HP just announced the V5560u Digital Camcorder which records in full high definition 1080p video format. It features a large 3″ wide touch screen LCD display for easy navigation and viewing of your recordings. Additionally, it comes with both HDMI and AV cables for convenient connection to play back recorded videos on your TV for instant sharing with friends and family.
Sharing videos in brilliant colors has never been so easy. Just record, connect the camcorder to your TV using the included HDMI cable, and instantly enjoy the vivid colors of the videos on your full HDTV. It’s that simple!
With the HP V5560u, you can easily transfer videos to your notebook or PC by inserting the SD card into a memory card reader or via the included USB cable. Once transferred you can upload your videos to video sharing websites to share with anyone you’d like. The easy-to-use, compact design, and the dual card feature make the V5560u the ideal travel companion.
Creative and Fun
- Large screen: 3″ wide screen allows you to clearly review the video you’ve just recorded
- Simple controls: Easily navigate the camcorder’s simple controls with the touch screen display
- SD/SDHC supported: Up to 16G SD/ SDHC card expansion slot gives you plenty of room to record the precious moments of your life.
- Motion detection: Capture fun moments of your pet
- Still image capture: Change to still image capture mode anytime to take brilliant color snapshots or convert a frame from a recorded video to a still image
Package Contents
- HP V5560u Digital Camcorder Li-ion rechargeable battery Battery charger (with power cord) HDMI cable
- USB cable AV cable Carrying case Lens cap (optional) Cleaning cloth Quick start guide Software install and electronic user manual CD-ROM Warranty document
Specifications
LCD display: | 3″ Touch Screen LCD panel |
Video resolution | Full HD (1920 x 1080p / 30 fps) HD (1280 x 720 / 30 fps) WVGA (848 x 480 / 60 fps) QVGA (320 x 240 / 30 fps.) |
Video format: | H.264 (.MOV) |
Still image resolution | 5MP (up to12MP with interpolation) |
Still image format | JPEG |
Zoom | 20X zoom max (5X optical zoom / 4X digital zoom) |
Internal memory: | 32MB |
Storage media: | SD/SDHC |
Warranty | One year limited hardware warranty from date of purchase |
Pricing
The V5560u will have a $199 MSRP.
