Preview: Grimani Systems’ IS-21 Infrasonic 21-inch Subwoofer for $15,000
Forget about surround sound, Grimani’s 21-inch subwoofer with 2400 watts of power will drive sound right through you.
Grimani IS-21 Infrasonic Subwoofer Front Angles
Subwoofers come with a variety of driver sizes, most commonly 8, 10, 12, and 15 inches, but there are some subwoofers with even larger drivers. We have previously reported on massive subwoofers such as the 21-inch RBH Sound 21-SF/R, 15-inch REL Reference No. 32, and the 12-inch Wilson Audio Submerge, but Grimani Systems custom install 21-inch subwoofer caught our attention.
Grimani IS-21
Grimani IS-21 Infrasonic Home Theater Subwoofer
Grimani Systems has added the IS-21 Infrasonic Subwoofer to its custom integration line. With a 21-inch driver and additional support from its 2400-watt amplifier, the IS-21 is designed to provide exceptional deep and immersive bass.
The IS-21 incorporates precision engineering, advanced materials, and state-of-the-art DSP technology — which is what one should be expect for its rather hefty asking price of $15,000 USD.
Grimani IS-21 Infrasonic Subwoofer Driver Front
Features
Specifications
  • Driver Size: 21-inches
  • Amplifier (Outboard): 2400 Watts for single unit, 4800 Watts for two units
  • SPL (Max Burst CTA2010): 124dB
  • Frequency Range: 15Hz to 300Hz
  • Dimensions (WxHxD): 23.5 x 46 x 16 inches
  • Weight: 118 lbs
  • Mounting Options:
    • On-wall: Concealed by screen or stretched fabric, four shock-mount L brackets included.
    • In-wall: Perimeter flanges & fabric-covered grille
    • In-room: Shock-absorbing rubber feet provided for floor placement
Power Amplifier for Grimani IS-21 Infrasonic Subwoofer
From Anthony Grimani, co-founder of Grimani Systems: “The IS-21 goes down a full octave below most subwoofers and brings visceral excitement to music, movies, and games. This innovative product truly adds to the immersive audio experience.
Initial Impression
Because every room is different, one has to take more than just driver size into consideration when selecting a subwoofer for a home theater system. Do you go with a ported or sealed design? Does the product offer advanced DSP that can help you position it properly and maximise its performance even if your room has some acoustic issues?
A good subwoofer not only needs to be able to deliver those room-shaking moments but also needs to deliver the texture and subtleness for times when it is also needed, such as with acoustic music.
On the other hand, large rooms have their own needs as the subwoofer needs to fill the room with deep bass. Sometimes more than one sub is required, and sometimes you need a subwoofer with a very large driver to deliver the goods.
With a 21-inch driver and supporting 2400-watt DSP controllable amp, the IS-21 Infrasonic Subwoofer should deliver bass you can feel to your core. We think it could make a lot of home theater listeners quite happy, but probably not your neighbors.
Pricing & Availability
The Grimani IS-21 Subwoofer, which includes external amp, is priced at $15,000 and is available through authorized dealers (contact Grimani Systems directly for details).
Related Reading
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
For $36,000, Grimani Systems' 5.4 active home theater speaker system boasts 2,160-watts of power from 5 speakers and 4 subwoofers.
Discover audio nirvana with some of the highest performing audiophile products in the world.
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
RSL Speakers undercuts its own pricing by offering a new 10-inch, 300-watt powered subwoofer for music and home theater.
The new flagship VTF-TN1 subwoofer from HSU Research has a 15-inch driver and some additional improvements for $1,199 USD.
