Hegel Introduces V10 Phono Preamplifier
At $1500, Hegel’s V10 phono stage was designed to reveal every last detail out of your turntable and vinyl collection.
Hegel V10 Phono Preamplifier beside turntable
Hegel today introduced its first phono stage. The new Hegel V10 Phono Preamplifier was built from the ground up using modern, discrete amplification, for vinyl enthusiasts looking for the detailed, dynamic and a neutral soundstage the company is known for.
Hegel V10 Phono Preamplifier front angle
Hegel says the V10 is a brand-new take on an old technology and is a phono preamplifier like no other. The chassis is divided into two compartments, physically separating the power supplies from the sensitive amplification circuitry. There is no detectable interference between the two parts. For the best possible connection, the V10 offers gold-plated terminals, balanced XLR outputs, and a solid custom grounding screw. On the all-important input stage, Hegel uses ultra-low-noise discrete JFET transistors for both the Moving Magnet (MM) and Moving Coil (MC) input. Eliminating external noise is especially important when using sensitive low output MC cartridges. That is why its MC input is fitted with four such transistors connected in parallel, making the input completely silent and stopping any bias current feedback to the cartridge coil.
Hegel V10 Phono Preamplifier rear view
The input signal feeds into equally silent amplifier circuits, where both the MM and the MC gain stages use ultra-low-noise power supplies built with discrete bipolar transistors to keep the signal noise at a minimum. This ensures an extremely accurate amplification of the input signal coming from the turntable. And to make sure the V10 gets the best operating conditions, it is supplied with a linear, low noise, analog AC-power supply. This features a large, custom design, E-core transformer, placed in its own housing to eliminate all possibility of interference.
Out of the box the V10 is configured as an excellent plug and play MM preamplifier. For many, this is exactly what they want and need, but some want even more. In such cases the V10 is highly optimizable, and can be adjusted for any MM and MC cartridge.
Hegel V10 Phono Preamplifier Back Right
The company says when the V10 is combined with a decent cartridge, the level of detail it can extract from a good vinyl pressing is just breath-taking.
Features
  • MM and MC
  • Subsonic Filter
  • Balanced (XLR) output
  • Highly optimizable
  • Auto standby
Price & Availability
The Hegel V10 Phono Preamp will be available mid February 2021 for $1500 (USD) / €1395 / £1,350. Learn more at: www.hegel.com/products/phono/v10
Specifications
Amplifier Typology Ultra low noise discrete JFET transistor input stage for both MC and MM MM: 40dB / 45dB / 50dB / 52dB
Gain XLR Out MC: 60dB / 65dB / 70dB / 72dB
MM: 34dB / 39dB / 44dB / 46dB
Gain RCA Out MC: 54dB / 59dB / 64dB / 66dB
MM Load CapacitanceFreely adjustable between 33 and 550 ohm / 47 kohm
MC Load Impedance 100pF / 147pF / 200pF / 220pF / 247pF / 320pF / 420pF / 467pF @ 47 kohm
Subsonic Filter: Switchable on / off, -3dB at 20Hz, -18dB octave
RIAA Accuracy+/- 0,2dB / 20Hz – 20kHz
Output Noise -84dB/MM (“A” weighted ref: 0dBV)
-81dB/MC (“A” weighted ref: 0dBV)
Output ImpedanceXLR / RCA: 200 ohm
Channel Crosstalk-84dB @1kHz 0dBV
Frequency Response2Hz-20kHz
Distortion (THD) MM: < 0.005%
MC: < 0.009%
@1kHz 0dBV
Inputs1*unbalanced (RCA) MM
1*unbalanced (RCA) MC
Outputs 1*unbalanced fixed (RCA)
1* balanced fixed (XLR)
Power AdapterHegel Power Adapter (M30103)
Dimensions with Feet 2.4” x 8,3” x 11”
HxWxD6cm x 21cm x 28cm
Unit Weight4.9 lbs unit weight
2.2 kg
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
