HOUCHMAND’s M1 Active Loudspeaker System Comes in Elegant Gold Finishes
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
HOUCHMAND M1 System Lifestyle Image
HOUCHMAND Audio is a German luxury audio brand dedicated to creating high-fidelity sound systems that seamlessly merge performance, design, and craftsmanship. If all of that sounds like it’s expensive — you would be correct.
First previewed back at Munich High End 2022, the HOUCHMAND M1 System has undergone three years of refinement and engineering to reach production-ready form. The system is designed and handcrafted in Germany as an ultra-high-end audio solution that combines a Monobloc player (not to be confused with a monoblock amplifier) and two active M1 speakers to create a truly immersive, high-fidelity listening experience, and, if desired, the inclusion of an optional subwoofer.
The M1 Speakers
HOUCHMAND M1 Active Speaker
The M1 speakers included in the system have a 3-way active configuration with a coaxial midrange driver and tweeter, designed to deliver clarity, balance, and immersive soundstaging. Built-in room compensation EQ allows the system to adapt acoustically to any living space.
The Monobloc
HOUCHMAND Monobloc Rear
The HOUCHMAND Monobloc Player is the central component of the M1 system. It integrates digital streaming services with high-end inputs and outputs for additional physical external sources. It connects to the M1 speakers via Purity Path Technology, offering both wired and wireless connectivity and enabling seamless playback from TIDAL, Qobuz, Deezer, and Spotify.
Pro Tip: HOUCHMAND’s use of the term monobloc may be confusing for audiophiles as the term (spelled with a “k” at the end of the word) commonly applies to single channel (mono) power amplifiers, but in the HOUCHMAND’s case, it refers to its central connection and preamp unit and does not include an amplifier section.
HOUCHMAND’s Purity Path Technology, an advanced audio transmission system, is designed to maintain stable signal integrity from source to speaker.  Unlike traditional audio setups, where cables, external amplifiers, and connectors can introduce distortion, interference, and loss, Purity Path Technology ensures an untouched, uninterrupted audio signal, eliminating signal degradation
HOUCHMAND M1 Speaker with Monobloc Lifestyle
German Craftsmanship
Each HOUCHMAND Audio system is available in 24ct gold, 18ct rose, and gold, platinum, and ruthenium finishes. With customizable RAL and NCS color options, the M1 System seamlessly integrates into luxury interiors with a stylish look.
Specifications
Houchmand ModelM1 System
Product TypeStreaming Music System with Active Speakers
Price (without Subwoofer)£58,995
€58,500
Price (with Subwoofer)£78,990 (subwoofer price: £19,995,  €19,500)
Room Compensation EQYes
Purity-Path-Technology (custom system)Yes
Bit Rate/Sampling Rate SupportWired up to 192 kHz/24-bit, Wireless up to 96kHz/24-bit
Monobloc InputsDigital S/PDIF (Toslink), Digital HDMI ARC Connector
Monobloc OutputsAnalogue (RCA), Digital S/PDIF (RCA)
ControlApp (iOS, Android), Remote Control
Additional SourcesUSB, SSD
Streaming SupportQobuz, TIDAL, Deezer, and Spotify
Dimensions WDH   (Speaker)103 x 19 x 25 cm
40.55 x 7.48 x 9.84 in
Dimensions WDH  (Monobloc Player)31,5 x 22,9 x 5,2 cm
12.40 x 9.02 x 2.05 in
Weight (Speaker)2 x 38.3 kg | 2 x 84.44 lbs.
Weight (Monobloc Player)11 kg / 24.25 lbs
What’s in the BoxSystem M1
2 x M1 Speaker
1 x Monobloc Player
1 x Remote Control
Optional1 x S1 Subwoofer – Analog or Digital In (RCA)
HOUCHMAND M1 App
The Bottom Line
The HOUCHMAND M1 System appears to be a curious beast.
On the one hand, it is a stylish audio system that includes a central connection hub (monobloc) that supports both physical and streaming connectivity, a pair of active (powered) speakers, and the option to add a subwoofer.
However, in looking over all the available information about this system, no detailed specs are provided for the speakers (or subwoofer), and no official image seems to be available for the subwoofer. Another curious thing is that it supposedly supports HDMI-ARC, but there is no HDMI connection shown on the monobloc unit unless the images provided are from the M1’s earlier development stage. A companion app is also mentioned, but no details or download links have been provided.
With international pricing starting at €58,500, we’ll have to wait for the HIGH END Show in mid-May to determine if this cost-no-object audio system can deliver on its sky high price.
HOUCHMAN M1 Finishes
Available finishes.
Price & Availability
Each M1 system is handmade to order. Crafted from 24ct gold, 18ct rose, gold, platinum, and ruthenium.
The HOUCHMAND M1 System and S1 Subwoofer are now available to order, either as a complete system or as individual components, with the following retail prices:
  • M1 System (without Subwoofer): £58,995 / €58,500
  • M1 System (with Subwoofer): £78,990
  • Subwoofer (if purchased separately): £19,995 / €19,500
US Pricing forthcoming. The HOUCHMAND brand is distributed through the Apex Audio Group. Based on current exchanged rates, U.S. pricing could be $64,000 / $85,000 (not confirmed).
HOUCHMAND M1 Active Speaker Rear
HOUCHMAND M1 Active Speaker Rear Close-up
1 Comment
1 Comment
  1. Ian White
    March 31, 2025 at 2:05 pm
    Anton,
    Only 3? My issue with this system is that it doesn’t deliver very much for that kind of money. Over the weekend, I had only a few hours to edit some of our coverage due to my therapy and I re-read Robert’s (and my own) coverage of the Nagra phono stage. Having actually listened to a system with the Nagra HD Phono (excuse me if I get the model wrong) at a show…it sounded great. But we’re talking about a $300,000 system. It better sound great. Mind-blowing.
    I just don’t get spending that kind of money on anything hi-fi related. $87K for a phono stage. That’s a new kitchen and covered outdoor patio with a Braai, 65″ waterproof TV, fireplace, and DALI CI speakers.
    IW
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
At $329, WiiM Ultra is the company's top-of-the-line digital music streamer which adds a touchscreen, HDMI ARC and a subwoofer out.
A recent study suggests Walmart's CastOS TV operating system may dominate the TV device market by 2029. Here's why that matters.
The Triangle CAPELLA 2 delivers flexible home audio with WiSA wireless, Bluetooth, and multiple wired inputs, including a new subwoofer output, combining French design...
Apple to deliver its next-gen wireless earbuds in 3 weeks. Let the fanboy drooling commence.
Improved battery life, better performance, and a very affordable price make the new Cambridge Audio Melomania 1+ wireless IEMs very appealing.
At $199, the Denon Home 150 is a versatile wireless speaker with Alexa built-in and HEOS for multi-room setups and hi-res music streaming.
LG's new StanbyME 2 is a portable smart touchscreen TV with a detachable design, QHD screen, built-in battery, and flexible placement.
The CANVAS HiFi Soundbar has already gotten good reviews, but it may get even better with the implementation of Organic Master Tuning
