DAPs
HiFiMAN HM-802 Reference Music Player
HiFiMAN today introduced a new high-end portable music player, the HM-802, which claims to deliver audiophile-grade sound at a more affordable price. Based on the company’s HM-901, the HiFiMAN HM-802 achieves its lower price point by use of the proven Wolfson Dual DAC chip.
Like the HM-901, HM-802 shares the same user interface, high performance step attenuator and rugged design. All amp cards and cable connections are also interchangeable. In addition to offering best-in-class sound quality, the new HiFiMAN player accepts a wide array of audio formats, is expandable and easy to operate.
According to HiFiMAN Founder and President, Dr. Fang Bian, “The best technology and great sound is only as good as the user’s ability to operate their device and access their music, quickly and easily. Along with great sound, ease of use has been a high priority in designing our portable players and the HM-802 is no exception. For example, on the User Interface for the HM-901, you’ll notice that the buttons and a rotating navigation menu cleverly comprise the main interface. The innovative TAICHI UI and high quality volume controller also add value and performance to the entire operating system.”
HiFiMAN HM-802
Price and Availability
HiFiMAN HM-802 is available now for $699.
Features:
Wolfson WM8740 Dual DAC chip
Upsampling to 24/192
Accepts most lossless audio formats, including Apple lossless
Step potentiometer for the volume control
TAICHI UI for fast response and simplicity of operation
Sleek design with robust case made of high-tech composites
Expandable including amplifier card
Digital input/output and USB decoding through optional docking station
Gapless playback (will support via firmware upgrading)
Specifications:
Music Formats: most major formats including WAV, FLAC, ALAC, AIFF, AAC, APE. Also supports playing DSD (DFF) files.
Distortion: less than 0.003%
S/N: 107dB
Stereo crosstalk: 86 dB (line output), 72 dB (balanced headphone output)
Supplied Accessories:
The player
Power supply
Amplifier card
Extension socket (Line out, coax input, coax output, USB cable, charge port)
HiFiMAN will be exhibiting at CES 2014 in # 6238 at the LVCC North Hall and at the Venetian in Suite 30-331. In addition to the new players, on display and demonstration will be the entire line of HiFiMAN award-winning full-size headphones, in-ear phones and headphone amplifiers.
Key Features of the HiFiMAN HM-802:
Sound quality comparable to reference digital playback systems
Accepts most major audio formats
Easy to set up, Simple to operate
Expandable – additional modules available
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
