Genelec G and F Series Active Speakers / Subwoofers
Genelec G and F Series Loudspeakers and Subwoofers
Genelec just introduced the G Series Active Loudspeakers and F Series Active Subwoofers. Both series feature elegant industrial design by award-winning designer Harri Koskinen and Genelec’s R&D team. Used together or separately, the G Series and F Series offer a simplified home audio solution with amplifiers built-in to each speaker and sub.
The Genelec G Series includes four models:
  • G One (Woofer 3″ + Tweeter 3/4″)
  • G Two (Woofer 4″ + Tweeter 3/4″)
  • G Three (Woofer 5″ + Tweeter 3/4″)
  • G Four (Woofer 6.5″ + Tweeter 3/4″)
The Genelec F Series includes two models:
  • F One (6″ active) subwoofer
  • F Two (8″ active) subwoofer
Genelec’s G Series active two-way loudspeakers combine an organic, rounded form with powerful and precise sound reproduction. The gently curving design is not chosen for good looks alone. Sharp edges or corners on a loudspeaker enclosure cause acoustic reflections that interfere with the direct sound. This harmful interference — diffraction — is dramatically reduced by the smooth, curved design of the G Series, audible in the excellent resolution and solid sound imaging of the products. Blending seamlessly to the enclosure shape, the proprietary Directivity Control Waveguide (DCW) formed around the high-frequency driver is designed to match the frequency response and directivity characteristics of the two drivers. This results in a smooth frequency response on- and off-axis and controlled directivity maximizing the direct sound aimed to the listening area.
Genelec’s F Series active subwoofers are designed to complement G Series loudspeakers in applications where an extended and powerful reproduction of very low frequencies is required. The all-metal construction of the subwoofers hides the driver and connectors on the bottom, leaving the clean form of the enclosure undisturbed. Both models feature connections and bass management for up to 5.1 channels and a comprehensive suite of adjustments for perfect matching to the main loudspeakers and room acoustics.
F One Specifications:
  • Maximum sound pressure: 98 dB @ 1 m
  • Frequency response: 35 – 85/120 Hz (± 3 dB)
  • Phase correcting: 0 to -270° (90°/step)
  • Driver: 6 1/2”
  • Amplifier power: 40 W
  • Dimensions: Height x Diameter 9.88″ x 12.01″ (251 x 305 mm)
  • Weight: 13.89 lb (6.3 kg)
F Two Specifications:
  • Maximum sound pressure: 102 dB @ 1 m
  • Frequency response: 27 – 85/120 Hz ± 3 dB
  • Phase correcting: 0 – 270° (90° steps)
  • Driver: 8”
  • Amplifier power: 150 W
  • Dimensions: Height x Diameter 11.81″ x 14.25″ (300 x 362 mm)
  • Weight: 21.61 lb (9.8 kg)
G Four Specifications:
  • Maximum sound pressure: 105 dB per loudspeaker @ 1 m
  • Frequency response: 45 – 21000Hz (-3 dB)
  • Drivers: Bass 6.5″ + Treble 0.75″ metal dome + DCW
  • Amplifier power: Bass 90 W + Treble 90 W
  • Dimensions: H x W x D: 14.37″ x 9.33″ x 8.78″ with Iso-Pod™ (365 x 237 x 223 mm)
  • Weight: 18.96 lb (8.6 kg)
G Three Specifications:
  • Maximum sound pressure: 100 dB per loudspeaker @ 1 m
  • Frequency response: 55 – 21000Hz (-3 dB)
  • Drivers: Bass 5” + Treble 0.75″ metal dome + DCW
  • Amplifier power: Bass 40 W + Treble 40 W
  • Dimensions: H x W x D: 11.77″ x 7.44″ x 7.01″ with Iso-Pod™ (299 x 189 x 178 mm)
  • Weight: 12.35 lb (5.6 kg)
G Two Specifications:
  • Maximum sound pressure: 96 dB per loudspeaker @ 1 m
  • Frequency response: 65 – 21000 Hz (-3 dB)
  • Drivers: Bass 4″ + Treble 0.75″ metal dome + DCW
  • Amplifier power: Bass 20 W + Treble 20 W
  • Dimensions: H x W x D: 9.53″ x 5.94″ x 5.59″ with Iso-Pod™ (242 x 151 x 142 mm)
  • Weight: 8.16″ (3.7 kg)
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
The Audioengine S6 Compact Subwoofer is their smallest, but a perfect match for your desktop home office audio system.
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
