HiFiMAN HE1000 Unveiled Open-back Planar Headphones: CanJam SoCal 2024
At $2,699, the new top-the-line HE1000 series audiophile headphones feature a removable back panel and stealth magnet technology.
HiFiMAN HE1000 Unveiled Open-Back Planar Magnetic Over-Ear Audiophile Headphones All Sides
HiFiMAN has introduced the HE1000 Unveiled ($2,699), a follow-up to one of its most popular open-back planar magnetic headphones. Its “unveiled” technology adds a removable back panel that first debuted in the HiFiMAN’s flagship headphone, Susvara Unveiled ($8,000).
The removable back panel is called a Magnetic Veil. When not in use, it simply acts as a protective shield. During listening it’s removed to maximize the exposure rate of the grills. The company says its nanometer-thick diaphragm is so lightweight that reflections from the grill disturb the movement pattern of the diaphragm.
HiFiMAN HE1000 Unveiled Magnetic Veil Removed
As Dr. Fang Bian, Founder and CEO, HIFIMAN Electronics explains: “The most effective way to avoid sound wave reflections and refractions from the grill is to eliminate the entirety of the grill design, leading to complete openness of the diaphragm. The result is sound that is demonstrably more detailed and open, which is why we refer to this approach as ‘unveiled’ technology.”
In addition, use of Stealth Magnet technology claims to achieve maximum sound transmittance and diaphragm control force at a refined balance point. Its purpose is to reduce distortion to a bare minimum for sound that is naturally warmer, with improved imaging and transparency.
Stealth Magnet technology is notable for an asymmetrical, double-sided magnetic circuit that gradually adjusts the magnet’s gap and cross-sectional shape, both inside and outside of the diaphragm.
HiFiMAN HE1000 Stealth Magnet vs HiFiMAN HE1000 Unveiled
HiFiMAN HE1000 Stealth Magnet (left) vs HiFiMAN HE1000 Unveiled (right)
Specifications Compared
HE1000 V4HE1000 Unveiled
MSRP$1,399 $2,699
Sensitivity93 dB95 dB
Frequency Response8Hz-65KHz8Hz-65KHz
Driver TypePlanar MagneticPlanar Magnetic
Impedance32Ω28Ω
Headphone Weight458 grams
450 grams
(excluding magnetic veils and cable
Package Contents:
  • Pair of headphones
  • 3m headphone cable (4-pin XLR plug)
  • 3m headphone cable (6.35mm plug)
  • 1.5m headphone cable (3.5mm plug)
  • Pair of Magnetic Veils
  • Pair of ear pads (mounted on headphone)
  • Owner’s Guide
“Following up the recent success of the Susvara Unveiled, we are proud to bring the Magnetic Veil design to one of our most popular high-fidelity headphone series to date,” says Dr. Bian. “It’s a point of differentiation that sets the HE1000 Unveiled apart from every other headphone in its price class.”
The Bottom Line
Planar magnetic headphones have come a long way over the past decade and it’s exciting to those of us who love headphone listening to see how companies such as HiFiMAN, Audeze, Dan Clark Audio, and Meze Audio are always trying to raise the bar with each new product cycle.
None of that innovation negates the sonic performance of the current crop of high-end planar headphones and we’re very curious to listen to these at CanJam SoCal 2024 this weekend to ascertain if the naked drivers truly make a difference.
The HE1000 Unveiled are not inexpensive at $2,700 USD and they enter the market against some strong competition from the aforementioned brands. HiFiMAN has introduced some excellent sounding headphones over the past few years and each new model has been easier to drive — which is one of the knocks against full-sized planar magnetic headphones.
We can’t wait to hear how these perform with a really high-end DAP and desktop amplifiers.
Price & Availability
The HiFiMAN HE1000 Unveiled are available for pre-order now for $2,699 at the HiFiMAN’s online store with an October 2024 expected ship date.
The previous version known as HE1000 Stealth Magnet (V4) is available for $1,399 at Amazon or Headphones.com.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
Over-Ear Headphones
For under $600, the DT 1770 Pro MKII closed-back studio headphones are a more refined and textured update of a classic studio can.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Over-Ear Headphones
Are the Grado Signature S950 really that different? Two significant changes to their design and a more balanced sonic approach make them an emotional...
Headphones
An affordable electrostatic headphone? The STAX SR-X1 makes that a real possibility for those who have always wanted to experience what makes them unique.
