Goldmund Ushers in a New Era of Sound With the Telos 800 Stereo Power Amplifier
With 300-watts per channel RMS, Goldmund claims Telos 800 is one of the finest Stereo Power Amplifiers ever crafted.
Goldmund Telos 800 Stereo Power Amplifier
The hills are alive with the sound of Goldmund? Does Julie Andrews know? So far in 2024, Goldmund has introduced the Theia, Rhea, And Asteria Wireless Speakers, Pulp + Hub Set Wireless Speaker System, and Telos 690 Integrated Stereo Amplifier.
Following up with those product introductions, Goldmund is adding a new stereo power amplifier to its product line-up, the Telos 800
Telos 800
Goldmund Telos 800 Stereo Power Amplifier Front and Rear Views
The Telos 800 is designed to deliver all the power needed to drive any set of passive loudspeakers. Offering significantly more power output than the Telos 690, the Telos 800 enables listeners to use large speakers without sacrificing any of their capabilities or quality.
Tip: For best results, Goldmund suggests pairing the Telos 800 with the Tethys loudspeakers and the Mimesis Signature preamplifier
With an output of 300 Wrms (x 2) at 8 ohms and 390 Wrms (x 2) at 4 ohms, the Telos 800 is a leap forward in Goldmund’s offerings, presenting a formidable stereo amplifier capable of satisfying even the most discerning audiophile consumers.
To support its power output and audio quality, the Telos 800 incorporates a 3200 VA toroidal power transformer and an impressive capacitor bank of 93,600 µF. Compliant with IEC 62368-1 standards on rated power consumption, this amplifier delivers remarkable efficiency and power, rivaling the performance of two mono-power amplifiers.
Capacitors Bank inside Goldmund Telos 800 Stereo Power Amplifier
With a distortion rate of less than 0.05% across IMD and THD+N measurements, and an output noise floor below 3 μV from 20 Hz to 20 kHz, the Telos 800 promises an immersive listening experience with impressive sound reproduction. With a dynamic range of 110 dB and a damping factor of 600 at 1 kHz / 8 Ω, subtle sound nuances are delivered precisely with clarity.
Specifications
Goldmund Telos 800 Stereo Power Amplifier Front Display
  • Rated Power Output (Maximum power IEC 62368-1)
    • 2 x 300 Wrms on 8 Ω / 1% THD
    • 2 x 390 Wrms on 4 Ω / 1% THD
  • Output Noise Floor: Analog input terminated with RCA Shorting Caps unloaded: < 3 μV from 20 Hz to 20 kHz
  • Gain: 35 dB
  • Dynamic Range: 22 kHz measurement bandwidth (flat), true RMS unloaded: 110 dB
  • Damping Factor: 600 at 1 kHz / 8 Ω
  • Output Level: Max level before clipping, 1% THD, unloaded: 170 Vpp
  • Input Level
    • Max level before clipping, Analogue input: 1 Vrms
    • Max level before clipping, Digital input: -6 dBFS
  • Distortion
  • Rated Power Consumption: IEC 62368-1, 1/8 Output Power at 8 Ω: 335 W
  • Dimensions (WHD):
    • 44 x 32 x 45.2 cm
    • 17.3 x 13 x  17.8 inches
  • Weight: 57 kg
Goldmund Telos 800 Stereo Power Amplifier Rear Connections Closeup
Connections
  • 1 x Power cord: universal socket 3 lugs
  • 1 x Main fuse (8 A slow-blow for 115V &  230 V)
  • 1 x Green-yellow AC earth binding post (with bridge connection)
  • 1 x Black ground binding post (with bridge connection)
  • 1 x Ground/Earth lift switch
  • 4 x output binding posts (2x red & 2x black; Left & Right speaker Output)
  • 2 x output Goldmund speaker 4B type connector (Left & Right speaker Output)
  • 2 x Analogue RCA input (unbalanced connector, Left & Right)
  • 2 x Analogue XLR input (balanced connector, Left & Right)
  • 1 x Digital input and output RCA connectors
  • 1 x RS232 command connector
Power Supply
  • Nominal line voltage: 115 V or 230 V, 8A slow-blow fuse
  • Input voltage range: +/- 10 %
  • 3200 VA Toroidal Power Transformer
  • Capacitor bank: 93’600 µF
Price & Availability
The Goldmund Telos 800 Stereo Power Amplifier is available at authorized dealers with an SRP of ~85,000 USD (£66,500 / 75,000 CHF) in a silver-gray finish (standard). Goldmund also offers a Black version, available on demand if desired.
For more information: goldmund.com
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
