HP just announced the 12-megapixel SW450 ultra-thin point-and-shoot digital camera with 4X optical zoom. At less than 3/4″ thick and weighing only about 0.25 lbs, you can take the SW450 everywhere you go. It easily fits conveniently in your pocket or purse making it handy for any spontaneous picture moments.
New & improved user interface
The new user interface features modern 3D icons and greater color contrast for improved visibility when navigating menu selections even in bright light. Additionally, when choosing scene modes, two images are shown as examples of how a picture would look like in comparison to using the auto mode.
4X Optical Zoom
The 4X Optical Zoom lets you magnify and capture sharp images when taking pictures from a distance. Optical Zoom brings the subject closer and makes additional detail visible.
Smile Detection
With smile detection, the camera will search for a smile and automatically take the picture when it detects that the subject is smiling. This feature is especially helpful when trying to capture pictures of young children smiling in front of the camera.
Blink Detection
When using the blink detection feature, the camera alerts you if a subject is blinking when the picture is taken. The camera will then prompt you to either keep or delete the picture, allowing you the opportunity to retake pictures as you deem necessary.
Over 25 scene modes
With over 25 scene modes, you can easily ensure the best shot is captured in different shooting situations. Pick the mode that best matches your activity or use the Intelligent scene mode to let the camera detect the conditions and select the best mode for you.
The party scene mode is great for taking pictures in indoor low-light conditions. The camera will adjust its shutter speed to capture subjects at a faster speed and enable anti red-eye flash. This way you can snap away and get perfect pictures of everyone at a party. The love portrait scene mode lets you take a good picture when there are just the two of you. Simply point the camera at the two of you and press the shutter. Face tracking will detect when your faces are in the frame, autofocus on them, and take the picture.
Specifications
LCD Display | 2.7″ |
Sensor Type | 1/2.3″ CCD |
Total Pixels | 12.5MP (4102×3057) |
Effective Pixels | 12.2MP (4032×3024) |
Zoom | 4X optical zoom, 5X digital zoom |
Still Image Format | JPEG/EXIF 2.2 |
ISO Sensitivity | Auto, 50, 100, 200, 400, 800, 1600, 3200 ( <3MP), 6400 (1280×960) |
Video Format | AVI (Motion JPEG) |
Storage Media | SD/SDHC (Up to 32GB) |
Minimum System Requirements | Microsoft Windows XP/Vista/7 Pentium III 1GHz processor or equivalent 512MB RAM or greater 300MB available hard disk space for software installation |
Power | Li-ion battery |
Dimensions | 3.6 x 2.3x 0.7 inch / 91.6 x 57.8 x 17.1 mm |
Weight | 0.22 lb / 100g (without battery) |
Warranty | One year limited hardware warranty from date of purchase |
Price and Availability
The HP SW450 will be available this spring in turquoise or red for $129.
