HAI Now Supports Philips TSU9400 Pronto Remote
Home Automation, Inc. (HAI), leading manufacturer of integrated security and home automation products since 1985, announced today that Pronto Link, a ProntoScript integration module for the Philips TSU9400 Pronto remote is now available as a free download. This is in addition to the ProntoScript that allows integration with Ethernet-enabled HAI Omni and Lumina family controllers and the Philips TSU9600.
The slender vertically aligned Pronto TSU9400 features a bright vivid touchscreen. It is ultra-thin with a stunning 3.5 inch QVGA color touch screen ideal for graphics, a rotary wheel for easy multimedia scrolling and conveniently placed buttons.
Pronto Link allows a homeowner to use either the Philips TSU9600 or TSU9400 as a single remote to control his home theater; adjust lights, temperatures, and security settings; and control multi-room audio systems, such as the Hi-Fi by HAI system. Pronto-Link supports the Pronto’s built-in Wi-Fi, which allows a homeowner to control their home from any room in the house. Pronto-Link automatically configures the home control screens so an installer can easily merge HAI’s home control functionality into a standard Pronto project. HAI’s Pronto Link is compatible with all Ethernet-enabled HAI Omni and Lumina family controllers.
“HAI is dedicated to giving our customers the flexibility to use a variety of interfaces”, explains Thomas Pickral Sr., HAI Director of Distribution Sales. “And we’re looking forward to being a worldwide partner with Philips in the Pronto integration.”
Pronto Link is a free download from the ProntoScript for Philips Certified Installers portion of the Philips Pronto website, www.pronto.philips.com/prontoscript. You will have to login to download the file.
HAI products are available through a worldwide network of Distributors and installing dealers in over 80 countries. For more information, please visit www.homeauto.com or call 800-229-7256.
To download a high res picture of HAI on the Philips TSU9400 Pronto Remote, please click here: http://www.homeauto.com/mediacenter/HaiPRImage.asp?image=9400.jpg
About HAI (www.homeauto.com): HAI (Home Automation, Inc.) is a privately held manufacturer of integrated automation and security products for residential and commercial use based in New Orleans, LA. Incorporated in 1985, HAI has developed a full line of award-winning automation products, including home control systems, programmable communicating thermostats, smart light switches, Whole Home Audio systems, video surveillance equipment, Touchscreen interfaces, and software that allows access and control of an automation system over the Internet. All products are sold through HAI’s worldwide network of Distribution Partners and installed by trained dealers in over 80 countries.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
