FOR IMMEDIATE RELEASE
Contact:
Allison Read
HAI Director of Marketing
4330 Michoud Blvd.
New Orleans, LA 70129
504-736-9810, x229
www.homeauto.com
Allison.read@homeauto.com
July 27, 2006
HAI Now Shipping 15A Relay Switch as Part of its Award-Winning HAI Lighting Control (HLC) Product Line — Only UPB Relay Switch on Market
Home Automation, Inc. (HAI), leading manufacturer of integrated security and home control products since 1985, is now shipping a 15A Relay Switch, Part number 40A00-1 as part of it’s award-wining HLC line. HLC “smart” switches let homeowners easily set elegant lighting scenes for individual rooms, without the use of complicated software programs.
All HAI Lighting Control Products are UL-Listed and use a digital communications standard for lighting and home control called Universal Powerline Bus (UPB) that ensures superior reliability. HAI’s 15A Relay switch is currently the only UPB relay switch on the market and is intended primarily for control of fans and florescent lighting, including compact fluorescents. They are shipped in white with color change kits (Part number 35A14) available in almond, ivory, black, brown, and grey. The 15A Relay switch is compatible with HAI’s Auxiliary Switch (Part number 37A00-1) for 3 — or 4 — way applications.
HAI’s HLC line is a fully two-way communicating lighting control system. It has big-system features while being cost effective and installable on a modular basis. Homeowners can have sophisticated lighting control in a home theater or living room and add rooms as needs grow. Additionally HLC switches can be tied into an HAI home control system or any UPB compatible automation controller for full fledged integrated lighting control coordinated with other events, such as time, motion, security modes, etc.
HLC products are extremely easy to install — no modifications to the home are required. These plug and play products are an easy way to add a touch of class to any home.
For more information on HAI’s HLC product line, including technical specifications and how to purchase, please visit www.homeauto.com or call 800-229-7256.
About HAI: HAI is a privately held manufacturer of integrated automation and security products for residential and commercial use based in New Orleans, LA. Incorporated in 1985, HAI has developed a full line of award-winning automation products, including automation controllers, communicating programmable thermostats, smart light switches, and software that allows access and control of an automation system over the Internet. All products are sold through HAI’s worldwide network of Distribution Partners and installed by over 1000 trained dealers.
