Digital Music Systems
Preview: Hegel H400 “Streamliner” Streaming Amplifier
Hegel’s H400 is nicknamed Streamliner for its streamlined design and performance. Just add speakers to this 250-watts per channel streaming powerhouse.
Hegel H400 Streamline Streaming Amplifier
Streaming amplifiers continue to make their way into home audio by combining an integrated amplifier with a built-in DAC (Digital Audio Converter) and digital music streaming capabilities that are accessible via network (Ethernet or Wi-Fi) connectivity.
The latest entry into this product category is the Hegel H400 “Streamliner”.
Priced at $6,995 USD, the Hegel H400 replaces the H390.
The H400 is made to drive any speaker, connect any source, and stream anyway, without compromising audio quality. Hegel’s streaming amplifiers provide an all-in-one solution that doesn’t break the bank but still provides high-end audio performance and ease of use.
Hegel H400 Streamline Streaming Amplifier Lifestyle Front
What’s New
According to Hegel, here is what is new on the H400.
  • New DAC (model not specified)
  • Control app that, in addition to volume and input control also provides radio and podcast access. Tip: The new control app also works with Hegel Reference H600.
  • A new streaming platform for better app support.
  • A new audio board that improves the sound from all inputs
  • New top cover with a tighter, smoother look including circular, more effective heat vents.
  • Rotary controls allow menu navigation without using the remote control.
  • New top cover with a tighter smoother look, including circular, more effective, heat vents.
  • Solid aluminum front panel and knobs. Milled out from one single aluminum block, then bead blasted and anodized
Hegel H400 Streaming Amplifier Front Screen
Feature Spotlight
Streamlined Visual Design Designed with simplicity and intuitive operation in mind, the H400 features a sleek, minimalist front with two multifunctional knobs for source selection and volume control. The knobs can also be pressed to mute, pause, or navigate the device menu. The display panel provides status information that is clear and easy to read from a distance, To maintain a clean and uncluttered appearance, the power button is located underneath the amplifier.
Amplification: The H400 incorporates a Class AB amplifier that delivers up to 250-watts (x2) of power into 8 ohms and is also stable down to 2-ohm loads. With a damping factor of 4000, the H400 supports precise and dynamic sound through connected speakers.
The dual mono amplifier construction and symmetrical layout ensure superior sound quality. The absence of an equalizer preserves signal integrity, while SoundEngine 2 technology provides instant distortion correction during amplification. This results in better sound while maximizing power efficiency.
Streamlined Connectivity: The H400 offers extensive analog and digital input options. You can also connect with any speaker, even those who are very hard to drive. Automatic signal detection recognizes connected digital audio sources and switches to the correct input, eliminating the need for manual selection.
All inputs can be set at a fixed high volume, enabling the use of home theatre preamps and multi-room devices. A TV remote function is also provided that lets you use your TV remote to control the amplifier, making home entertainment setups more intuitive and user-friendly.
Shared Features with Reference Integrated Amplifier: The H400 incorporates many of the advanced features found in Hegel’s H600 reference integrated amplifier such as Dual Mono design, robust streaming platform, and a high-quality bit-perfect DAC based on the one in the H600.
These shared features mean that the H400 delivers similar high standards of sound quality and versatility, making it a remarkable choice for discerning listeners.
Hegel H400 Streaming Amplifier Back
Streaming and Control App: The H400 is optimized for simplicity, supporting popular streaming platforms such as AirPlay, Spotify Connect, Roon Ready, Tidal Connect, Google Cast™, and UPnP. Users can control the amplifier through these services directly.
Additionally, the Hegel Control App provides volume and input control, and access to internet radio, podcasts, and media server playback, enhancing the overall user experience. Whether you are streaming your favorite playlist or exploring new podcasts, the H400 makes it easy and enjoyable.
Multi-Room Audio: The H400 supports multi-room audio via Roon, AirPlay, and Google Cast, enabling synchronized music playback in different areas of your home. Imagine having the same high-quality audio in every room, seamlessly integrated with your smart home system.
In-House Development:  The H400 has been developed in-house. This ensures consistent quality control and cohesive design. This approach eliminates unnecessary steps and complications, allowing engineers to focus on innovation and performance.
This in-house development strategy also allows for faster implementation of new features and improvements.
Environmentally Friendly: Built from high-quality materials and components, the H400 is designed for durability and reliability, ensuring a long life, and minimizing the need for frequent maintenance.
The SoundEngine 2 technology makes the H400 energy efficient, consuming minimal power while delivering top-tier performance. This technology and the amplifier’s auto standby feature reduce energy waste and environmental impact without compromising sound quality.
Comparison
Hegel H400 vs H390 vs H600 Reference
H400 StreamlinerH390 H600 Reference
Price (USD)$6,995$6,500$12,500
Component TypeStreaming AmplifierStreaming AmplifierStreaming Amplifier
Power Output2 x 250W in 8 ohms, Dual Mono2 x 250 W into 8 ohms, Dual Mono2 x 303W in 8 ohms, Dual Mono
Minimum Impedance2 ohms2 ohms2 ohms
Analog inputs1 x Balanced (XLR)
2 x Unbalanced (RCA)
1 x balanced (XLR)
2 x unbalanced (RCA)
2 x Balanced (XLR)
Analog Outputs1 x Unbalanced fixed(RCA)
1 x Unbalanced variable(RCA)
1 x unbalanced fixed (RCA)
1 x unbalanced variable (RCA)
1 x Unbalanced fixed (RCA)
 1 x Unbalanced variable (RCA)
Digital inputs1 x Coaxial (BNC) S/PDIF – 24/192, DSD64(DoP), MQA 8x
1 x Coaxial (RCA) S/PDIF – 24/192, DSD64(DoP), MQA 8x
3 x Optical S/PDIF – 24/96, MQA 8x
1 x USB – 32/384, DSD256(DoP), MQA 8x
 1 x Network – 24/192, DSD64, MQA 8x
1 x coaxial (BNC)
1 x coaxial (RCA)
3 x optical
1 x USB,
1 x Network
MQA-supported inputs: USB, BNC, Optical, and Coaxial
1 x Coaxial (BNC) S/PDIF – 24/192, DSD64 (DoP), MQA 8x
 1 x Coaxial (RCA) S/PDIF – 24/192, DSD64 (DoP), MQA 8x,
1 x USB -32/384. DSD256 (DoP), MQA 8x
Digital Outputs1 x Coaxial (BNC) S/PDIF – 24/1921 x coaxial (BNC)1 x Coaxial (BNC) S/PDIF – 24/192
Streaming Services Spotify Connect
Roon Ready
AirPlay
Tidal Connect
Google Cast
Airable Internet Radio Podcast
UPnP Streaming
Spotify Connect
Roon Ready
Apple AirPlay
UPnP Streaming
Spotify Connect
Roon Ready
AirPlay
Tidal Connect
Google Cast (pending)
UPnP Streaming
Streaming FormatsMP3, WAV, FLAC, ALAC, AIFF, DSF, DFF, AAC, PCM, MQA, OggMP3, WAV, FLAC, ALAC, AIFF, DSF, DFF, AAC, PCM, MQA, OggMP3, WAV, FLAC, ALAC, AIFF, DSF, DFF, AAC, PCM, MQA, Ogg
Frequency response5Hz – 180kHz5 Hz – 180 kHz5Hz – 100kHz
Signal-to-noise ratioMore than 100 dBMore than 100 dBMore than 100 dB
CrosstalkLess than -100 dBLess than -100 dBLess than -100 dB
DistortionLess than 0.005% @ 50W 8 Ohms 1kHzLess than 0.005% @ 50W/8 Ohms/1 kHzLess than 0.005% @ 50W 8 Ohms 1kHz
IntermodulationLess than 0.01% (19kHz + 20kHz)Less than 0.01% (19 kHz + 20 kHz)Less than 0.01% (19kHz + 20kHz)
Damping FactorMore than 4000 (main power output stage)More than 4000 (main power output stage)More than 4000 (main power output stage)
Dimensions (HxWxD)15 x 43 x 44 cm
5.9 x 16.9 x 17.3”
14.5  x 43  x 44 cm
5.71 x 16.93 x 17.32″
17.1 x 43 x 44.5cm
6.74 x 16.93 x 17.52″
Weight 20 kg
44.1 lbs
20 kg
44.1 lbs
22 kg
48.51 lbs
Initial Impressions
In this age of streaming, a streaming amplifier is a great addition (or switchout) for a typical integrated amplifier as in many cases, it offers both built-in streaming and physical connectivity. However, not many offer the extensive power output capability of the Hegel H400.
Based on the information provided by Hegel, the H400 is a highly engineered unit with lots to offer, but there are a couple of things to take into account.
One thing is that for all the connectivity it does offer, there is no direct phono input or HDMI-ARC/eARC connectivity. This means that unless you have a turntable with a built-in phono preamp, you will have to connect an external phono preamp between the turntable and the H400.
In addition, if you want to use the H400 with your TV, you will have to opt for the digital optical connection option, rather than the more versatile HDMI-ARC/eARC option.
In addition, there is the issue of price. The H400 appears to be an excellent offering in the streaming amplifier category, but if you are budget-conscious or just looking for a more modest option, the $369 WiiM AMP Pro disserves a serious look.
Price & Availability
The Hegel H400 “Streamline” Streaming Amplifier is priced at $6,995 (US) and is expected to start shipping September 2024 via authorized distributors and dealers.
Related Reading
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
