HiFiMAN’s EF600 DAC/Amplifier Utilizes A New R2R DAC: CanJam NYC 2023
At $799, the versatile EF600 serves as a headphone stand, high-resolution Bluetooth transmitter and balanced desktop DAC/Amplifier.
HiFiMAN EF600 Desktop DAC/AMP Front and Rear Angle
CanJam NYC 2023 starts in 3 days but that hasn’t stopped HiFiMAN from already announcing 3 new products including the $1,999 USD AUDIVINA Planar Magnetic Headphones that require a DAP or desktop headphone amplifier to really justify the price of admission.
When HiFiMAN discontinued its EF6 Headphone Amplifier, it created a void in its product lineup; the remaining amplifiers were designed to be paired with the Susvara, Jade, Shangri-La, and Shangri-La Jr. headphones. A quick look at the HiFiMAN website reveals some eye-opening prices for these particular systems and unless you don’t mind going without a car — they are priced well out of the reach of 99% of the planet.
HIFIMAN today introduced the EF600 balanced desktop DAC/amplifier, designed for audiophile-grade desktop performance. It follows the EF400 desktop DAC/amp ($599) introduced last year.
Designed for use as a DAC, or independent headphone amplifier, the EF600 (SRP: $799) features an industrial design that is not only aesthetically appealing, it also serves as a headphone stand, reducing desktop clutter. Included are fully balanced input/output connections, high-resolution Bluetooth connectivity, an independent power supply and a thermal optimized tower case.
“The EF600 has the power and advanced technology to stand out from a field that too often relies on off-the-shelf technologies instead of incorporating technologies that are truly unique to the category,” says Dr. Fang Bian, President and CEO, HIFIMAN Electronics. “The Hymalaya Pro DAC module alone represents a giant leap forward from DACs that were considered state-of-the-art only a few short years ago.”
HIFIMAN’s Hymalaya Pro consists of an array of highly accurate resistors that use a “ladder” method of conversion. This approach converts the digital signal with maximum accuracy and overall musicality.
The Hymalaya Pro supports up to 24-bit/768kHz PCM; there is no support for MQA or DSD.
HiFiMAN EF600 Desktop DAC/AMP Front and Back
The EF600 includes two Hymalaya Pro modules for improved sonic output, especially when compared to the more commonplace PCM1704k module. The Hymalaya Pro, with the added support of a new algorithm and 0.01% precision resistors, reaches a THD (total harmonic distortion) rate of -60dB 2%.
Bluetooth connectivity is achieved with an upgraded design that supports multiple codecs, including LDAC, delivering lossless sound reproduction for audiophile-level sonics.
An array of RCA and XLR inputs allows the EF600 to be used as a high-performance headphone amplifier that is fully compatible with most CD and SACD players or even external phono pre-amplifiers.
The EF600 requires the bare minimum of desktop or rack space. The physical dimensions are: 104mm/4” x 135mm/5 1/4” (top); 104mm/4” x 165mm/6 1/2” (bottom); 283mm/11”(height).
The front panel includes four balanced outputs – 6.35mm single-ended, 3.5mm single-ended, 4.4mm balanced, XLR four-pin balanced – in addition to a four-level function switch and volume control. The rear input panel includes jacks for RCA, USB-B, and USB-C source connectors, in addition to dual (L/R) XLR three-pin full balanced line outputs.
The signal-to-noise ratio is measured at 118dB (weighted), channel separation is 131+/-3dB, and THD+N (line out) is 0.0014% (-8dB).
Maximum power output is robust at 5.12 wpc @ 32 ohms balanced/1.8 wpc @ 32 ohms unbalanced, giving the EF600 the power to drive the majority of low-efficiency planar headphones, including HIFIMAN Electronics’ flagship model, Susvara
Price & Availability
The EF600 DAC/amplifier will be available in April 2023 at a suggested retail price of $799 from authorized HiFiMAN dealers and the company’s online store.
Related reading: CanJam NYC 2023 Coverage
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Does full EQ functionality and even more power make the Element IV an easy recommendation at $549?
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Over-Ear Headphones
HiFiMAN Arya Unveiled open-back headphones feature exposed planar magnetic drivers and an all-new sound. Find out how it compares to the prior Organic and...
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
At $1,300, is the STAX SRM-400S capable of driving some of the best headphones in the world?
