Camcorders
HP V5061u Digital Camcorder
HP just announced the V5061u — a 1080p high definition digital camcorder with a large 3″ touch screen LCD display for easy navigation and viewing of your recordings. It features two SD card slots and dual power sources allowing you to capture more videos and enjoy battery power flexibility.
1080p High Definition recording
Featuring 1080p high definition recording, the V5061u Digital Camcorder allows you to record videos at up to 1440×1080 resolution. Now you can capture videos of your life’s moments in sharp details and in vivid colors.
Dual Power Source
The V5061u provides you with the flexibility of using AA batteries whenever the rechargeable battery runs out of power. You can now record your life moments with 2x AA batteries whenever you forget to recharge your battery.
HDMI interface
With the HDMI Interface, you can easily transmit digital videos to any HD TV to share instantly with friends and family. Just record, connect the camcorder to your TV using the included HDMI cable, and enjoy the vivid colors from the videos instantly on your High Definition TV. It’s that simple!
Motion Detection Function
Capture fun moments of your pet or toddler by setting the camcorder in place. Recording automatically starts when motion is detected.
Still image capture
Press the camera button at any time to take color snapshots to share with friends and family. With the still image resolution of up to 16MP with interpolation, you can be sure to have brilliant color pictures with great clarity.
Specifications
LCD display dimension 3 inch touch screen LCD panel
Video resoultion 1080p HD (1440 x 1080 / 30 fps)
720p HD (1280 x 720 / 30 fps)
WVGA (848 x 480 / 60 fps)
QVGA (320 x 240 / 30 fps)
Video format H.264 (.AVI)
Still image resolution 5MP (up to 16MP with interpolation)
Still image format JPEG
Zoom 4X digital zoom (2X for 1080p video recording)
Internal memory 32MB
Storage media SD/SDHC up to 32GB
Minimum system requirements
  • Microsoft Windows XP sp2/ Vista sp1, Microsoft Windows 7
  • 300 MB available hard disk space for software installation
  • CD/DVD optical drive (for software installation only)
  • 300 MB RAM or above
SD Playback (480p)
  • CPU: Intel Pentium 4 2.4GHz or above, AMD Sempron 2600+ 1.6GHz or above
  • Graphic card: VGA card with 64MB or more
  • Screen resolution: 800 x 600 or higher
HD Playback (over 720p)
  • CPU: Intel Core 2 Duo CPU E4400 2.0GHz or above, AMD Athlon 64 X2 4600+ 2.4GHz or above
  • Graphic card: GeForce 7600 GT or ATI Radeon HD 2400 Series or more
  • Screen resolution: 1280 x 1024 or higher
Power NP-40 Li-ion rechargeable battery or 2x photo lithium AA batteries
Dimensions 4.4 x 2.0 x 2.3 inch / 11.5 x 5 x 5.8 cm
Weight 0.57 lb / 0.260 kg
Warranty One year limited hardware warranty from date of purchase
Price and Availability
The V5061u will have a $169 MSRP, available this spring.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
