Gryphon Audio Designs Debut EOS 5 Speakers at Hong Kong High-End AV Show 2023
Ultra-luxe Danish brand, Gryphon Audio Designs introduces the EOS 5 Floorstanding Loudspeaker for $50K/pair in four finishes.
Gryphon Audio Designs EOS 5 Loudspeaker in Soul Red Crystal
During our podcast conversation with Denmark-based Gryphon Audio from T.H.E. Show 2023, we were reminded that Gryphon’s ultra-luxe products start where other brands end.
With that in mind, we learned Gryphon’s newest loudspeaker, the EOS 5, just debuted at the Hong Kong AV High-End AV Show 2023 and will retail for about $50,000/pair USD.
The Gryphon EOS 5 Loudspeaker builds on the foundation of their innovative EOS 2 floor standing speaker, offering even greater full range and dynamics from 20Hz – 40kHz (+/- 2dB).
Gryphon Audio Designs EOS 5 Tweeter Closeup
Speaker Drivers
The EOS 5 is a three-way speaker that incorporates the following driver complement:
The 6.5” Midrange and dual 9.5” woofer drivers incorporate TPCD™ (Thin-Ply Carbon Fiber Diaphragm) cone construction and Impulse Optimizer Rings which first appeared in EOS 2. As with EOS 2, the cones are manufactured by one of the world’s leading fabricators of Formula 1 components.
To round out the driver complement, the EOS features a (29mm) Beryllium Dome Tweeter that has been engineered for EOS 5’s higher crossover point.
The EOS speaker has 90 dB sensitivity with 4 Ohm nominal and 2.9 Ohm minimum impedance. This makes them highly efficient for use with modestly-powered amplifiers.
Gryphon Audio Designs EOS 5 (left) vs. EOS 2 (right) Loudspeakers
Visual Design
EOS 5 shares the same type of enclosure style used for EOS 2.
Internally, a line-dampened porting system offers a unique solution to smoothing airflow in this larger, wider-bandwidth loudspeaker. Like the EOS 2, the new EOS 5 benefits from two design flourishes that enhance placement versatility across a wide range of listening environments.
  • A three-position Tweeter Level Switch is provided that provides 0dB, +2dB, or +3dB boost to optimize off-axis dispersion providing flexibility in different room sizes and seating arrangements.
  • Gryphon’s custom-manufactured adjustable spikes are equipped with removable, integrated dampers to provide the most stable speaker positioning on flooring either with or without carpeting.
Gryphon Audio Designs EOS 5 Loudspeaker Inputs Base Rear
Finishes
The EOS 5 will be offered in four finish options: Soul Red Crystal, High Gloss Black, Stealth Grey, and “S-Mat Black.”
Tip: The S-Matte black option feature “Self-Healing” chemistry which, in the event of small scratches, can actually be repaired with the help of a piece of parchment baking paper and iron used at low heat, which encourages the paint to re-flow and regain its normal, unblemished surface.
Availability and Pricing
The EOS 5 will be available in early 2024 with an MSRP of 42,800 EUR ($49,800 US MSRP) through authorized dealers and distributors.
Tip: More detailed specifications will be revealed closer to an announcement of an official release date.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
