New HiFiMAN ANANDA-BT Wireless Headphones Debut at CanJam SoCal 2024
At $799, the refreshed HiFiMAN ANANDA-BT planar magnetic wireless headphones include a R2R DAC and Stealth Magnet technology.
HIFIMAN ANANDA-BT R2R Wireless Headphones 2024
When the original HiFiMAN ANANDA-BT debuted in 2019, it was one of the most expensive Bluetooth wireless headphones at $999. Now there are many more competitors in the luxury wireless headphone category ($699 to $999), which include the Focal Bathys, Bowers & Wilkins Px8, and Mark Levinson No. 5909.
HiFiMAN has responded with an updated version of its wireless ANANDA-BT open-back planar magnetic headphone at a lower price, just $799. However, there are two key distinctions between ANANDA-BT and its competitors. ANANDA-BT is the only one to use planar magnetic drivers, which have significantly lower distortion when compared to dynamic drivers used in its competitors. However, the trade-off makes ANANDA-BT larger and heavier, while also forgoing noise cancellation.
HIFIMAN ANANDA-BT R2R Wireless Headphones 2024 with Travel Case
2024 HiFiMAN ANANDA-BT (also known as ANANDA-BT R2R)
What’s new?
The new ANANDA-BT (2024 model) adds HiFiMAN’s R2R DAC along with Stealth Magnet technology, while using a NEO “supernano” Diaphragm (NsD) that’s 80% thinner. All these technologies contribute to lower distortion and more efficient use of power, although battery life remains the same at 10 hours per charge.
“When we first introduced the ANANDA-BT five years ago, it represented the best of both available Bluetooth technologies and features unique to HIFIMAN,” says Dr. Fang Bian, Founder and CEO, HIFIMAN. “This new version of a HIFIMAN classic takes the best of the original and adds several of our most recent developments to create a new standard in high-fidelity wireless audio.”
ANANDA-BT also includes a window shade grill design that reduces sonic reflections for improved clarity, and a hybrid headband design for hours of listening comfort. There’s also now a built-in microphone for calls and gaming.
HIFIMAN ANANDA-BT R2R Wireless Headphones 2024 Inputs and Controls
Tip: HiFiMAN says its planar headphones benefit from break-in to achieve optimum performance. This typically takes up to 150 hours, although headphones can still be used during this period.
Technology
ANANDA-BT not only supports Bluetooth playback (up to 24-bit/96kHz) but also can be directly connected to a device via a USB cable for music playback (up to 24-bit/192kHz).
With full support for high-resolution protocols including LDAC, aptX, and aptX-HD, the ANANDA-BT is compatible with most high-definition playback devices on the market, ensuring excellent audio signal transmission for outstanding sonics.
HiFiMAN’s R2R DAC is composed of an array of resistors with a new algorithm that reduces power handling between the chip and peripheral components. As a result, signal-to-noise ratio, total harmonic distortion, and energy consumption are said to be at their most efficient and cost-effective.
Use of Stealth Magnet Technology ensure sound waves pass through to your ears without generating interference. HIFIMAN says its advanced magnet design is acoustically transparent, which dramatically reduces wave diffraction turbulence that degrades the integrity of the sound waves. The company claims reduced distortion yields pure sonic output that is accurate and full-range.
Rounding out the list of ANANDA-BT technological updates is its NEO “supernano” Diaphragm (NsD). The new NsD is 80% thinner than previous designs, resulting in fast response and detailed image with lush, full range sonics.
HIFIMAN ANANDA-BT 2019 vs. 2024 Wireless Headphones
HiFiMAN ANANDA-BT (2019 model, left) vs. ANANDA-BT (2024 model, right)
Specifications Compared
ANANDA-BT
(2019)
ANANDA-BT
(2024)
MSRP$999$799
Frequency range8Hz-55kHz 8Hz-55kHz
Impedance35 Ω25 Ω
Sensitivity103 dB103 dB
Weight495 grams469 gram
Charging time2.7 hours2.7 hours
Battery Life10 hours10 hours
Bluetooth version5.05.1
CodecsaptX, aptX HD, HWA, LDAC, LHDCaptX, aptX HD, LDAC, AAC, SBC
HIFIMAN ANANDA-BT R2R Wireless Headphones 2024 Angle
Initial Impressions
The ANANDA-BT R2R’s price makes it competitive in a crowded market of excellent options, but we wonder if the absence of active noise cancellation will make it a non-starter with some buyers.
The reduced weight is a step in the right direction because the original version was very heavy to say the least.
We also wonder why HiFiMAN went with aptX HD and not aptX Adaptive or aptX Lossless?
The planar concept in a wireless headphone is unique and if the sound quality is superior to the Bathys or Px8 — consumers will have another excellent option to audition.
HIFIMAN ANANDA-BT R2R 2024 Accessories
Package includes Headphone Travel Bag, USB-C to USB-A cable, USB-C to USB-C cable.
Price & Availability
The HiFiMAN ANANDA-BT R2R is available for $799 at HIFIMAN’s Online Store.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Over-Ear Headphones
HiFiMAN Arya Unveiled open-back headphones feature exposed planar magnetic drivers and an all-new sound. Find out how it compares to the prior Organic and...
At $1,400, the fourth-generation Arya Unveiled features a removable “Magnetic Veil” back panel and Stealth Magnet Technology.
