HomeLogic Delivers Home Theater Control With Its OneHome Solution
Marblehead, MA, September 2005 — HomeLogic, LLC, the leading manufacturer of IP-based integrated solutions, announced today the release of the OneHome Theater simplified control of home theater and video distribution systems to its broad line of home management and control solutions.
Applying the same award winning integration technologies they pioneered for the automation of leading home subsystems such as security, lighting, and climate control; HomeLogic has created home theater control that will allow custom dealers to integrate leading brands of home theater components into fully integrated, networked homes. Homeowners will be able to access their home theater and video distribution systems from the OneHome in-wall and wireless touch screens or from a Pocket PC. Integrators will be able to connect various new and legacy sources such as DVD, DVR, satellite, and cable TV as well as projection, flat screen and other displays, using either serial or IR-based control.
OneHome Theater features serial control for several supported receivers and video switchers including models from Elan, Integra, B&K and more. IR capability is provided through integration of the Global Cache’ product line, enabling the simple integration of legacy components to fully integrated OneHome systems.
“The integration of video entertainment control is a significant addition to the OneHome solution,” stated Jim Herman, HomeLogic co-founder. “With our touch-screen video preview feature users can preview and queue up a DVD or VCR source while watching the satellite feed on the plasma. Our software provides dealers with standardized templates which they can easily customize to meet the individual customer’s demands.”
For more information on HomeLogic, please call 791.639.5155 or visit www.homelogic.com.
HomeLogic has been developing and delivering IP-based entertainment and home control solutions since 2002. Home Logic’s OneHome solutions provide an easy to use, elegant interface without custom programming to enhance the home owner experience while lowering the cost. OneHome Entertainment and Home Control Solutions integrate home theater, digital & distributed audio, security, climate, lighting, video surveillance, irrigation, pool/spa controls and messaging.
Press Contact: Caster Communications, Inc. at 401.792.7080
Joseph Hageman jhageman@castercomm.com
Allie Mills amills@castercomm.com
For digital images: www.castercomm.com
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
