HSU Research Announces New Flagship VTF-TN1 15-inch Subwoofer
The new flagship VTF-TN1 subwoofer from HSU Research has a 15-inch driver and some additional improvements for $1,199 USD.
HSU Research VTF-TN1 Subwoofer Black
HSU Research has a rather loyal fanbase that has been waiting with bated breath for the introduction of a new flagship subwoofer. You can exhale kids. The new subwoofer is the 15″ ported VTF-TN1, which is slotted into their lineup as a replacement for their VTF-15H MK2.
The TN1 looks to earlier HSU Research subs such as TN1220HO and TN1225HO that were inspired by the design philosophy of the late Tom Nousaine. However, Dr. Poh Ser Hsu is the founder and technical guru of the company.
Dr. Hsu with HSU Research VTF-TN1 Subwoofer
Features
HSU Research has designed the VTF-TN1 to provide the ultimate home theater experience with higher output and deeper bass than previous models.
The new flagship incorporates a 15-inch driver in combination with dual 4-inch down-firing ports that extend lower frequency output further as a result of Variable Tuning Frequency (VTF) technology. The way VTF works is that the subwoofer has two ports that can be plugged up if desired. When one port is plugged, the subwoofer has the deepest bass response. However, if both ports are unplugged, the overall subwoofer output increases, but the subwoofer won’t go as deep.
What is Variable Tuning Frequency (VTF)?
In addition, Q-control adds another layer of adjustment that fine-tunes bass tightness.
Connectivity includes balanced XLR, unbalanced RCA, and high-level inputs for integration flexibility with all types of audio systems.
Tip: Balanced XLR inputs protect against noise caused by RF interference, RMI, etc for usage in high-end audio and professional audio (studio, live sound environments).
The VTF-TN1 also has a taller body than previous models.
Dual HSU Research VTF-TN1 Subwoofer in Home Theater Lifestyle Angle
Compared to other HSU subs, the VTF-TN1 differs in the following ways (also check out the specification comparison and product links in the provided table below):
  • Larger enclosure than the VTF-3 MK5 HP, so more efficient in the deeper bass
  • Larger ports at a lower tuning than the VTF-3 MK5 HP, so it not only plays louder and cleaner with sub 20 Hz bass (less port noise) but also lower.
  • Plays significantly louder and cleaner than the VTF-2 MK5 across the board (like having two of the VTF-2 MK5’s put together) with low distortion.
  • Plays significantly louder and cleaner than the ULS-15 MK2 in the deeper bass (like having two ULS-15 MK2’s put together) with low distortion.
  • Among the smallest footprint – similar to the ULS-15 MK2.
Tip: The VTF-TN1 can also be laid on its side if preferred. Less deep than most sofas, this sub makes a good end table without affecting sound quality,
Dual HSU Research VTF-TN1 Subwoofer in Home Theater Lifestyle Front
Dual HSU Research VTF-TN1 Subwoofers with HC-1 / HB-1 MK2 Center / Bookshelf Speakers.
Comparison
VTF-TN1VTF-2 MK5ULS-15 MK2VTF-3 MK5 HPVTF-15H MK2
Price$1,199$689$989 $999$1,249
Woofer DriverFront Firing
15-inch
Front Firing
12-inch
Front Firing
15-inch
Front Firing
15-inch
Front Firing
15-inch
Amplifier Power (RMS)2000 W Short Term
600 W Continuous
1400 W Short Term
350 W Continuous
2000 W Short Term
600 W Continuous
2000 W Short Term
600 W Continuous
2000 W Short Term
600 W Continuous
Hybrid Tuning15 Hz Ported
20 Hz Ported or Sealed
18 Hz Ported
22 Hz Ported or Sealed
20 – 200 Hz, +/-1 dB18 Hz Ported
16 Hz Ported
Low-End Extension (+/- 2 dB)14 Hz (1 port open)
18 Hz (2 ports open)
16 Hz (1 port open)
22 Hz (2 ports open)
20 Hz17 Hz (1 port open)
16 Hz (1 port open)
21 Hz (2 ports open)
Q Control Range0.3 – 0.70.3 – 0.70.3 – 0.70.3 – 0.70.3 – 0.7
Crossover30-120 Hz, Bypassable30-90 Hz, Bypassable30-90 Hz, Bypassable 30-90 Hz, Bypassable30-90 Hz, Bypassable
Crossover Slope24 dB/Oct24 dB/Oct24 dB/Oct24 dB/Oct24 dB/Oct
Phase0°/180°0°/180°0°/180°0°/180°0°/180°
InputsLine Level (2)
Speaker Level (2)
Balanced XLR (2)
Line Level (2)
Speaker Level (2)
Line Level (2)
Speaker Level (2)
Balanced XLR (2)
Line Level (2)
Speaker Level (2)
Line Level (2)
Speaker Level (2)
Balanced XLR (2)
Power Outlet Requirement720 W, 120/240V430 W, 120/240V720 W, 120/240V720 W, 120/240V720 W, 120/240V
Enclosure Dimensions  (HxWxD)29.5 x 18.5 x 18.5 inches20 1⁄2 x 15  x 22-inches18 x 18  x 18 inches24 x 17 1⁄4  x 21 1⁄2-inches24 x 18 x 26 inches
with Grill, Feet, and Amp
(HxWxD)
Not provided21 1⁄2  x 15  x 24 inches19 x 18 x 19 1⁄2 inches25 x 17 1⁄4  x 24-inches25 x 18 x 28 1⁄2-inches
Weight85 lbs62 lbs65 lbs85 lbs110 lbs
HSU Research VTF-TN1 Subwoofer Rear
HSU Research VTF-TN1 Subwoofer Rear. View panel close-up.
Price & Availability
The HSU Research VTF-TN1 Subwoofer will start shipping on April 12th for $1,199. Pre-order now with a $200 non-refundable deposit and receive $50 off (while supplies last) via the HSU Research Website
The VTF-TN1 comes with a furniture-grade smooth satin black painted finish. The warranty for all subwoofers is 7 years on the woofer and 5 years on the electronics.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
