Goldmund Unveils Telos 690 Integrated Stereo Amplifier
At $36,250, the Goldmund Telos 690 Integrated Stereo Amplifier signifies a bold declaration in the pursuit of sound purity.
Goldmund Telos 690 Stereo Integrated Amplifier
2024 has been a busy year for the luxury Swiss audio brand, Goldmund with the introduction of the Theia, Rhea, And Asteria Wireless Speakers, and Pulp + Hub Set Wireless Speaker System.
Tip: In 2023, Goldmund introduced new Tethys speakers
Following up with those announcements, Goldmund is adding a new integrated amplifier to its product line-up, the Telos 690.
Goldmund states that the Telos 690 is an amplifier that offers a bridge between traditional hi-fi and modern digital sources. Connections options include analog RCA, as well as digital USB Audio class 2.0, Toslink Optical, and Digital S/PDIF coaxial.
Tech Note: The Telos 690 does not provide dedicated MM or MC phono inputs. Nor does it provide A/B speaker connections or switching.
Goldmund Telos 690 Stereo Integrated Amplifier Top Angle
Technology
Telos Amplification technology significantly reduces intermodulation by improving the linearity of all stages and considerably decreasing the time distortion. Telos uses a higher bandwidth circuit with minimal group delay distortion inside the audio bandwidth.
The Telos amplifier input circuitry includes the latest version of Alize Digital/Analog converter circuits for enhanced coupling with the preamp section of the 690. Separate input and output stages prevent feedback between high and low current circuits and improve mechanical grounding.
Telos technology also provides driver control. This lowers the amplifier’s output impedance so that it provides a much higher quality of micro-dynamics and helps large woofers avoid overshooting and overloading your listening space with too much bass information. This means that the Telos 690 can drive any high-end passive speaker system, unleashing its full potential, for convenient high-fidelity sound, without compromise.
The Telos 690 incorporates a dual 350 VA Toroidal Power Transformer and a massive 46,000 µF capacitor bank. This combination ensures that the Telos 690 can deliver enhanced dynamics, response, and clarity for exceptional auditory experience.
With a maximum output power of 2 x 250 Wrms on 8 Ω and 2 x 320 Wrms on 4 Ω, the Telos 690 can drive any high-end passive floor-standing speaker system to its full potential, promising an immersive listening experience.
Goldmund Telos 690 Stereo Integrated Amplifier Left Rear Angle
Craftsmanship
As with all Goldmund products, the Telos 690 is crafted with attention to detail and reflects Goldmund’s commitment to precision mechanics. The upgraded panel structure enhances the mechanical grounding and vibration dispersion capabilities of the amp. It also comes in Goldmund’s custom-designed, robust flight case. Goldmund isn’t just about style, but substance, too.
Specifications
  • Output Level: Max level before clipping, 1 % THD, unloaded: 170 Vpp
  • Output Noise Floor: Analog input terminated with RCA Shorting Caps, unloaded: < 10 μV from 20 Hz to 20 kHz
  • Gain: 35 dB
  • Dynamic Range: 100 dB (with 22 kHz measurement bandwidth (flat), true RMS unloaded
  • Damping Factor: 600 at 1 kHz / 8 Ω
  • Dimensions (WxHxD): 17.3 x 6.5 x 17.5 inches (44 x 16.5 x 44.5 cm)
  • Finishes: Silver Gray (Standard) or Black Matte (Custom)
  • Weight: 62 lbs (28 kg)
Power Supply
  • Nominal line voltage: 110 V or 220 V
  • Input voltage range: +/- 10 %
  • 2x 350 VA Toroidal Power Transformer
  • Capacitor bank: 46’000 µF
Rated Power Consumption: IEC 62368-1, 1/8 Output Power at 8 Ω: 275 W
Goldmund Telos 690 Stereo Integrated Amplifier Rear
Connections
  • 2 x speaker output binding posts (left & right)
  • 1 x On/Off power switch key
  • 1 x Voltage input selector
  • 1 x RS232 Command connector
  • 1 x USB device: Audio Class 2.0 (no driver required on Mac OS X as of v.10.6.4 nor on Linux, driver required only for Windows, contact your Goldmund representative): Sample rate up to 384 kHz/Bit depth up to 32 DSD 64, DSD 128 over PCM capabilities
  • 1 x Toslink Optical
  • 1 x Digital S/PDIF coaxial RCA 75 Ohms
  • 5 x Analog RCA (left & right)
Input Level
  • Max level before clipping, Analogue input: 1 Vrms
  • Max level before clipping, Digital input: -6 dBFS
Rated Power Output (Maximum power IEC 62368-1)
  • ·2 x 250 W RMS on 8 Ω / 1% THD
  •  2 x 320 W RMS on 4 Ω / 1% THD
Distortion
  • IMD (SMPTE), unloaded: < 0.02%
  • THD+N unloaded: < 0.08 % from 20 Hz to 20 kHz at 30 V RMS output
Goldmund Telos 690 Stereo Integrated Amplifier Front
Price & Availability
The Goldmund Telos 690 Integrated Stereo Amplifier is now available for purchase through authorized Goldmund distributors and dealers in Silver Gray or Black Matte finishes. The amp also comes packaged in a high-value, robust flight case custom-designed to ensure secure transportation and delivery.
Price: $36,250 USD / £32,500 / 30,000 CHF (Swiss Franc)
For more information: goldmund.com
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
