Dongle DACs
HIDIZS’ S8 PRO Robin Portable Hi-Res Dongle DAC is Only $99?
With support for 32-bit/384kHz PCM and native DSD256, combined with singe-ended and balanced headphone outputs,
the $99 HIDIZS S8 PRO Robin could be an exceptional value.
Hidizs S8 Pro Robin Dongle DAC
Following up on the debut of the SD2 Dongle DAC and ST2 PRO USB-C IEM Headphones at CES 2024, HIDIZS has unveiled the new S8 PRO Robin Dongle DAC Headphone Amp which is being shown at the Bristol HiFi Show this weekend.
Users of large planar magnetic headphones will need to look elsewhere, but the $99 asking price and rather compact design certainly makes this one to consider if you are looking for something small to drive headphones and IEMs with a friendly impedance and high-sensitivity rating.
Has the Dongle DAC market become overly saturated? Without question.
But our experience with some recent products from both HIDIZS, iFi, and FiiO below $200 in the category makes us rather bullish on the S8 PRO Robin.
Tip: The HIDIZS SD2 Dongle DAC and ST2 PRO USB-C IEM Headphones announced at CES 2024 are also being shown at the Bristol Hi-Fi Show.
Hidizs S8 Pro Robin Dongle DAC Sides
What the HIDIZS S8 PRO Robin Offers
The HIDIZS S8 PRO Robin is an affordable, compact portable USB Headphone DAC/Amplifier designed to provide an excellent solution for improving your headphone listening from various sources including iPhone 15, PC, Mac, portable gaming devices & more at a very low price.
The diminutive S8 PRO Robin incorporates dual flagship Cirrus Logic CS43131 DACs, which support up to 32-bit/384kHz PCM and native DSD256 Hi-Res audio files.
For maximum flexibility with different types of headphones, the HIDIZS S8 Pro Robin includes both Single-ended (3.5mm) and Balanced (4.4mm) headphone outputs. ​The outputs support offer a frequency response of 20Hz-45kHz.
The rather minimalist design features a CNC machined aluminium body and only physical controls for volume adjustment and filter selection. A sampling rate indicator is positioned on the side of the chassis allowing users to confirm PCM and DSD playback.
The HIDIZS S8 PRO Robin works across multiple devices and platforms, including Windows, MacOS, Android, iOS, and Harmony OS.
Specifications:
  • DAC: Dual 32-bit Cirrus Logic CS43131
  • PCM Audio Support: Up to 32-bit/384kHz
  • Native DSD Audio Support: Up to DSD256
  • 3.5mm Single-ended Output: Yes
  • 4.4mm Balanced Output: Yes
  • Chassis: CNC Aluminium Alloy Integrated Molding
  • Frequency Response: 20Hz-45kHz
  • Physical Buttons: Power, Volume +/-, Filter Selection, Sampling Rate Indicator
  • Distortion: 3.5mm: 0.0005% / 4.4mm: 0.0006%
  • SNR: 3.5mm: 125dB / 4.4mm: 125dB
  • Separation: 3.5mm: -74dB / 4.4mm: -110dB
  • Output Power: 3.5mm: 80mW+80mW @32Ω / 4.4mm: 160mW+160Mw @32Ω
  • Selectable Digital Filters
    • High Pass
    • NOS (Non-oversampling)
    • De-emphasis
    • Fast and Slow
    • Low-latency and Phase-compensated
    • Wideband Flatness Mode
Availability and Pricing
The HIDIZS S8 PRO Robin will be available from March, priced at £79, €79, and $99 from Authorized Retailers.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
