HiFiMAN HE1000 Planar Magnetic Headphone
HiFiMan HE-1000 Headphones Top
HiFiMAN announced a $3,000 full-size planar magnetic headphone, the HE1000, intended for reference use in the home or studio. Assuming the position as the company’s flagship model, HE1000 combines several new innovations that raise the bar for absolute performance, style and comfort.
HiFiMAN is the only headphone brand to fully utilize Nanotechnology as HE1000 features the world’s first Nanometer grade thickness diaphragm, which means that it is less than an astonishing 0.001 mm thin. Seven years in the making, this breakthrough diaphragm is so thin that when viewed from the side, it is not visible to the naked eye. The incredibly low driver mass produces fast, effortless response with negligible distortion, two key elements to the ultimate goal of natural sound reproduction.
To take advantage of the Nano-Grade driver, HiFiMAN engineers designed an Advanced Asymmetrical Magnetic Circuit. A painstaking process, it took the HIFIMAN team seven years to obtain the optimum balance between high driver efficiency and high sound quality. The innovative design of the double-sided, asymmetrical magnetic circuit is the perfect marriage of the Nanometer Grade Diaphragm and its Magnetic partner.
Window Shade Grill System
HiFiMAN needed to create a special design solution that provides driver protection, is optimized for an open-back design and that also yields the best possible sound quality. For HE1000, a patented “Window Shade” grill made with premium alloys is the solution, precisely structured to gain greater openness in the headphone design. Its openness keeps the sound waves from second refraction to avoid unwanted vibration and distortion. The result is a wider soundstage, outstanding imaging and remarkable clarity.
HiFiMan HE-1000 Headphones Close-up
Aesthetically, as an added benefit, the Window Shade Grill also provides a unique, high-tech look to HE1000 and an appropriate complement to its premium alloys and wood trim.
The premium ear pads of HE1000 have been specially designed in an asymmetrical shape that follows the form of the ear cups. The pads are beveled so that they contour to the shape of the user’s head for superb comfort and extended listening as well as a good acoustic seal. The hybrid design has velour on the surface for optimal comfort and sound.
Ergonomic, comfortable headband design for most head shapes and sizes
The HE1000 headband is the result of clever industrial design. Entirely new thinking was needed that would accommodate the widely varied sizes of people’s heads while applying or distributing correct pressure evenly. This provides not only improved comfort but also a better seal of the pads around the ears and on the head for improved bass.
The headband combines a special metal alloy with fine calf’s skin to form a sturdy arch structure. The perforation on the calf’s skin helps to dissipate the heat. For additional comfort, the light mass also contributes to lessen the overall weight of the headphone.
Making the Connection
HiFiMAN only uses the finest cables for their headphones and each model features a cable specially designed for it. HE1000 is supplied with a high purity, oxygen-free copper (OCC) wire custom designed for wide frequency range, low signal loss and enhanced emphasis on the low end for quality audio reproduction. The HE1000 package includes three different types of plugs: mini 6.35mm, ¼” 3.5mm and 4-pin XLR connector so it can be used with a wide array of equipment. The plugs are easy to switch and quickly connected to different cables and amplifiers.
According to HiFiMAN Founder and President, Dr. Fang Bian, “For many years now, HiFiMAN has created planar magnetic headphones that have sounded quite good and the company has developed a strong following. However all along, it has been my dream to create the world’s best headphone and I decided that to do that I had to leverage my background in Nanotechnology. HE1000 has taken us several years of patience and hard work and so far, the results are very exciting.”
Dr. Bian went on to add, “For HE1000, it was also important for us to take our industrial and mechanical design to an all new level. I feel the look and comfort of this new headphone are comparable to its sound, making it a truly complete package.”
Features
  • Nanometer-Grade Diaphragm first of its kind in headphone application, improves efficiency while reducing weight and distortion.
  • Advanced Asymmetrical Magnetic Circuit- double-sided magnetic circuit provides perfect control of the driver for lifelike clarity and sonic precision.
  • Asymmetrical Ear Cups- form follows function as these ear cups are designed to properly fit the shape of the human ear.
  • Beveled Ear Pads- asymmetrical shape perfectly follows the contour of the human head for an optimum acoustic seal and sublime comfort
  • Ergonomic Headband accommodates a wide range of head sizes and applies pressure evenly assuring maximum comfort for extended periods.
  • Window Shade Grill System- provides greater openness and a wide soundstage by reducing unwanted reflections and distortion.
  • Specially-designed Oxygen-Free Copper (OCC) cable delivers widest possible frequency response, especially on low end, with minimal loss.
Price and Availability
The HiFiMAN HE1000 model is now available to order and shipping in June 2015 for $2,999.
Update: The HE1000 V2 was released in late-2016 in a lighter design with thicker earpads. It now sells for $1,399 at Amazon.
About HiFiMAN
Founded by Dr. Fang Bian in 2007, HiFiMAN is widely regarded as one of the leading manufacturers of high performance headphones and portable audio products in the world. HiFiMAN is especially known for its critically-acclaimed Planar-Magnetic headphones that feature state-of-the-art driver technology. The company also designs and manufactures best-in-class dynamic in-ear phones that have also garnered awards and rave reviews. HiFiMAN also owns and operates Head-Direct, an online webstore featuring the finest headphones and portable audio players available today, including HiFiMAN products.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
