Gemini FirstMix USB DJ Controller
Gemini has introduced the FirstMix USB DJ Controller for aspiring DJs. This easy to use, yet feature rich controller with two touch sensitive jog wheels allows anyone to scratch like a pro with a Mac or PC.
The FirstMix is a DJ MIDI controller with a standard USB connection that works with the powerful MixVibes CROSS LE performance DJ software to give you a powerful all-in-one DJ solution.
The FirstMix recreates the two-decks-and-a-mixer setup that professional DJs use around the world. Just load your tracks to either Deck A or Deck B on the MixVibes CROSS LE software, and then control it, cue up the start point, and even perform advanced transitions and scratching.
The FirstMix has complete DJ controls such as tone controls and sync so you can mix two tracks creatively and match the tempo. The FIRSTMIX even comes with an effects section to add spice and space to your mixes.
Features
  • Includes everything to DJ with your computer
  • Use your Mac or PC to DJ parties, events and even clubs
  • Use your digital music library with support for M4A, AIFF, WAV, MP3, FLAC and OGG audio files
  • Traditional mixer/CD player layout w/ crossfader
  • Two-deck controller with volume, 2-band EQ, effects, and jog wheel for each deck
  • Features large, touch-sensitive jog wheels for a natural vinyl feel for scratching, cueing, etc.
  • Easy-to-use MixVibes Cross LE DJ software included
Price and Availability
The Gemini FirstMix will be available in May 2011 for $79.95.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
