Hisense PL2 4K Laser UST Projector Does Dolby Atmos, Dolby Vision Up to 150 Inches
At $2,499, the Hisense PL2 ultra-short throw projector has a lot in common with the previous PL1 but it can project a larger 150-inch screen size and offers much higher peak brightness.
Hisense PL2 4K Laser UST Projector Lifestyle
Hisense has become a global TV/projector market leader with a successful line of LED/LCD TVs, Laser TVs, and projectors. Their latest projector release is the PL2 UST (Ultra Short Throw) projector. Similar to the previously released Hisense PL1, PX2-PRO, and, PX3-PRO, USTs, the PL2 is designed for people who already have or plan to purchase their screen or intend to use the projector on a blank wall (though we don’t recommend that as dedicated screens give you much better results).
The Hisense L9H and L5H UST Projectors come packaged with either a 100-inch or 120-inch screen. Hisense calls these models “Laser TVs” because they use a laser lighting system and, unlike traditional projectors, include speakers and a streaming app platform as well as a screen. So they really can directly replace a standalone TV. The PL2 also includes a built-in speaker and streaming platform (Google TV) but does not come with a screen.
Pro Tip: The PL2 is the direct successor to the PL1. Expect discounts on existing stock of the PL1 as retailers sell remaining inventory.
DLP 4K Pixel Shifting
The Hisense PL2 is designed to deliver high-quality picture performance. It incorporates a Texas Instruments DLP imaging chip that can achieve 4K UHD resolution (via Pixel Shifting). It also includes AI upscaling and Hisense’s X-Fusion Laser Engine that is said to cover 85% of the DCI-P3 color space with 2,700 ANSI lumens of brightness and a 3,000:1 native contrast ratio.
The PL2 projector can project an image between 80 to 150 inches: 30 inches more than its predecessor. Its ultra-short throw design (0.22:1 throw ratio) requires less space, adding versatility for a variety of rooms and screen setups.
Hisense PL2 4K Laser UST Projector Screen Sizes Up To 150-inches
The PL2 includes Filmmaker Mode, ALLM, and MEMC (Motion Estimation, Motion Compensation) to ensure smooth playback for movies, sports, and gaming.
Smart Features
The PL2 runs on the Google Smart TV OS for seamless access to popular streaming services like Netflix, YouTube, Disney+, Hulu, and Amazon Prime Video. Compatible with Control4, AirPlay 2, and Apple HomeKit, it allows connectivity with other smart devices at home, enhancing the overall user experience.
Connectivity
Hisense PL2 4K Laser UST Projector Rear Connections
Physical connections include three HDMI 2.1 inputs (one is eARC compatible) and one Digital Optical output.
Pro Tip: The HDMI-eARC and Digital Audio output can be used to connect the PL2 to a compatible external audio system, receiver or soundbar.
Audio
Hisense PL2 4K Laser UST Projector with Dolby Vision and Dolby Atmos
With video projectors, audio isn’t always prioritized. However, PL2 includes a built-in speaker system that provides both Dolby Digital and Dolby Atmos sound with the inclusion of two up-firing speakers. Just remember that this method relies on bouncing sounds off your ceiling for immersive effects and is dependent on ceiling height and seating position to work effectively.
The PL2 is also WiSA-ready for added audio setup flexibility. WiSA enables high-quality audio to be transmitted and received wirelessly by compatible speakers with precise synchronization and no perceivable latency. Products that are designated as “WiSA Ready” mean that a plug-in WiSA transmitter can transmit to any WiSA Certified Speaker.
Comparison
Hisense PL2 (left) vs PL1 (right) UST Projectors
Hisense PL2 (left) vs PL1 (right). Differences noted in Bold.
Hisense PL2 (2024 model)Hisense PL1 (2023 model)
MSRP$2,499$2,499 $1,987
Projector TypeUST (Ultra Short Throw)UST (Ultra Short Throw)
Light SourceX-Fusion Laser EngineX-Fusion Laser Engine
Laser Life25,000+ Hours25,000+ Hours
DLP Imaging Chip0.47″ DMD0.47″ DMD
Brightness2700 ANSI Lumen2200 ANSI Lumen
Contrast Ratio (Dynamic)3,000:1 (native)
2,000,000:1 (dynamic)
3,000:1 (native)
Color Space85% DCI-P385% DCI-P3
HDRHDR10, Dolby Vision, HLGHDR10, Dolby Vision, HLG
Resolution 4K (via pixel shifting)4K (via pixel shifting)
Refresh Rate60Hz60Hz
Filmmaker ModeYesYes
MEMCYesYes
Throw Ratio0.22:10.25:1
Projection Screen Size80″-150″80″-120″
Eye SafetyYesYes
HDMI3x HDMI 2.1 2x HDMI 2.1
HDMI ARC, CECYesYes
ALLMYesYes
USB1 x USB 3.0,
1 x USB 2.0
1 x USB 3.0,
1 x USB 2.0
Audio Output Power30W (Stereo 15 watts x2)30W (Stereo 15 watts x2)
Surround SoundDolby Atmos, Dolby DigitalDolby Atmos, Dolby Digital
Analog Audio Output1 x 3.5mm1 x 3.5mm
Digital Audio Output1 x Optical1 x Optical
WiSA ReadyYesYes
RF Antenna Input/TV Tuner
Smart TV PlatformGoogle TV (Google Certified)Google TV (Google Certified)
App StoreGoogle Play StoreGoogle Play Store
Streaming Service SupportNetflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, Pandora, Sling TV, YouTube, etc.Netflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, Pandora, Sling TV, YouTube, etc.
BluetoothYesYes
Ethernet (LAN)YesYes
Wi-Fi802.11a/b/g/n/ac (Dual-Band)802.11a/b/g/n/ac (Dual-Band)
Screen Mirroring/CastingChromecast, Airplay2Chromecast, Airplay2
Voice AssistantGoogle AssistantGoogle Assistant
Works WithHey Google, Amazon AlexaHey Google, Amazon Alexa
Sleep TimerYesYes
RemoteYes, Voice remote with backlightYes, Voice remote with backlight
Remote FinderYesYes
Detachable Power CableYesYes
Console ColorGraphiteGraphite
Cleaning KitYesYes
Quick Start Guide / ManualQSG in the box, Manual onlineQSG in the box, Manual online
Dimensions (WxHxD)20.9″ x 4.7″ x 13.2″20.9″ x 4.7″ x 13.2″
Weight18.7 lbs17 lbs
Remote Controls or Hisense PL2 Projector
The Bottom Line
Hisense has been successful in both the TV and projector categories and was the first to make the UST projector concept work in the home entertainment space with its laser TVs that come with both a projector and a screen in one package. However, in the past couple of years they have also released standalone UST projectors that cater to users who may already have a screen or would to like make the decision on what screen might be right for them. The PL2 is the newest projector from Hisense that offers this option.
The Hisense PL2 has most of the core features and specifications as the previously released PL1 but incorporates a higher lumens output, a larger maximum screen size option, can be placed slightly closer to the screen, has an additional HDMI connection, and is almost two pounds heavier than the PL1. The PL2 is priced at $500 more than the current price of the PL1, but the PL1 originally sold for $2,799 (MSRP) so to have its replacement, with even better performance, priced at $2,499 is a decent deal.
For the $500 difference, the PL1 is still a great option while it is still available unless you would like a larger 150-inch screen option and the higher brightness of the PL2.
Hisense PL2 4K Laser UST Projector Rear Angle
Where to buy Hisense PL2?
The Hisense PL2 is available as of October 23, 2024 at the following online stores.
The Hisense PL1 is still available for $1,987 at Amazon, and $1,997 at ProjectorScreen while supplies last.
Related Reading
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
