of this bespoke streaming engine was first utilized in the ZEN Stream – a ‘streaming transport’ that launched in 2021 – and has evolved significantly since. ZEN Stream users have already benefitted from updates to improve performance and functionality; the NEO Stream combines the latest version of this firmware with enhanced hardware to deliver something truly special.
Supported Platforms
Roon Ready
The Roon platform has become the standard-bearer for high-quality digital music management and streaming, thanks to a great interface, strong flexibility and high-quality sound. The NEO Stream has Roon Ready certification, which means it’s ready to slot straight into a Roon audio environment and work seamlessly with Roon software.
DLNA/UPnP
Any DLNA/UPnP-compatible streaming app (for example: BubbleUPnP, mconnect, Audirvana and so on) can be used to control the NEO Stream and access audio content from online services and DLNA-certified network storage devices.
Integrated Tidal Connect and Spotify Connect
Users of these hugely popular online music services can stream directly from the Tidal and Spotify apps – simple, seamless and effective.
Apple AirPlay
Integrated Airplay ensures easy streaming from Apple devices.
NAA operation
The NEO Stream can operate as an NAA (Network Audio Adapter) in conjunction with Sygnalist HQPlayer software – favoured by many serious music streaming enthusiasts. This means it can direct packets of audio data received over Wi-Fi or Ethernet cable straight to the connected DAC without applying processing.
Streaming from local storage with Stream-iFi app
iFi’s ‘Stream-iFi’ app is simple tool to aid initial set-up of the NEO Stream and initiate streaming from local storage devices – a NAS drive, for example.
Ultra-resolution digital audio
The NEO Stream can be used in two ways: connect to an amp and speakers via the onboard DAC stage and analogue outputs, or connect one of the available digital outputs to an external DAC. In the latter mode, the NEO Stream acts as a ‘streaming transport’ or ‘network bridge’, like the ZEN Stream but with a higher level of ‘ultra-resolution’ performance.
Whether the onboard DAC is engaged or not, the NEO Stream’s hi-res audio support is state-of-the-art: PCM data to 32-bit/768kHz, all levels of DSD up to DSD512, and single- and double-speed DXD. Remarkably, this level of hi-res audio is not only supported over the LAN and USB cable inputs but over Wi-Fi too. (A stable, full-strength 5GHz Wi-Fi signal is required for 384kHz PCM, DSD256 and above.)
MQA ­– the hi-res streaming technology, as used by Tidal’s ‘HiFi Plus’ tier – is comprehensively supported, with full decoding of MQA files up to 384kHz. This means that the full ‘three unfold’ decoding process can be performed internally, as opposed to only the final unfold in the manner of an MQA ‘renderer’. When the digital outputs are used to connect an external MQA-supporting DAC, both MQA passthrough and ‘first unfold’ are supported.
Custom DAC stage for exceptional sound
The NEO Stream’s integral DAC stage is based around a Burr-Brown chipset that iFi uses extensively, selected for its natural-sounding ‘musicality’ and True Native architecture.
One such critical component is the XMOS chip that iFi uses to process audio data received over the digital inputs. The NEO Stream incorporates a 16-core XMOS microcontroller, programmed by iFi’s in-house team to optimize sound quality and ensure a perfect partnership with the Burr-Brown DAC.
Thanks to the DAC chip’s four-channel True Native design, PCM and DSD take separate pathways and remain ‘bit-perfect’ in their direct-native form, right through to analogue conversion. In the case of DSD, there is no conversion to PCM or application of multi-bit processing – this is unusual and makes the NEO Stream an excellent choice for DSD purists.
Connectivity
The NEO Stream offers a connectivity array that is unique in a network music streamer at its price, both in breadth and specification, providing unparalleled versatility across a range of system configurations.
iFi Audio NEO Stream rear
Inputs
  • Dual-band Wi-Fi reception (2.4GHz and 5GHz) with 802.11a/b/g/n/ac support
  • Gigabit Ethernet (LAN) – 1x RJ45; 1x M12; 1x Optical LAN (see below for more information)
  • 2x USB-A (USB2.0 and SuperSpeed USB3.0 supported)
  • 1x USB-C system update port (OTA – Over The Air – updates also available)
Outputs
  • Analogue – 1x stereo RCA; 1x 4.4mm balanced
  • Ultra-res digital (PCM 768kHz, DSD512) – 1x HDMI-I2S; 1x USB-A (USB3.0)
  • Hi-res S/PDIF digital (PCM 192kHz) – 1x optical; 1x coaxial; 1x AES/EBU
Different Strokes for Different Folks
Several different settings allow users to tailor the NEO Stream’s performance to suit their system and the way they like to stream. For example, users can select between Exclusive Modes – individual settings that optimise performance by focusing operation on one mode of use. There are specific settings for Roon, Tidal Masters, DLNA and NAA, as well as a general mode for multi-platform use.
Further personal tailoring is provided by four user-selectable digital filters, each of which has a subtle but clearly discernible effect on sound. Users can switch between Bit-Perfect, GTO (Gibbs Transient Optimised), Minimum Phase and Standard, according to personal taste and whichever setting best suits their choice of music.
Look for a review of the iFI NEO Stream in Q4 with a number of new active loudspeakers and our existing systems.
For more information: ifi-audio.com
Where to buy: $1,299 at Audio46
Related Reading
1 Comment
1 Comment
  1. -0ID
    March 10, 2023 at 9:29 am
    “…streaming from local storage devices – a NAS drive, for example”
    I would avoid such formulation, more precisely would be “local network storage devices” as “local storage devices” means USB storage.
    Thank you.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
An immersive and dynamic listening experience, with a bold omni-directional design that creates a spacious, all-encompassing soundstage.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
