HiFiMAN’s SERENADE Wireless DAC/Headphone Amplifier Supports Lossless Streaming for Less Money
The HiFiMAN SERENADE Wireless DAC/Headphone Amplifier offers lossless streaming over Wi-Fi for $200 less than its predecessor.
HIFIMAN Serenade Wireless Angle
Before you chime in with “Didn’t HiFiMAN introduce the Goldenwave Serenade DAC/Amplifier back in 2023?” — there is a difference between that version and this one.
The price has also dropped below $1,000 which makes this “new” iteration more appealing.
HiFiMAN Serenade Wireless Front View from Top
The HiFiMAN SERENADE Wireless is designed for personal audio and music fans looking for enhanced flexibility and performance with multiple streaming and physical connectivity options. An integrated Wi-Fi card allows for lossless wireless streaming of high-resolution audio.
The new SERENADE Wireless desktop DAC/headphone amplifier incorporates HIFIMAN’s proprietary Hymalaya Pro Ladder DAC, an update of the company’s first-generation Hymalaya DAC, originally released in 2021.
From Dr. Fang Bian, President and CEO, HIFIMAN Electronics: “The addition of a Wi-Fi card adds greater flexibility to the reference-quality SERENADE,…With its Hymalaya Pro ladder DAC, SERENADE Wireless is the perfect match for music lovers who want to wirelessly stream high-resolution audio for the best sound at any price…SERENADE Wireless is the next step in our mission to bring high-resolution audio to our customers, no matter their preferred source.”
HiFiMAN Serenade Wireless Top Internal
HiFiMAN’S Hymalaya Pro R2R DAC, with the added support of a new FPGA algorithm and 0.01% precision resistors, provides performance that surpasses the commonplace PCM1704 in every way, reaching a THD (Total Harmonic Distortion) rate of -6dB 0.0012%. Performance is equivalent to that of two PCM1704K DACs.
With a built-in Wi-Fi card, the SERENADE wireless offers significantly lower latency compared to traditional Bluetooth and is compatible with major mobile devices and PC operating systems.
The SERENADE Wireless amp circuit is based on a Class A design, supplemented by a precisely matched, discrete transistor amplifier circuit, with dozens of power transistors that are precisely matched, delivering both high-frequency airiness and warm mid-to-low frequencies.
The Serenade Wireless incorporates a 50w toroidal transformer with a full-band iron core, a large-pool filter capacitor of nearly 30,000 microfarads, and a multi-stage, multi-channel, low-noise, high-speed voltage regulator circuit.
The SERENADE Wireless uses an FET operational amplifier, with a discrete component LPF analog circuit that translates into detailed sound with high-precision, low-noise test indicators. The digital input options and supported formats are comprehensive and meet high standards.
HIFiMAN Serenade Wireless Front Rear Views
SERENADE Wireless outputs, in addition to Wi-Fi, include 4-pin XLR, 6.35mm and 4.4mm on the front panel, with XLR balanced, RCA single-ended outputs, and a pair of RCA single-ended audio inputs on the rear panel.
Comparison
The SERENADE Wireless and previously released GOLDENWAVE SERENADE have the same outward appearance, features, and specifications except for the Wi-Fi connectivity built into SERENADE wireless. Neither unit provides Bluetooth connectivity.
SERENADE Wireless (2024)GOLDENWAVE SERENADE (2023)
Price$999$1,199
Headphone Amplifier Balanced Output Power ( THD+N<0.07% @1KHz)4000mW@32 Ω
760mW@300 Ω
4000mW@32 Ω
760mW@300 Ω
Headphone Amplifier  RCA Single-ended  ( THD+N<0.07% @1KHzoutput)2800mW@32Ω
510mW@300 Ω
2800mW@32Ω
510mW@300 Ω
Frequency Response 20Hz-20KHz, ±0.1dB@1KHz20Hz-20KHz. ±0.1dB@1KHz
(THD+N) Signal-to-Noise Ratio110dB, 0dBFS@1KHz110dB, 0dBFS@1KHz
Channel Separation120dB, 0dBFS@1KHz; THD+N: 0015%, 3dBFS@1KHz120dB, 0dBFS@1KHz; THD+N: 0015%, 3dBFS@1KHz
DAC output level4.5V/XLR, 2.2V/RCA, 0dBFS@1KHz4.5V/XLR, 2.2V/RCA, 0dBFS@1KHz
Digital Inputs and Supported FormatsUSB PCM: 32-bit/384kHz, DSD64-DSD256
COAX OPTICAL: PCM32-bit/192K DSD DoP64
Wired LAN: PCM44.1-PCM768DSD64-DSD512
WI-FI: PCM44.1-PCM768DSD64-DSD512
DoP64
Dimensions (protrusions not included)300 x 255 x 50mm
12 x 10 x 2 inches
300 x 255 x 50mm
12 x 10 x 2 inches
Net Weight 3.9 kg
8 lbs, 10 oz
3.9 kg
8 lbs, 10 oz
The Bottom Line
HiFiMAN is known primarily as a headphone maker, but it also has an extensive line of DAC/Headphone Amplifiers. It is interesting that after releasing the GOLDENWAVE SERENADE in 2023, they are back so soon with essentially the same unit, but with built-in Wi-Fi for $200 less.
The previous GOLDENWAVE SERENADE was still able to access the internet, but only through a wired Ethernet connection. With the new Serenade users now have both wired and wireless options available.
Another interesting thing to note is that the SERENADE Wireless doesn’t carry the GOLDENWAVE label, which is odd as both units have the same features and components.
Was this a planned omission, or can HIFIMAN no longer use the GOLDENWAVE name?
In any case, at $999, the SERENADE wireless might just be the ticket for any high-end audio system. However, if you are looking for something that is less pricey, but less flexible (no network or Wi-Fi), check out what FiiO, iFi, and Michael Fidler have to offer.
Price & Availability
The SERENADE Wireless will be available now for $999 at the HiFiMAN Store.
1 Comment
1 Comment
  1. David O.
    January 1, 2025 at 5:06 am
    Still no remote. An odd ommission given that this unit has a-welcome rca input and can also function as a preamp. If it had remote I would buy it.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
