DAPs
Gitzo Introduces Mountaineer Tripod Featuring Breakthrough
Orlando, Florida (February 26, 2006) — Gitzo, revered throughout the world for its precision, quality and innovation in bringing new products to market for both the professional photo and video markets, is proud to announce the Mountaineer GT2540L 2 Series 6X Long Tripod. The new tripod is an extension of the popular Mountaineer line as well as part of a new line of carbon fiber tripods incorporating a revolutionary design process that reduces overall weight up to 17 percent without sacrificing strength or stability.
Available in a four leg section configuration and with a maximum capacity of 17.65 lbs, the new Mountaineer rapid column tripod introduces a new concept of “Eye Level” height tripods. According to this concept, tripods can hold the equipment up to eye level without extending the center column. Photographers and birders no longer need to compromise between tripod performance and use comfort. The taller GT2540L reaches maximum heights of 58.85 and 67.7 in (with fully extended central column) and folds to 24 in for travel.
Used together with the new G2180 Series 1 Fluid Head — also being introduced at PMA 2006 — the GT2540L Mountaineer 6X Tripod is ideal for bird watching and supporting medium sized spotting scopes.
New 6X Carbon Fiber Technology
The existing 1.5mm Gitzo carbon fiber tube wowed the world with its unsurpassed strength, stability and remarkable lightweight form factor. Utilizing a three-crossed multilayer carbon structure, bonded together at high pressure and temperature by high quality resins, Gitzo was able to offer professionals a carbon fiber tube that proved to be the ultimate in vibration absorption, strength and stability.
Tapping into its revolutionary resources and utilizing its unmatched experience with composite materials, Gitzo was able to develop a new, six-crossed multilayer 1mm carbon fiber 30 percent lighter than the previous generation that features the same exceptional performance of stability and vibration absorption and unbeatable quality.
Backing Gitzo 6X technology is the new six-crossed multilayer range which features the Anti Leg Rotation (ALR) system. The ALR system allows for a fast and smooth setup, yet maintains the uncompromised locking strength of the traditional Gitzo twist lock system. Just loosen all twist locks at the same time and pull down the leg before tightening them, making setup a mere 15 seconds for this four sectioned tripod.
By fine tuning its market leading three layer technology to a six layer, with advanced parameters in terms of pressure, temperature and bonding resins, Gitzo was able to create the 6X generation. The six-crossed multilayer tubes measure only 1mm, but are equally as strong and as stable as the 1.5mm, three layer carbon fiber tubes. The 6X range represents, once again, Gitzo leadership not only in introducing unique and world-first innovations, but above all in creating the best products in terms of quality and performances.
In addition to the new, exclusive six-crossed multilayer structure tube and the Anti Leg Rotation System, the new 6X carbon fiber tripods have been further improved to achieve an even higher quality standard. In a world where details matter, even the smallest details on these tripods have been improved. Top casting now features high quality corrosion resistant, polished stainless top casting bolts for added stability and a redesigned built-in, spring-loaded retractable hook on the bottom of the center column provides a place to hang a stabilizing counterweight such as camera, sand or water bags.
Gitzo products are distributed exclusively by Bogen Imaging in the United States. For information, contact Bogen Imaging at info@bogenimaging.com.
About Gitzo:
Professionals the world over acknowledge Gitzo tripods, monopods, heads and accessories as setting the industry’s standards for excellence. Innovations such as the first uses of carbon and basalt fiber to make tripods and magnesium to make heads, matched with a design policy of “no gimmicks and no compromise on quality,” put Gitzo products in a class of their own. Gitzo’s carefully crafted products form a comprehensive range of supports for large, medium and small format cameras, for film or digital technology, for still photography or dynamic video, for studio or location work. Precision assembly, high quality materials and fine control are all qualities that represent Gitzo products.
About Bogen Imaging:
Since 1959, Bogen Imaging (formerly Bogen Photo) has been a leading source for photographic, cinematic and video lighting, supports, and accessories. Many of the most respected manufacturers of precision products for the photographic, video, Cine and lighting are distributed in the U.S. exclusively by Bogen. These include Manfrotto and Gitzo tripods and heads, Kata protective carrying systems and accessories, Avenger lighting grip, I.F.F. ceiling mounted lighting suspension, Metz on-camera flash systems, Gossen light meters, Elinchrom studio lighting systems and a wide host of additional product lines which round out the most complete range of exceptional accessories in the business.
For more information contact:
Bogen Imaging Inc., 565 East Crescent Ave.
Ramsey, NJ 07446
Phone: (201) 818-9500
Fax: (201) 818-9177
e-mail: info@bogenimaging.com
Web: www.bogenimaging.us
Media Contacts:
Jason Ledder or
Melissa Aiello
R&J Public Relations, LLC
jledder@randjpr.com
maiello@randjpr.com
Larry White, Communications Manager
Bogen Imaging Inc.
(201) 818-9500 x-270
larry.white@bogenimaging.com
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
