GefenTV Home Theater Audio Processor
Gefen today announced that its GefenTV Home Theater Audio Processor (model GTV-HT-AUDPROC) and optional five-set, wall-mountable speakers are now shipping. These two products work in concert to enable a plug and play method of creating surround sound audio in any room using primarily audio extracted from the HDMI input from any Blu-ray player, gaming system or set-top box. A digital audio input is also available.
The GefenTV Home Theater Audio Processor comes equipped with a variety of both analog and digital audio connections so consumers can select the best sound delivery for their particular entertainment system. There are six analog (25 watts RMS per channel) RCA outputs that support 5.1 Dolby surround sound and can connect to any amplifier achieve the perfect combination of amp/pre-amp so desired in home theater systems. Front right and left channels are bi-amped to improve sound quality.
Powered speakers can be connected directly to the Home Theater Audio Processor's left, right, front left, front right, rear left, rear right, subwoofer and center positions. Finally, one coax input can be passed through in both TOSlink and coax formats, directly connecting digital audio to an existing A/V receiver.
The one HDMI input that supplies audio for the Processor is also split and delivered to two HDMI outputs at the same time, allowing for dual screens or HDTV displays to be connected locally. Both HDMI outputs deliver 1080p full HD video with deep color and 3DTV pass-through capability, as well as multi-channel audio supporting lip sync, Dolby TrueHD and DTS Master Audio.
A high contrast LCD display and front panel buttons on the Home Theater Audio Processor give access to a variety of control features and status information so consumers can finely tune the entire system. An IR remote control and RS-232 connection are also included for full control.
GefenTV Home Theater Audio Processor - Back
Features:
  • Separates digital audio from the HDMI or of S/PDIF inputs and decodes up to 5.1 channels of digital audio
  • Splits one HDMI input source into 2 mirrored HDMI outputs
  • Supported audio formats: Dolby Digital, Dolby Pro Logic, and Dolby Pro Logic II decoding
  • Test tone for system diagnostics
  • Outputs line-level analog audio up to 5.1 channels using RCA connectors
  • Outputs amplified analog audio at 25 Watts per channel RMS on external speaker terminals
  • LCD status display for full selection menu
  • IR control
  • RS-232 control
  • Field-upgradable firmware
  • External / Internal EDID management
  • Small in size
  • This product is HDMI and HDCP-compliant
Specifications:
  • Pixel Clock: 165 MHz
  • Input DDC Signal: 5 V p-p (TTL)
  • Single Link Range: 1080p @ 60 Hz (max.)
  • Maximum Power Output: 25 W RMS
  • Digital Audio Input: 1 x S/PDIF coaxial
  • HDMI Input: 1 x HDMI Female 19-pin
  • HDMI Outputs: 2 x HDMI Female 19-pin
  • Digital Audio Output: 1 x S/PDIF coaxial
  • Digital Audio Output: 1 x TOSLINK optical
  • Speaker Outputs: 7 total (5 five-way binding posts + 2 additional binding posts for Bi-Amp)
  • Analog Audio Outputs: 8 total (6 analog audio RCA jacks + 2 additional RCA jacks for Bi-Amp)
  • Supported Audio Formats:Dolby Digital 5.1 (AC3), Dolby Pro Logic II, LPCM up to 6 channels, Audio Decoding: Dolby Digital 5.1 (AC3), Dolby Pro Logic II
  • Signal-to-Noise Ratio: > 90dB (20 Hz – 20 kHz A-weight filter)
  • THD+N: < 0.1% at 1 kHz at reference level
  • Frequency Response: < ±0.5 dB 20 Hz - 20 kHz
  • Power Supply: 24 V DC
  • Dimensions: 6.9″ W x 2.1″ H x 6.9″ D
  • Shipping Weight: 6 lbs.
MSRP: $999
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
