Earbuds & In-Ear Headphones
HiFiMAN’s SVANAR Wireless Jr and LE Earphones Expand Their Hi-Res Bluetooth Range
HiFiMAN’s SVANAR Wireless Earbuds lineup has expanded with two new models price at $299 and $179.
HiFiMAN SVANAR Wireless Jr Earphones in Charging Case Lifestyle
Our review of the HiFiMAN SVANAR ($499) Wireless earphones is coming this week and it will be interesting to see if the new SVANAR Wireless LE ($299) and SVANAR Wireless Jr ($179) address some of the issues that arose and created mixed feelings about them.
HiFiMAN clearly sees some daylight in the wireless earbud category which is already oversaturated; the wireless earbud category is projected to grow to over $20 billion by the end of 2024 so it’s not hard to understand their optimism.
HiFiMAN SVANAR Wireless Jr and LE Earphones
Left: SVANAR Wireless Jr | Right: SVANAR Wireless LE Earphones
The new products are significantly more affordable and that makes sense based on the sales data; 99% of the market exists below $400 USD and Apple controls a huge slice of that pie.
The biggest differences between the two new models is that the LE has the same Hymalaya DAC as the reference model, but the Jr does not. However, the Jr has both types of noise cancelling and can also play LDAC files.
SVANAR Wireless LE
HiFiMAN SVANAR Wireless LE Earphones in Charging Case Front
The new SVANAR Wireless LE ($299) is a full range high-performance Bluetooth 5.2 earbud that features a custom version of HIFIMAN’s Hymalaya multi-bit ladder DAC/AMP module that results in clearly audible sonic improvements over standard wireless receivers built-in 1-bit DAC chips.
Combined with the headphone amplifier module, the SVANAR Wireless LE claims to bring a sense of realism and a wide soundstage to audio streamed from smartphones, tablets, Digital Audio Players (DAP), and any Bluetooth device.
In addition to the Hymalaya DAC, SVANAR Wireless LE features HIFIMAN Electronics’ Topology Diaphragm: each earbud’s diaphragm, which converts mechanical vibrations to sound, is covered with a Nano particle coating that contributes to significantly greater sonic detail than is typically associated with True Wireless earphones.
HiFiMAN SVANAR Wireless LE Earphones Lifestyle
SVANAR Wireless LE is designed to be enjoyed on-the-go, with ANC Deep Noise Cancellation that accurately identifies and eliminates noise up to -35dB. Also, SVANAR Wireless LE is IPX5-rated for resistance to sweat and dirt over hours of uninterrupted activity.
The frequency range of SVANAR Wireless LE is 10Hz to 35KHz.
The on-board amp output is rated at 45mW. Average battery time is four-to-seven hours, depending upon usage. The earbuds, each of which weigh 8 grams, can be charged three times before needing to recharge the case.
SVANAR Wireless Jr
HiFiMAN SVANAR Wireless Jr Earphones in Charging Case Front
At $179, SVANAR Wireless Jr claims many same sonic benefits thanks to HIFIMAN’s Topology Diaphragm and Class AB amplifier that boasts the high efficiency output and low distortion.
Two noise canceling technologies — ANC Deep Noise Cancellation and ENC Deep Voice Cancellation combine to create one of the most effective noise canceling systems in personal audio. ANC accurately identifies and eliminates noise up to -35dB.
To keep voice calls clear and clutter-free, ENC relies on artificial intelligence that simulates the human auditory system, extracting the human voice while filtering out extraneous noise.
The full range, high-performance Bluetooth 5.2 earbud is IPX5 water resistant, making it the perfect companion when engaging in active sports for hours at a time. Svanar Wireless Jr is compatible with the high-resolution LDAC codec, for true high fidelity output when streaming from a compatible source device.
The frequency range of SVANAR Wireless Jr is 10Hz to 35KHz. The on-board amp output is rated at 45mW, and maximum output is 50mW@32 THD+N: 1%.
The fully charged SVANAR Wireless Jr battery lasts a substantial 4 to 7 hours, depending upon usage. The SVANAR Wireless Jr weigh 8 grams and can be charged 3 times before one needs to recharge the charging case.
Where to buy:
NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
FiiO FX17 IEM FiiO FX17 IEM
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Craft Recordings announces seven titles coming to participating independent music retailers on Record Store Day, April 12, spanning jazz, salsa, rock and soul.
Daily Deals
Spring time is here and with it the opportunity to bring home a giant TV at a great price to enjoy all the basketball...
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Is it possible to make Hi-Fi and home theater work in really small spaces? EIC Ian White's journey into the great unknown of cabin...
Over-Ear Headphones
Are the Grado Signature S950 really that different? Two significant changes to their design and a more balanced sonic approach make them an emotional...
