HiFi Rose’s RA280 Integrated Amplifier Features GaN FET Technology and A Much Lower Price Than The Flagship RA180
The RA280 integrated amplifier boasts 250-watts per channel using a unique combination of Class AD technology with GaN FETs.
HiFi Rose RA280 Integrated Amplifiers in Silver and Black with remote control
HiFi Rose distributed by Henley Audio might be a small brand, but it offers up some great HiFi components such as the RS130 Network Streamer, RS520 Streaming Amplifier, and RS201E Media Player we have previously reported on.
For 2024, HiFi Rose is offering a new integrated amplifier, the RA280 which will first be available in the UK market first before its North American distribution begins.
The RA280 is built on the foundation of the HiFi Rose RA180 flagship amplifier ($6,995), first released in 2022. The RA280 offers a lot of power from a relatively small chassis and utilizes the core technologies of the RA180; with fewer features and a much lower price.
Using HiFi Rose’s innovative Class AD design, featuring GaN FET technology, the RA280 is a rather important addition to the HiFi Rose amplifier lineup. The RA280 retains the core look of the RA180, with a more minimalist approach.
HiFi Rose RA280
Key Features
  • Amplification: The RA280 incorporates a Class AD (Advanced D) amplifier with 250W per-channel output.
  • FETs: Gallium Nitride FETs in the amplification stage deliver perfect linear output
  • Phonostage: Built-in moving magnet phono stage
  • Neutral Output: Neutral output design, complemented by Bass and Treble tone controls with bypass selector.
  • Power Supply: Purpose-designed high-efficiency power supply with Silicon Carbide FET technology
  • Construction: Distinct, retro-industrial aesthetic with high-purity aluminum construction
  • Status Display: Dimmable VU meters
  • Control: IR remote control included
HiFi Rose RA280 Integrated Amplifier in Black
HiFi Rose RA280
Amplification
HiFi ROSE independently developed Class AD amplifier technology using GaN (gallium nitride) FETs and applied this technology to the RA280. The company claims to have achieved sound quality comparable to analog while maintaining the efficiency and power amplification of existing Class D amplifiers.
The RA280 uses the innovative new material gallium nitride (GaN) to replace the previously used silicon FET (field effect transistor). This material is said to dramatically improve dead time to 1/10 of the previous level and implements linear output with a switching speed close to zero. This improvement in linearity is the result of pushing the limitations of Class D amplifiers, allowing smooth, natural reproduction of sound quality with the fluidity of an analog amplifier.
The RA280 is designed with two separate amplifier modules that operate like a mono amplifier, supporting 250 W (4 ohm and 8 ohm) for the left and right amplifiers respectively, outputting 500-watts on a stereo channel.
HiFi Rose’s LC filter claims to provide excellent frequency response by offering -1 dB attenuation in the frequency band up to 65 kHz and -3 dB attenuation in the 85 kHz range. This technology also claims to dramatically reduce carrier noise caused by the inherent switching of Class D amplifiers, providing clearer and cleaner sound quality in all bands. HiFi Rose says spatial description and resolution have been greatly improved, creating an evolved sound with an analog feel.
HiFi Rose RA280 Rear
HiFi Rose RA280
Power Supply
The RA280”s power supply circuit was independently developed by HiFi Rose. This circuit uses silicon carbide FET instead of silicon FET to stably provide high output while minimizing heat generation. In addition, RA280 applies a 2.5 kW power factor correction (PFC) circuit and a high-capacity condenser to maintain excellent performance even under rapid load situations.
MM Phono
The RA280 supports moving magnet input with a simple switch selection, but does not seem to support moving coil (MC) phono cartridges. Additionally, it utilizes a high-precision correction circuit independently developed by HiFi Rose said to deliver audio signals as close to the original sound as possible.
HiFi Rose RA180 Integrated Amplifier
RA180
HiFi Rose RA280 Front
RA280
RA180 vs RA280
RA180RA280
Released2022 (flagship)2024
Cabinet  ConstructionHigh Purity AluminiumBody-Solid Aluminium / Rust-Proof Steel
Amplifier Out (4Ω)200W x 4ch (800W)250W x 2ch (500W)
Amplifier Out (8Ω)200W x 4ch (880W)250W x 2ch (500W)
Amplifier Output: BTL Mode On400W x 2ch (400W)
Input Sensitivity Balanced Input (XLR)2000mV600mV
Unbalanced (Line 1,2,3) Input (RCA)1000mV300mV
Phono (MM) Input5mV / 0.5mV5mV
Impedance Input Balanced Input44k Ohms47kΩ
Impedance Unbalanced
(Line 1,2,3) Input
47k Ohms47kΩ
Impedance Phono (MM) Input47k47kΩ
THD 0.005% (50W)0.007% (@ 125W)
Damping Factor>150>250
Signal to Noise Ratio107dB (Balanced)
105dB (Unbalanced)
109dB
Phono MM (S/N)80dB85dB
Phono MC (S/N)60dB
Output Impedance53m Ohm30mΩ
Tone ControlBass (100Hz) / Treble (10kHz) +- 15dB(Bass (@100Hz) / Treble (@10kHz)) ±15dB
Phono Turnover Flat300Hz (+7.7dB @100Hz)400Hz (+11.7dB @100Hz)500Hz (+13dB @ 100Hz)700Hz (+14.5db @ 100hz)500Hz (+13dB @100Hz)
Phono Roll-offFlat1.6kHz (-16dB @ 10kHz)2.1kHz (-13.7dB @ 10kHz) 3.18kHz (-11dB @ 10kHz3.4kHz (-8dB @ 10kHz)6.36kHz (-5dB @ 10kHz)2.1kHz (-13.7dB @10kHz)
Trigger 3.3v ~12V3.3v ~12V
Power Supply
(Switched Mode)
800W500W
Dimensions (WDH)430 x 348 x 109.2mm/16.9  x 13.7 x 4.3-inches/430 x 355 x 103mm/16.9 x 13.9 x 4.1 inches
Weight16.7 kg/36.8 lbs9.5 kg/21 lbs
Price (SRP) – Dealer Locator$6,995.00 USD
(£5,543)
USD price pending
(£2,999)
For more information: hifirose.com/RA180
HiFi Rose RA280 Remote Control
2 Comments
2 Comments
  1. ORT
    February 13, 2024 at 1:29 am
    Aaaaaaagh!! Now that I got the “Charlie Brown” moment out of the way…This is a thing of desirable beauty. Alas that my current problems prevent me from getting one.I
    Curse my metal body!
    ORT-3PO
    • Ian White
      February 13, 2024 at 4:50 pm
      ORT,
      I knew you would love the meters. 😉
      If this sounds even close to the flagship model for 1/2 the price…very much worth the money.
      Ian White
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
The WiiM Vibelink drops streaming, but users gain an inexpensive, flexible, and powerful integrated amplifier.
WiiM is well-known for its streaming products, but they are expanding their reach with a dedicated integrated amplifier.
Starting at $21,600, the high-end Burmester 232 Integrated Amplifier offers DAC and Phono pre-amp upgradability for $13,300 extra.
The Onkyo Icon Series includes three components offering network streaming, MM/MC phono capabilities, Roon-Ready support, and Class A/B amplification priced below $2,000 each.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
