Digital Cameras
HP PW550 Digital Camera
HP just announced the 12-megapixel PW550 digital camera with 5X optical zoom. With its 28mm wide-angle lens, you can capture panoramic views in detail. The PW550 is an excellent choice for taking pictures that are wider or taller, e.g. group pictures, landscapes, and tall buildings.
Featuring a 28mm wide-angle lens, the PW550 allows you to fit more scenery into a shot. The wide-angle lens is ideal for taking pictures of panoramic landscapes and tall subjects.
5X Optical Zoom
Use the 5X Optical Zoom to magnify and capture sharp images when taking pictures from a distance. It brings subjects closer and enables you to see crisp details that would not otherwise be visible.
Smile Detection
With smile detection, the camera will search for a smile and automatically take the picture when it detects that the subject is smiling. This feature is especially helpful when trying to capture pictures of young children smiling in front of the camera.
Blink Detection
When using the blink detection feature, the camera alerts you if a subject is blinking when the picture is taken. The camera will then prompt you to either keep or delete the picture, allowing you the opportunity to retake pictures as you deem necessary.
Over 25 scene modes
With over 25 scene modes, you can easily ensure the best shot is captured in different shooting situations. Pick the mode that best matches your activity or use the Intelligent scene mode to let the camera detect the conditions and select the best mode for you.
Use the portrait mode to make the background less distracting for perfect pictures focused on your loved ones. Select Snow mode on your next ski trip to transform overly bright washed out pictures into vibrantly colored photos of the slopes and snow capped mountains. Select Sunset mode to capture the beautiful scenes bathed in the dramatic warm colors of a sunrise or sun setting sky.
Specifications
LCD Display 2.7″
Sensor Type 1/2.3″ CCD
Total Pixels 12.4MP (4077×3038)
Effective Pixels 12.2MP (4032×3024)
Zoom 5X optical zoom, 5X digital zoom
Still Image Format JPEG/EXIF 2.2
ISO Sensitivity Auto, 50, 100, 200, 400, 800, 1600, 3200 ( <3MP), 6400 (1280×960)
Video Format AVI (Motion JPEG)
Storage Media SD/SDHC (Up to 32GB)
Minimum System Requirements Microsoft Windows XP/Vista/7
Pentium III 1GHz processor or equivalent
512MB RAM or greater
300MB available hard disk space for software installation
Power Li-ion rechargeable battery
Dimensions 3.59 x 2.30 x 0.89 inch / 91.1 x 58.3 x 22.5 mm
Weight 0.26 lb / 120g (without battery)
Warranty One year limited hardware warranty from date of purchase
Price and Availability
The HP PW550 digital camera will be available this spring in black or plum for $149.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
