Preview: Goldmund Telos 4800 Mono Power Amplifier
Goldmund’s latest monoblock amp delivers 1050 watts RMS at 8 ohms for $260,000, yet it’s one step below the top-of-the-line model.
Goldmund Telos 4800 Mono Amplifier
When it comes to its power amplifiers, Goldmund doesn’t take a back seat to anyone. So far in 2024, we have reported on the Telos 690 Integrated Amplifier and 800 Stereo Power Amplifier that offer a lot of high-end performance with a huge price tag.
Even with a soft economy, high-end brands such as Sonus faber, Gryphon, and Goldmund have focused this year on six-figure products that appeal to a minuscule portion of the market. Goldmund’s new Telos 4800 mono power amplifiers will empty your bank account with very little effort.
Built on the foundation of Goldmund’s flagship 8800 mono power amplifier (released in 2023), the Telos 4800 is designed to drive even very low-impedance loudspeakers without compromising distortion levels, allowing easy integration with any loudspeaker configuration.
Goldmund 4800 Features
Goldmund Telos 4800 Mono Amplifier Menu Screen
Power Output: With a maximum power output of 1050 watts RMS at 8 ohms and a total harmonic distortion (THD) of only 0.005% across 20 Hz to 20 kHz, the 4800 is designed to deliver unmatched sound clarity and power.
Dynamic Range: The dynamic range, measured at 117 dB with a 22 kHz bandwidth, ensures that subtle audio details are rendered accurately.
Damping Factor: The Telos 4800 features a damping factor of 600 at 1 kHz and output floor noise of less than 3 μV, delivering an impeccably clean and detailed sound free from unwanted background noise.
Gain: The amplifier’s gain is adjustable in 3 dB increments, providing precise control and customization to suit individual preferences and audio setups.
Capacitors: Responding to the growing demand for increased capacity and power, the Telos 4800 is equipped with the innovative Goldmund proprietary MKP silver-metalized polypropylene film cap capacitors and a fully massive copper ground plan.
This state-of-the-art component ensures a supremely stable supply for the Mosfet output stage, guaranteeing optimal stability even for demanding loads
Analog Signal Path: With fully analog circuitry from input to output, the Telos 4800 ensures maximum thermal security and short-circuit protection. The amplifier has an automatic shutdown feature, which protects both the amplifier and connected speakers.
Connections: The Telos 4800 is equipped with analog and digital inputs, including RCA and XLR connectors. The rear panel also features a universal power socket, multiple output binding posts, and a ground lift switch. The 4800 also includes a 12-volt trigger jack for external control.
Finishes and Cabinet: The Telos 4800 is available in sleek gray and sophisticated black finishes. Its elegant sidelines are designed to blend authenticity with avant-garde design.
The upgraded, thicker panel structure compared to the previous collection enhances the amplifier’s operation, reinforcing. Mechanical Grounding emphasizing Golmund’s quality craftsmanship.
Comparison
Goldmund Telos 4800 vs. Telos 8800 Mono Amplifiers
Telos 4800Telos 8800
Price (USD)$260,000$366,000
Amplifier TypeMono Power AmplifierMono Power Amplifier
Maximum Power Output (IEC60065)1050 Wrms on 8 Ω / 1 % THD1400 Wrms on 8 Ω / 1 % THD
Dynamic Range22 kHz measurement bandwidth (flat), true RMS unloaded: 117 dB22 kHz measurement bandwidth (flat), true RMS unloaded: 117 dB
Damping Factor600 at 1 kHz / 8 Ω600 at 1 kHz / 8 Ω
DistortionIMD (SMPTE), unloaded:: < 0.01%
THD+N unloaded: < 0.005 % from 20 Hz to 20 kHz at 30 Vrms output
IMD (SMPTE), unloaded: < 0.01%
Output Moise FloorAnalog input terminated with RCA Shorting Caps, unloaded: < 3 μV from 20 Hz to 20 kHzAnalog input terminated with RCA Shorting Caps, unloaded: < 3 μV from 20 Hz to 20 kHz
Gain35 dB, +/- 9 dB (adjustable in steps of 3 dB for each input)35 dB, +/- 9 dB (adjustable in steps of 3 dB for each input)
Input LevelsMax level before clipping
Analog input: 2 Vrms
Digital input: 0 dBFS
Output LevelsMax level before clipping
1% THD, unloaded: 300 Vpp
Audio Inputs Analog input RCA unbalanced connector
Analog input XLR balanced connector
Digital input (RCA connector)
Audio Outputs2 x speaker output binding posts (red & black)
1 x output Goldmund speaker 4B type connector
Digital Output (RCA Connector)
Additional Rear Panel ConnectionsPower cord: universal socket 3 lugs, 16 A
Main fuses (F1: 2.5A ; F2: 1A F3: 8A)
AC black GND binding post
Green-yellow AC earth binding post
Ground lift switch.
RS232 command connector
Jack connector for 12 Volt Trigger
Main fuses
AC black GND binding post (with bridge connection)
Green-yellow AC earth binding post (with bridge connection)
Power SupplyNominal line voltage: 115 V or 230 V
Input voltage range: +/- 10 %
Input voltage range: +/- 5 %
Power ConsumptionIEC 60065, 1/8 Output Power at 8 Ω: 680 WIEC 60065, 1/8 Output Power at 8 Ω: 750 W
Finish OptionsSilver Grey (standard)
Black (on request)
Silver Grey
Black
Dimensions (WHD)
42 x 82.6 x 50 cm
16.6 x 32.6 x 20 inches
42 x 113 x 47 cm
16.6 x 44.5  x 18.5 inches
Weight195 kg
430 lbs
265 kg
584 lbs
Goldmund Telos 4800 Mono Amplifier Top Front
Goldmund Telos 4800
Initial Impression
The Telos 4800 may not be the flagship entry in Goldmund’s power amplifier product line – but it might as well be as you need a lot of cash to buy it and a couple of people to pick it up and move it (dolly recommended).
Also, keep in mind that this is a mono (aka monoblock) power amp which means it only powers one channel in an audio system. So stereo (two-channel) systems require two of these amps. Home theater setups need 5 or more. Let that sink in — in terms of product cost and your electric bill!
On top of that, you need to budget for a preamp to supply input switching and any processing that may be needed before sending those signals to the Telos 4800 to power the speakers.
That being said, on paper the specs for the 4800 are impeccable, so there is little doubt that the 4800 can probably meet the needs of any audio system, regardless of the speakers used. On the other hand, it is probably overkill for 99% of us (including die-hard audiophiles).
Goldmund Telos 4800 Badge
Pricing & Availability
The Telos 4800 and 8800 are available for purchase through authorized Goldmund dealers worldwide
Suggested Retail Prices: Telos 4800
US – $260,000
CHF – 220,000
GB – £235,000
AUS – $445,000
Suggested Retail Prices: Telos 8800
US – $366,000
CHF – 320,000
GB – £350,000
AUS – $650,000
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
