Grado Labs GW100x Wireless Headphones Feature New Drivers & Improved Battery Life
Priced at $275, the updated Grado Labs GW100x Wireless Headphones offer new drivers and improved battery performance.
Grado Labs GW100X Wireless Headphones Lifestyle
The folks at Grado Labs have been burning the midnight oil in Brooklyn for the past 3 years in response to the incredible demand for phono cartridges and headphones; a combination of the resurgence of vinyl and the pandemic which forced tens of millions of people to work and listen from home. We were super impressed with the Grado SR80x, Timbre Opus3, and Prestige Gold3 so far in 2022 and we’re rather curious about the new $275 USD Grado Labs GW100x Wireless Headphones.
Grado are not really known for their wireless headphones and IEMs which have been around for a few years; the high-end press just hasn’t paid that much attention to them when 90% of their otherwise excellent headphones are the open-back wired variety.
Grado Labs GW100X Wireless Headphones Back
The Grado Labs GW100x are certainly not your typical wireless headphones; the open-back design has only been used by a few manufacturers so far with any degree of success.
GW100x Headphone Specifications:
  • Bluetooth Version: 5.2
  • Battery Capacity: 850mAh
  • Working Distance: 10m
  • Battery Life: 46 hours*
  • Frequency Response: 20Hz~20KHz
  • Mic Sensitivity: 42dB +/- 3dB
  • Transducer Type: Dynamic
  • Operating Principle: Open Air
  • SPL 1mW: 99.8 dB
  • Nominal Impedance: 38 ohms
  • Driver Matched dB: .1 dB
The Grado Labs GW100x are the second iteration of the design and the biggest changes are the 4th generation Grado drivers; which have been specifically tuned for the wireless GW100x.
The new driver design features a more powerful magnetic circuit, a voice coil with decreased effective mass, and a reconfigured diaphragm. Reengineering these components for the 44mm drivers improved efficiency, reduced distortion, and offers a higher level of resolution and detail.
Grado Labs GW100X Wireless Headphones Angle
The new ear cup design for the GW100x is also meant to reduce the amount of leakage so that you can listen on the subway or in the office and not disturb others.
With a more efficient battery and Bluetooth 5.2, the GW100x can now play music for nearly two days straight. Matching their GT220 wireless IEMs, USB-C is now included, bringing the GW100x in line with global charging standards.
The upgraded chipset allows more information to flow from your device to the GW100x, all while maintaining a strong connection. The GW100x support Bluetooth 5.2, aptX Adaptive, SBC, and AAC protocols
Grado Labs GW100X Wireless Headphones Side
Phone calls and volume levels can be controlled directly on the earcups and the new GW100x support voice assistant technology.
Included with your purchase are the GW100x headphone, a USB-C to USB-A cable for charging, a 3.5mm headphone jack for a wired connection and an instruction booklet.
For more information: Grado GW100x Wireless Headphones
1 Comment
1 Comment
  1. BRIAN TRENT LAMFERS
    January 26, 2023 at 1:28 pm
    I own these headphones. They are the best Bluetooth wireless so far on the market. The clarity the detail superb for Bluetooth. A lot of Bluetooth sound muddy or two much Bass with no mids or high’s and low volume. These headphones do not do that very clean. Sound best you can get for Bluetooth at this point. Highly recommended
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Over-Ear Headphones
Are the Grado Signature S950 really that different? Two significant changes to their design and a more balanced sonic approach make them an emotional...
Headphones
Not only do the new Grado Signature S950 feature an improved headband, gorgeous ear cups, and a brand new 52mm driver...but they finally have...
Over-Ear Headphones
Can the Grado Signature HP100 SE carve out its own spot at the top of the high-end category below $2,500 against some fierce competition?...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Shopping for wireless noise cancelling over-ear headphones or gaming headsets? Here are our picks for best you can buy on any budget.
