HP Wireless TV Connect (2011)
HP updated its Wireless TV Connect accessory to support 3D video streaming from a PC to a television for a 3D theater experience in the comfort of a living room.
The latest generation of the HP Wireless TV Connect is WHDI certified and features a smaller design for greater mobility while still delivering HD video with virtually no latency. Simply plug the receiver into a PC’s HDMI port to instantly stream HD and 3D movies, games and web applications directly to a television.
New Features:
  • Stream 3D content from a PC directly to a 3D-enabled television
  • Extended transmitting range, up to 25-30 feet away.
  • Supports 7.1 audio (over the HDMI 1.4 spec)
  • Zero lag between what you’re transmitting and what you see on-screen.
Like its predecessor, the all-new HP Wireless TV Connect wirelessly streams 1080p HD multimedia content such as photos, videos and Blu-ray movies from the notebook to a TV or any large screen and is compatible with almost any PC with an HDMI port. Here’s a video of the bulkier older (non-3D) model, but the concept is the same.
Price and Availability
The HP Wireless TV Connect is expected to be available December 2011 in the United States $179.99.
Philips Roku 65-oinch OLED TV
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Rotel DX-3 Black Angle Front Lifestyle with Headphones Rotel DX-3 Black Angle Front Lifestyle with Headphones
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Q Acoustics Q SUB Subwoofer Series in Satin Black Q Acoustics Q SUB Subwoofer Series in Satin Black
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
TCL QM7K QD-MiniLED TV Lifestyle 2025 TCL QM7K QD-MiniLED TV Lifestyle 2025
HDTV 4K & 8K TV
With sizes up to 115 inches and fairly affordable pricing, TCL's QM7K MiniLED TV will be one to watch in 2025.
Fluance Wireless Floorstanding Speakers Lifestyle Fluance Wireless Floorstanding Speakers Lifestyle
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Arendal 1961 Loudspeakers Arendal 1961 Loudspeakers
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
