Loudspeakers
HDX Audio High Performance Loudspeakers
HDX Audio High Performance Loudspeakers are poised to become the new benchmark by which all High End speakers are judged. The Hdx Audio model “THE KING” uses an exclusive cabinet material called “Hansen Composite Matrix”. A proprietary material that easily outperforms conventional mdf cabinets. All HDX drivers are designed,engineered and built by HDX Audio using many designated propriety components.
This marriage of advanced scientific research, dedication to a philosophy of uncompromising quality, purity of sound and graceful elegant cabinets are the heart and soul of HDX Audio.
While words can convey something of the craft and science that make HDX Audio high performance loudspeakers the best of the best, only when listening can one fully appreciate how great they really are.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
