HDTV 4K & 8K TV
Preview: Hisense CanvasTV Takes on Samsung’s The Frame For Less
The Hisense CanvasTV hangs flush on the wall like a picture frame for watching shows or displaying art, but should you buy it over Samsung’s The Frame?
Hisense CanvasTV (2024 model) Hung on Wall Lifestyle
Although Korean based Samsung is the still number one selling TV brand worldwide, two Chinese brands (Hisense and TCL) are gaining significant ground in a dead heat for 2nd place. It’s not hard to see why. Both brands continue to offer “near” pound-for-pound performance at lower price points and in larger sizes.
One of Samsung’s most popular TV lines is The Frame, which is slim enough to be mounted like a picture frame for displaying digital art in stand-by mode. Although it debuted in 2017, surprisingly its style has not been copied, until now. Hisense’s answer to The Frame is the CanvasTV.
CanvasTV is designed to blend art, personalization, and premium picture quality, at an affordable price point. The first model in this new S7N CanvasTV series is being offered in a 65-inch screen size with a 55-inch screen size to become available later in 2024.
Hisense CanvasTV Google TV (2024 model)
CanvasTV Features
  • Art Mode: This feature curates a library of free art, such as abstract, modern, and Renaissance styles. When the “Art Mode” button is pressed on the remote, users can switch between pre-loaded, iconic artworks and personal photographs. Users can also rotate and style personal photos to create a personalized artistic centerpiece.
  • Visuals and Sound:  The S7N is a 4K UHD QLED TV. This means that it incorporates a Quantum Dot layer that provides an enhanced color range. The Hi-Matte anti-glare display screen supports clarity and vibrancy, unaffected by ambient light. A multi-channel 2.0.2 surround sound system offers an immersive listening experience.
Tech Note: Consider a soundbar or home theater audio system for the best listening experience when TV sound is lacking.
Hisense CanvasTV Corner Bezel (2024 model)
  • Seamless Design Personalized to Taste: The CanvasTV comes with a teak outside frame. However, customers can further personalize their TV’s appearance with additional optional frame options. The interchangeable frames are held securely by embedded magnets, making it easy to swap them out. The UltraSlim Wall Mount ensures a flush installation for a sleek, space-efficient look.
  • Entertainment Features: Just as other select Hisense TV models, the S7N incorporates the same connectivity and features as other Hisense TVs. The S7N also incorporates the Google TV OS. Google TV provides access to 700,000+ movies, shows, live TV, and more from various apps and subscriptions, along with curated recommendations from a vast library.
  • Gaming: The S7N features 144Hz Game Mode PRO. A Variable Refresh Rate (VRR) of 48Hz to 144Hz, AMD FreeSync Premium, Auto Low Latency Mode (ALLM), and Low Latency MEMC virtually eliminate screen tearing and reduce lag in a gameplay environment.
CanvasTV vs. The Frame
The chart compares basic features of the 65-inch Hisense CanvasTV and Samsung The Frame TV. There may be differences at other screen sizes.
Hisense CanvasTV vs. Samsung The Frame (2024 models)
Hisense S7N Canvas TVSamsung The Frame TV
Price (65-inch Model)$1,299$1,799
TV Type QLED QLED
Display PanelLCDLCD
Backlight SystemLED Edge-litDual LED Edge-lit
Smart TV PlatformGoogle TVTizen
Art ModeYesYes
Game ModesYesYes
Screen Sizes (diagonal inches)55, 6543, 50, 55, 65, 75, 85
Anti-Reflective Matte DisplayYesYes
Display Resolution 4K UHD4K UHD
Surround SoundDTS Virtual XDolby Atmos
Dolby VisionYes
HDRHDR10, HDR10+, HLG, HDR10+ AdaptiveHDR10, HDR10+, HLG, HDR10+ Adaptive
NetworkWiFi 5WiFi 5
ChromecastYes
AirPlayYes
HDMI Audio Return ChannelARCeARC
Refresh RateUp to 4K@144HzUp to 4K@120Hz
Remote ControlBacklit Voice RemoteSolarCell Remote
Wall Mount IncludedYesYes
TV Depth1.4″1″
Rotating Wall MountN/AOptional
Customizable FrameYesYes
One Connect Box*N/AYes
Warranty2 years1 year
Weight63.5 lbs49.3 lbs
* Samsung’s external One Connect Box houses all inputs/outputs so that only a single link cable connects into the back of the TV. Whereas all connections on the Hisense CanvasTV are located on the back of the TV.
Hisense CanvasTV Google TV on-wall with art (2024 model)
Initial Impressions
Consumers choose an art-based TV because of how flush it mounts and blends into a room. Video quality, while good, is generally less of a concern since both brands offer higher picture quality sets per screen size for less.
A TV’s digital art integration and library are important considerations which may give Samsung an advantage, but they charge a subscription fee. Although, we’re not sure what Hisense offers or charges. However, both sets let you display your own photos.
Usability is the biggest difference day to day. The CanvasTV uses a Google TV interface, while Samsung uses Tizen. Either Smart TV platform gets the job done, and choosing one you already know could shorten your learning curve.
Installation and setup may be handled by a professional installer, but Samsung’s One Connect Box offers more flexibility when connecting other equipment. Since the box can be tucked away in a cabinet, it’s easier to connect other equipment nearby with short cable runs. Alternatively, CanvasTV’s connections all lead into the back of the TV, which could require multiple cable runs through the wall.
Ultimately, Hisense CanvasTV has copied The Frame’s slimness, framing style, and art features, while asking $500 less. That’s significant savings that makes it hard to justify spending more.
Hisense CanvasTV (2024 model) Hung on Wall Lifestyle Angle
Price & Availability
The Hisense CanvasTV S7N series is available now in a 65-inch model for $1,299 at Amazon. A 55-inch model is coming later this Summer (2024) for $999.
Tip: We reviewed The Frame (2020 model) a few years ago and found it quite a compelling option. Since then, Samsung has added a matte screen finish to cut down on glare, larger screen sizes, and new framing/mount/stand accessories.
1 Comment
1 Comment
  1. ORT
    July 24, 2024 at 6:17 pm
    In the past year I have purchased two Hisense TVs. A U8 and a U7.
    I do not buy crap. I had some trouble with the U8 but found it was the fault of the Firestick and removed it from my system. The U8 is the sharpest and best looking TV I have owned.
    I bought the U7 model for my daughter and her family. It is close to my U8 in performance. The new model U8 Hisense models are said to be even better.
    ’nuff said? Indeed.
    ORT
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
