iBUYPOWER Erebus GT Desktop Gaming PC
iBUYPOWER announced the Erebus GT gaming PC, bringing highly efficient custom liquid cooling, once reserved for expensive boutiques, to the mainstream audience. The original, larger Erebus system has been renamed the “Erebus XL”.
The Erebus GT is a low-cost revision of iBUYPOWER's premium system named for the God Darkness and features a proprietary liquid cooling solution powered by Koolance that provides epic overclocking potential. The rugged Erebus GT features an advanced cooling system that includes three large radiators and 13mm high flow tubing to circulate 4.5 gallons of coolant per minute.
Like its larger sibling, the Erebus GT features a steel chassis frame, with aluminum top and front paneling. Erebus GT also retains the top fill port, built-in reservoir that can be checked through the front panel, and transparent top fins redirect exhaust and noise to the rear of the chassis.
The Erebus GT's compact cooling system features wider radiators than the XL's (140mm vs 120mm) to offset the cooling capacity loss from overall shorter radiators (top radiator from 4×120 to 3×140, rear from 2×120 to 1×140), as well as the removal of the front radiator. The result is a smart case design that creates unidirectional air flow to help the cooling system reach a maximum rated heat dissipation of 2,500W.
See more about:
Desktop PC
Gaming PC
Gamers looking to get the most of the Erebus GT's unmatched cooling abilities can take advantage of iBUYPOWER's PowerDrive Overclocking Service. Professionally trained and certified iBUYPOWER technicians can boost CPU performance by as much as 30% without the risk of system instability, crashes or damage to expensive components. All new systems enhanced with PowerDrive overclocking are fully covered under iBUYPOWER's standard warranty.
Price and Availability
The iBUYPOWER Erebus GT is available now for $899 to $4,599, depending on the configuration at http://www.ibuypower.com/Info/erebus-gt.aspx
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
